38Nic Posted July 25, 2023 Author Share Posted July 25, 2023 Ok, proviamo, secure boot già disable, cambiata porta usb e reset nvram prima di avviare Link to comment Share on other sites More sharing options...
38Nic Posted July 25, 2023 Author Share Posted July 25, 2023 Ok, riprovato come descritto parte installazione su hd esterno, di riavvia ed arrivo alla Gui allegata ed una volta selezionato Mac OS Installer entra in recovery Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted July 25, 2023 Support Team Share Posted July 25, 2023 Securebootmodel l hai disabilitato nel plist? Non intendevo nel bios Link to comment Share on other sites More sharing options...
38Nic Posted July 25, 2023 Author Share Posted July 25, 2023 Ok era su default cambiato in Disabled, provo a rifare la procedura Ti aggiorno. Grazie Link to comment Share on other sites More sharing options...
38Nic Posted July 25, 2023 Author Share Posted July 25, 2023 E come va formattato il disco dove installo Monterey? Mac OS esteso o APFS? Grazie Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted July 25, 2023 Support Team Share Posted July 25, 2023 APFS Link to comment Share on other sites More sharing options...
38Nic Posted July 25, 2023 Author Share Posted July 25, 2023 Ok, provato come descritto e rimane bloccato qui, é così da 20 minuti Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted July 26, 2023 Support Team Share Posted July 26, 2023 Altro passo in avanti , disabilitare il SBModel ha aiutato visto che nn e’ andato in Rec. Puoi provare a impostare in Kernel -> Quirks -> SetApfsTrimTimeout = 0 invece di -1 Se non va neanche cosi presumo non digerisce il disco … non e’ un HDD immagino ? Se nn ricordo male hai il disco 0 ( Ventura ) abbastanza capiente , proverei a creare una partizione e Installare li Mrey 🤷♂️ Link to comment Share on other sites More sharing options...
38Nic Posted July 26, 2023 Author Share Posted July 26, 2023 Ok, nel frattempo sono riuscito a far funzionare la scheda audio Motu firewire con Ventura, adesso funzionano sia i midi standalone e con Logic Pro sia l'audio... Curiosità': visto che per installare il kext ho dovuto disabilitare SIP, attualmente "csrutil status disabile" è opportuno che lo lasci cosi' o devo nuovamente modificarlo? Comprometterebbe poi di nuovo il funzionamento dell'audio? Grazie Nic Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted July 26, 2023 Support Team Share Posted July 26, 2023 😂 tutto il casino con Mrey x niente meglio cosi' pero' 👍 , evidentemente non avevi seguito bene tominc hai da provare comunque probabilmente riattivando sip ti blocca il kext quindi niente banda 🎸 in caso la disattivi nuovamente 🤷♂️ Link to comment Share on other sites More sharing options...
38Nic Posted July 22, 2025 Author Share Posted July 22, 2025 Buongiorno, per il pc in firma, è ancora valida e supportata la scheda thunderbolt Gigabyte titan ridge v2 oppure c'e' qualcosa di meglio? Grazie Nic Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Buongiorno, grazie al vostro aiuto per il pc in firma che utilizzo sono riuscito ad aggiornare a Sequoia. Il mio amico ha lo stesso identico pc, e anche li con la stessa EFI abbiamo installato Sequoia. Il problema ora è la scheda audio Motu con uscita firewire, funzionava in Sonoma, da quel che ho letto in rete funziona anche con Sequoia ma non con Tahoe. Dove posso reperire il kext AppleFWAudio.kext? E altra cosa, non riesco a disabilitare il Sip in Sequoia, ho provato agendo da ToggleSIP alla GUI di Opencore ma csrutil status mi da sempre enable. Attendo cortesemente istruzioni. Grazie Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Sono riuscito a trovare il kext AppleFWAudio.kext ma nonostante i diversi tentativi non riesco a disabilitare completamente SIP Mi date una mano cortesemente? Grazie Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 7, 2025 Supervisor Share Posted November 7, 2025 che valore hai di sip nel config.plist? Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Come l'altra volta mi vengono fuori questi valori, non ricordo come avevo risolto Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 7, 2025 Supervisor Share Posted November 7, 2025 ciao @38Nic, quelli della foto non li ho chiesti in quanto scrivevi che non riesci a disattivarlo mi servirebbe sapere il valore che hai nel config.plist nella sezione Nvram etc 😉 Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Ok, scusami, più tardi torno a casa e ti aggiorno, grazie per l'attenzione Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 7, 2025 Supervisor Share Posted November 7, 2025 non c'e' bisogno di scusarti @38Nic Comunqueverifica il valore e se hai tutti 0 metti al posto dei primi due il numero 67 poi al boot menu resetti nvram e vedi se te la disattiva Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 7, 2025 Supervisor Share Posted November 7, 2025 con 00000000 con 67000000 sembre ricordarsi dopo qualsiasi modifica di fare reset Nvram a livello di boot menu di opencore Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Io mi ricordo che avevo tutti 0 e di aver messo 03080000 nel config.plist sezione Nvram Ma serve anche inserire csr-active-config nella sezione Delete? Grazie Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 7, 2025 Supervisor Share Posted November 7, 2025 io non lo uso nel delete, se hai messo 0308 etc e' quella che disabilita parzialmente se metti 67 etc e poi resetti nvram ti verrà come ti ho fatto vedere sopra non devi cliccare su disable o enable sip nel bootmenu se li hai. Non serve Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 ok, grazie, dopo provo Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Ok, sembra a posto..ora il problema è il kext AppleFwAudio.kext, farlo digerire al Mac, ho provato con Opencore ma quando installo i drivers della Motu la scheda non viene vista…azz non ricordo come era stato fatto con Ventura Ok, ora è cosi, sembra a posto Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 7, 2025 Support Team Share Posted November 7, 2025 Potrebbero funzionare questi ? 🤔 https://motu.com/en-us/download/product/273/#2717 Link to comment Share on other sites More sharing options...
38Nic Posted November 7, 2025 Author Share Posted November 7, 2025 Ho provato, niente, non viene vista... Puo' essere il problema del kext, va iniettato diversamente o manualmente? Io ho utilizzato semplicemente Opencore Link to comment Share on other sites More sharing options...
