Build Ryzen 9 7/9950X - ASUS ROG X670E Hero
On 11/11/2024 at 8:23 PM, fabiosun said:
All is good with the same @CorpNewt ACPI patches
Hi @fabiosun, I couldn't find these ACPI patches. Can you please share these ACPI patches with us?
I updated my bios to 2506 and my mac is not booting and waiting for the apple logo.
Thanks for help.
Thanks for help.
12 hours ago, Xsario said:
ok, did you change any bios settings on 2506 bios? When I use this bios macos not booting I saw only freeze apple logo.
And did you check to my shared EFI ?
Thanks,.
I see now your EFI
something wrong but i think not related to your hang
you have sip like OCLP app board needs (03080....)
You have Amfipass.kext
also i see a device properties for Aquantia ethernet but no patches for it and no quirk enabled
try to insert -v as bootarg and see where it hangs
ACPI patches seem fime to me, and i have no checked well if you are using Sequoia updated  AMD Kernel patches
  • 3 weeks later...
Hi @fabiosun
Are you using macos with ASUS x670E hero motherboard?
If so, could you please share the version of macos you are using, the motherboard BIOS version and your EFI file?
I want to check the bios build with my own EFI.
Thanks.
19 hours ago, Xsario said:
Hi @fabiosun
Thanks.
Usually i use always latest bios
i have installed Sequoia 15.2
i use a pretty similar EFI you can find in this thread (now it is my second pc at home and i have filled with 64gb DDR5 5200 Mhz and a 9700x CPU
Hi @Xsario
Your EFI it is good if it works in Sonoma also with latest Sequoia
I see something not good because you use AMFIPass kext and also a disabled sip value i use for my broadcom wifi (i changed internal EFi with a Broadcom one compatible till ventura out the box and compatible from sonoma and greater using OCLP)
If you are on intel wifi, maybe you have to adjust your used kexts to newer one
  • 4 months later...
