[HELP] Build Ryzen 9 7900X - ASUS ROG X670E Hero
Coral
HI, @FaBIOSUN
I used your EFI and CaseSJ's together, but cann't finished the installation. stuck on "X86PlatformPlugin::GetCPUstates-__."
Here is my Desktop info
motherboard: ASUS X670E Hero
CPU: AMD 7900X
DDR5 G.Skill 6000 DDR5 32G*2
GPU: AMD RX6600XT
NVMe: Hynix P44 Pro 2T( Windows 11), 1T for Adobe; WD SN810 1T (*2) for Mac
WiFi: 94360CS2 using adapter in PCI-E *1 slot.
Hard Disk 3.5in WD Gold 4T, WD 12T*2 for storage.
Case: Lianli Lancool II
The Opencore using Debug edition 0.9.3
EFI.rar
I have changed the EFI, delete Appleinteli210Ethernet.kext, add AppleIGC.kext 1.3, I have successfuly process to patrition the disk, then install and reboot show "MacOS Installer", but after choose MacOS installer and then the system start restart and again and again, cann't move forward more?
Here is my EFI and snapshot of it. CAN you help me. Thanks!Image_20230710221156.thumb.jpg.960cf38a1a885247ca8fb3fdbfc765f1.jpg
@TReXintos,TReXintosh The EFI can successfuly process to the step of Disk Unity partrition the Disk and then install on selected disk, it show about 27min to install, after some time it restart, show the snapshot on upper picture, after selected the MacOS Installer restart the system and the first time it show it may need 29 min, but some times go, it restarted the same picture, I cann't see any further forward. then the system restart many times. I don't the reason for it.
@Coralplease use this one:
load bios optimised settings
then change only fast boot (off is better)
and I do not use also Asus logo (but it is not mandatory)
leave for now all other settings by default
check also how do you format your nvme disk:
@TReXintosh 🙂 I have tried your EFI using my Own SMBIOS SN. There are some process more than before. but after selected MacOS installer ,the first time it reboot to install show about 29 min, after process to 22min, the system reboot, then repeat.
MY BIOS is uptodate 1415. and My MMIO whitelist 4 is different with you. and the Ryzen patch I used CaseSJ's patch it has 26 patches. your kernal patches are 18. Here are the Debug report and my EFI.rar and some snapshots.
EFI202307111644.zip
You're messing up 🙈
In 8 hours I will be at work and if you want I'll help you.
Bios will have to be checked if it is set well
And if you use wifi ext you will have to disable from bios wifi and bt internal intel.
See you later
8 hours ago, Coral said:
I have change the Kernal Patch with the AMD-Vanilla patch and change the CPU core to 0C, the same problem.
Any idea for this? Thanks!
there is no need to use all generic AMD Vanilla Patches
The ones posted in my EFI are enough for you
All steps I see in your screenshot are correct
I have some doubt of your NVME booting disk (if you are using Kioxia one)
@Lorys89I have (as you know) two WIFi card on and it is possible to install from scratch without disabling stuff
problem could be in other part of user system
There are two NVMe SSD not shown on the Image, Both are WD SN810 (SN850 OEM edition) 1T.
P44 Pro 2T for Windows 11, Koxia 1T for Adobe, Two intel U2 NVMe SSD 1.2T for File and Photos, and two SN810 1T for MacOS Ventura and MacOS data, another three hard disk 4T and two 12T for storage.
Archive.zip
overwrite your with this config.plist
and copy the kext in kext folder
this follows @Lorys89 advice
i did also minor adjustment in Nvram section and platform info
Backup yours things before overwriting them
@Extreme™ I have tried your Config.plist and add NVMeFix.kext 1.1.1, The result is I cann't process to the Disk Unitity and MacOS installer. Then I remove my Hackintosh WiFi card BCM943602CS, and using my own's EFI, the result is after selected MacOS installer, the system will be restart again and again.
Here is my BCM943602CS card image and my log.txt.
Thanks for all help. Now I don't have any new idea about it.
opencore-2023-07-13-164142.zip
@Coral
00:819 00:009 OCCPU: CPUFrequencyFromTSC  4699998224Hz  4699MHz
00:827 00:007 OCCPU: CPUFrequency  4699998224Hz  4699MHz
00:837 00:010 OCCPU: FSBFrequency   102173874Hz   102MHz
are you overclocking your system before to have OSX installed?
@Fabiosun,Yes I disable DOCP II(Load the optimise BIOS,disable Fastboot and CSM,also Disable IGPU,the onboartd WiFi and BT is auto,but I didn't add the kext for them), and tried again. no further forward. and then I add NVMefix.kext, and setafpstrimout =0, the results is even worse.
Edited by Coral
@Coral
for me all versions..but the try is for a (i hope) corrupted bios for any reason
i use 1415 but also previous are good
in my case i have to use bios version that supports high density dimm (i have 48Gb x 2)
i would do in this way:
  1. flash 1415 using flashback button
  2. when done reset cmos (with back button a couple of times)
  3. load optimised settings (then csm off 4g on fast boot off)
  4. download again your OSX installer
and then try
macOS Installer icon could stay there for about 2/3 times (after initial reboot) if more it is not working
EDIT
i would use my EFI with only cores count patches modified for your cores number and without my SSDT for the GPU
Edited by fabiosun
@fabiosun I have flashback to BIOS 1410,and clear CMOS, then log in BIOS load optimised setting, then disabled CSM, fast boot, and abled 4G on。
I download the newest Ventura 10.14.1.
The results is the same. I'm completely lost now.
11 hours ago, Coral said:
BIOS the 4G on is gray,I
It is enabled
I have only a try to do
detach all your hard drive s and use only WD 850 to instal
or use a different media to create an usb installer
no other ideas
it is very weird you cant finish installation steps
In my system I have zero problems and your system is pretty similar
ah, windows or other system can be installed well?
