Bug fix for AM5 new firmware motherboards (DSDT-FIX)
Lorys89
Hi everyone, like @fabiosun I no longer use the patched dsdt, I migrated to the fix with ACPI rename performed by @corpnewt
my feed is positive and works great.
 Asus Rog Strix B650e-i Gaming Wifi - bios vers 3035
Asus Rog Strix B650e-i Gaming Wifi patches_OC.zipFetching info...
  On 7/20/2024 at 1:56 AM, rnieas said:
Can Ryzen 7000 to Ryzen 9000 be exchanged?
Expand
yes work 🙂
Hi !
I installed macOS Sonoma 14.6.1 on my new 9950X, but I can't seem to run it stable on my ASUS ProArt X670E CREATOR WIFI.
For example I crash at the cinebench 2024 launch screen and randomly in x265 encoding 😢
I tried different BIOS from 2007 to 2401 without success. I was using the DSDT patched for 2007 found on the other forum (amdosx), can't boot without it.
Can you help me patch my DSDT or do the ACPI Fix ? thanks !
I was using Gskill F5-8000J4048F24GX2-TZ5RK, same problem at 5200/5600 or even 8000.
ACPI-DUMP-2401.zipFetching info...
Edited by Arch30n
  On 9/18/2024 at 9:54 AM, Arch30n said:
Expand
A first problem i see is you have dummypowermanagemnt disabled and this could cause instability
so, if your system boots fine then it hangs or freeze in few minutes this could help to solve
try first to enable it in emulate section of your patches config.plist
then, you could also try to apply ACPI patches instead to patch all DSDT
ah, by the way CPUR ssdt is disabled in this EFI
Why?
Why?
Expand
Hello, yes in this version i have disabled dummypowermanagemnt for testing, but problem is the same with it enabled.
For CPUR I have tested a lot of configurations trying to enable or disable some SSDT kext too.
I reactivated it, but with no luck, system boot fine, but hangs 20-30 minutes later.
I think my patched DSDT is probably bad ???
I have no ACPI patches for this motherboard.
(To clarify, for the moment, bluetooth, aquantia 10gb and thunderbolt/USB4 are disabled in the bios. I'll see about that later. And i have replaced the RZ600 with a AX210 M2 key card, system is rock solid under Windows 11 and Ubuntu 24.10)
Edited by Arch30n
Still no success 😢
DP properties are ok, i've got 6 NVME drives 🙂
I use a Vega 56
iGPU is disabled
CPUR and dummypowermanagemnt re-enabled
2 tests done :
1) With your ACPI patches : boot hang
2) Old DSDT patched + RebaseRegion enabled : Nothing change, boot ok but not stable
I'm going crazy 😅
Edited by Arch30n
  On 9/18/2024 at 4:45 PM, Arch30n said:
Still no success 😢
I use a Vega 56
iGPU is disabled
2 tests done :
I'm going crazy 😅
Expand
@corpghost did these patches for your motherboard
you can try but i dont know if your problems are related because many users can use patches or dsdt patches
let me know and thanks to corpghost
patches_OC.plist.zipFetching info...
Still the same instability, BUT i can boot without the patched DSDT ðŸ¤© so i can exclude this problem now.
I will investigate further (NVME, USB, etc...). And for info, I also quickly tried installing Sequoia, but it crashes after the picker, i need some logs...
Thanks to corpghost ! and thanks to you 🙂
I will keep you inform tomorrow.
Expand
Have you mounted a pcie gen 5 nvme?
Expand
No, only Gen4 :
  • 2x WD SN850X in the Gen5 slots (Gen 4 mode)
  • 2x Crucial P3 Plus in the Gen 4 slots
  • 2x WD SN770 on a PCIE Gen 4 card plugged into the PCIEX16_1 with bifurcation (works great in my previous 5950X with a MSI X470 board)
I will test tomorrow leaving only the main nvme.
Have you tried ACPI patches in OpenCore instead?
This is getting naughty, as I now see conditional statements inside declarations, in addition to conditionational statements wrapping full declarations.
Edited by etorix
  On 11/4/2024 at 7:31 AM, kosmos said:
Hi!
Could @fabiosun or @Lorys89 please help patching the ROG STRIX X670E-F GAMING WIFI BIOS 2403 DSDT or the ACPI rename?
I've had a patched DSDT that worked but updated the bios and it no longer boots.
Thanks!!
DSDT.zip 30.12 kB Â· 2 downloads
Expand
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>ACPI</key>
    <dict>
        <key>Patch</key>
        <array>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <integer>0</integer>
                <key>Comment</key>
                <string>\_SB.PCI0.GPP7.UP00.DP40.UP00.DP20 NoOp to force-enable</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>
                oECWkJCSk0cwMDIKA5NHMDAwAZCSk0cwMDIKBJKTRzAw
                MwA=
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>OemTableId</key>
                <data>
                QSBNIEkgAAA=
                </data>
                <key>Replace</key>
                <data>
                o6Ojo6Ojo6Ojo6Ojo6Ojo6Ojo6Ojo6Ojo6Ojo6Ojo6Oj
                o6M=
                </data>
                <key>ReplaceMask</key>
                <data>
                </data>
                <key>Skip</key>
                <key>TableLength</key>
                <key>TableSignature</key>
                <data>
                RFNEVA==
                </data>
            </dict>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>\_SB.PCI0.GPP7.UP00.DP40 NoOp to force-enable</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>
                oESnkJKTRzAwMgoDk0cwMDAB
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <data>
                QSBNIEkgAAA=
                </data>
                <key>Replace</key>
                <data>
                </data>
                <data>
                </data>
                <key>Skip</key>
                <data>
                RFNEVA==
                </data>
            </dict>
        </array>
    </dict>
</dict>
</plist>
ths was done by @corpghost from amd osx discord for you
  On 11/5/2024 at 6:28 AM, kosmos said:
Thanks alot @fabiosun!! Working great now 🙂 Can I buy you a beer? 🙂
Expand
Happy for you!
We do not do for beer here but if you like you can do a donation to the forum , it will help our admins to maintain it 🙂
It is not necessary because this forum is completely free (but if you like.. 🙂 🙂 )
  On 11/4/2024 at 8:50 PM, etorix said:
@kosmos Here are two patched DSDT you may try. The first one follows strictly the method in the first post; 'patched2' then further removes conditional statements on G002 and G001 inside declarations.
@Lorys89, please have a look into this.
patched.zip 60.85 kB Â· 0 downloads
Expand
@etorixhave you learned to do this by hand or have you programmed a tool to do it?
I did it by hand. To simplify, I begin by temporarily commenting out the Operation CPVS declaration, so that all further references to its objects show up as errors and then track them one by one: Find one, jump to the corresponding object in the tree in MaciASL left panel, go to the next object to find the closing bracket, delete it, go back to the opening section and complete the deletion, check, rinse and repeat.
It's somewhat tedious, and not made easier by the many warnings produced when recompiling the base DSDT. (AMD ACPI tables are an awful mess compared with those from Intel systems.)
The new inner conditional statements are worse, as they can be quite long, which makes it difficult to find the closing bracket. But it's maybe not necessary to remove these.
Anyway, if the patches by @corpghost keep working these are a much, much, better way to go forward.
  On 11/5/2024 at 9:20 AM, fabiosun said:
Happy for you!
Expand
Ok cool 🙂 Donated.
