Build Ryzen 9 7/9950X - ASUS ROG X670E Hero
No change for me in Beta 4. It is still totally unusable because of the graphics glitches, e.g totally red screen in web browser windows, the same for mail messages and often the whole screen becomes unreadable or lags when you click anything..
Have you upgraded to AMD beta kernel patches?
could you post your config.plist?
8 hours ago, fabiosun said:
@Ploddlestry to adapt this config.plist to yours
if you use 2124 BIOS for ASUS you could use it as is (NO DSDT but some ACPI patches added)
I use also a different kext for our ethernet card (check also bootarg)
Thank you my genius friend. I now have it working as it should.
The kext you use for the ethernet card (AppleIGC.kext) does not work for me. If I enable that kext and disable AppleIntelI210Ethernet.kext my system just hangs at a black screen. If I disable both of those kexts the same thing happens, I just get a black screen. Enabling AppleIntelI210Ethernet.kext (with the e1000=0 boot arg) and it works again, but ethernet speed is only 10% of what it should be - but that is better than nothing.
The AppleIGC.kext I have is V1.5 dated 14 June 2024.
I will experiment with a few things over the weekend.
About Ethernet and low speed
set hardware speed in Ethernetproperties manually
then set speed to 2500
it is a known problem
For the other kext solution
use latest appleIGB you find in macos86 GitHub if you want to try  Ethernet with this kext
Added in OP my latest EFI for macOS Ventura/Sonoma/Sequoia
I use a FEnvi WIFI with OCLP patches, so you have to check kext and block i use if you use intel WIFI
I am using latest 2124 ASUS Hero firmware patched via ACPI patches (Thanks @CorpGhost for the ACPI patches)
  • fabiosun changed the title to Build Ryzen 9 7/9950X - ASUS ROG X670E Hero
2 dimm @6400
below the best results is my system with 4 dimm installed and stock settings (it is difficult to push dimm to higher frequency than 3600, i can push to 4200, but if somethings fails in overclocking test system needs long time to boot well again
On 9/15/2024 at 5:16 PM, fabiosun said:
2 dimm @6400
Awesome single core results!!!
pushing ram @6400 (two sticks) it is much better also multicore benchmark in Geekbench and CinebenchR24
with Cinebench R23 no improvemnt and always a benchmark about 45000
Curve shaper seems to be a powerfull tool to optmize performance and temps/Watt (for 9950x and also for previous CPU Gen)
