Dell Latitude 7210 2 in 1
Lorys89
58 minutes ago, kiki59665 said:
Finally, how to extract the BIOS version V1.33 and modify it using RU.efi? I have tried many software but was unable to extract it. Can Lorys assist me in modifying the BIOS?
Disabled CFG Lock, set DVMT pre-allocated to 64MB (it seems to be the default 64MB) and set DVMT total to MAX.
Many Thanks!
BIOS V1.33 website download https://dl.dell.com/FOLDER11977216M/1/Latitude_7210_2in1_1.33.0.exe
Hi @Lorys89 , I am trying your EFI 7210 ( https://mega.nz/file/FRVlUTzJ#fTYUuWl7dEupIOPu66PjoWaY4BiXyUsbXh8ItbPDQEU)
On Dell 2 in 1 7200 I7 8665U OC 1.01 Sonoma . All works, only sleep problem : wake up screen will change color ( kind like monochrome and all vertical color ). But The extended monitor works fine, only laptop screen has a problem. Any suggestion how to fix it ? btw on Sequoia have same behaviour plus no WIFI . Thank you
Edited by TRYIT
From bios set to disable this :
Sign Of Life : Early Logo Display / Early keyboard backlight
Hi Lorys,
Recently I've been experiencing an issue with my Mac where it runs normally for a while, but after few time the CPU starts to throttles down and programs run very slowly, as shown in the pic. I've tried various methods, but the issue still remains.
I suspect it might be related to SSDT. Would it be necessary to customize the SSDT, or are there other possible solutions?
Have you faced this issue before?
10 ore fa, kiki59665 ha scritto:
Cfg Unlocked and CPUFriend.kext should be effect, but occasionally there is still a phenomenon of CPU downclocking
Have you checked if you have this problem on windows as well?
Hi Lorys,
I have a same problem !
You mentioned that this computer has a slower CPU power issue when plugged in. Could you share your experience? I encountered a similar problem.
I have a Dell Latitude 7210 running macOS Ventura 13.5.1 and am facing a GPU power throttling issue. In high power mode at 4.3GHz, the CPU temperature rises to 70-80°C but can only sustain for a few seconds before throttling down to 0.4GHz. It takes a long time for the CPU temperature to drop to around 50°C before the power returns, and this cycle repeats.
I tried several adjustments, including setting the fan to its maximum speed of 4800 RPM, disabling Intel SpeedStep, Intel TurboBoost, and Hyper-Threading. These efforts slightly lowered the CPU temperature, but it still throttles down to 0.4GHz. Finally, by enabling macOS's low-power mode and capping the CPU frequency to 2.4GHz, I was able to keep the computer stable in unplugged mode. However, once plugged in, the CPU again briefly runs at 2.4GHz before dropping to 0.4GHz. How can I resolve this issue?
I currently believe that the computer's thermal design is suboptimal and suspect that the CPU temperature limit is set too low, causing the frequent throttling. I found that VoltageShift can not only adjust voltage and TDP but may also modify MSR to adjust the temperature limit. However, there is little detailed guidance on this online. Have you tried this approach?
I attempted to use CPUFriend to generate a custom driver to manage CPUFriendDataProvider along with CPUFriend.kext. After adding the kext files and loading config.plist using OpenCore Configurator, I encountered issues where the system would hang during the boot process and result in kernel panic after rebooting.
  • 2 months later...
On 10/16/2024 at 1:12 PM, hank said:
Hi Lorys,
Not SURE this help??
https://youtu.be/YfFWFjKdr5I?t=437
  • 8 months later...
On 10/1/2024 at 1:26 PM, kiki59665 said:
Hi Lorys,
On 10/16/2024 at 7:12 AM, hank said:
Hi Lorys,
Subject: Possible Solution for CPU Throttling to 400MHz on Dell Latitude
Hello,
I am writing this because I saw your post from October 2024 describing a CPU power management issue, and I believe I had the exact same problem with my Dell Latitude 7210 2-in-1 (i5-10310U). I have finally found a solution, and I wanted to share it in the hope that it might help you too.
The Problem I Had:
My CPU would immediately drop to 0.4 GHz (400 MHz) the moment macOS started to boot. The system would become almost completely unresponsive. If I waited long enough for the CPU "request" to drop, the frequency would slowly recover, but as soon as any load was applied, it would throttle down again. No amount of SSDT patching or config.plist changes could fix this core issue.
The Solution:
After extensive testing, I discovered the cause was related to the battery and its management system. By simply physically disconnecting the internal battery, all my power management problems were instantly solved.
After disconnecting the battery and running only on AC power:
 * The CPU no longer drops to 400 MHz at boot.
 * Intel Turbo Boost now works correctly, reaching its full potential.
 * The system is stable and performs as expected, even though it runs a bit warmer now (around 60°C+ under load), which is normal for proper performance.
How I Found This:
I ran Intel Power Gadget and the system Console log simultaneously to capture the exact moment the failure occurred. I saw a "Plochfehler" (which I believe might be related to IOPlatformPlugin or power plane errors). This led me to research causes outside of the typical Hackintosh configuration, such as faulty power adapters and battery management issues. Testing without the battery confirmed the source of the problem.
How You Can Test This:
If you still have this issue, I highly recommend you try this as a diagnostic step:
 * Power off your device completely.
 * Unplug the AC adapter.
 * Carefully open the bottom case of your laptop.
 * Disconnect the battery connector from the motherboard.
 * Close the case (or leave it open for testing), plug in the AC adapter, and boot up.
If your system suddenly works perfectly, then you know the issue lies with the battery hardware or how macOS is interacting with its power management controller. This might mean the battery needs replacing or that a more specific ACPI patch is required to handle battery status correctly, but at least you will have identified the root cause.
I truly hope this helps you finally enjoy your device. It was a very frustrating problem, and I wanted to make sure nobody else had to give up on it.
Best of luck!
Edited by Squall
Sono incapace
  • 4 weeks later...
