[HELP] Build Ryzen 9 7900X - ASUS ROG X670E Hero
Coral
@Fabiosun My Windows is 11 Enterprise,it works fine. In my view, in the Opencore install guide, we should create ourselves USBMap.kext for the system. In CaseSJ's ASUS X670E Gene, he creates himself's USBMap.kext, Do you think we need to creat it. and also I have tried different USB port for the case front USB port to the motherboard's backplate USB port, it seems the second reboot install from 29min-23min, then reboot again and again.
Can you help me to create a ASUS X670E Hero‘s USBMap.kext for the Hackintosh to install? Thanks for your help.
You said to try usb port to see if there was problems drone there
i know usb map it is good because it works for different users on asus x670e hero 😉
as I said your problem is weird
i would try to install with only gpu on first slot and also with only wd nvme disk on first gpu slot
or to try an image of a fresh installed os if you have the chance to grab one
@Coral post it because it is changed and there are different version or check in it if you have xhc9
it is the USB port of my GPU
if so try to delete it ..i donot think this is your problem..but it is worth to try
Today I update the newest BIOS beta 1516, I used the old EFI which unsuccessful in BIOS 1510. I have successfully installed macOS Ventura 13.5 on my Koxia KXG6 NVMe SSD. Then I changed it with WD SN850X 2T, it also successfully.
So far so good. Thanks all for help.
Edited by Coral
Today I update MacOS 14.0 Sonoma, after successful update,I find the WiFi card Fenvi T919 doesn't work, also the local internet card intel i225/i226 doesn't work. How can I do to adjust it. thanks everybody for your help!
