Drupi Posted September 5, 2018 Share Posted September 5, 2018 Salve mi e venuta la nostalgia di el capitan, ho cosi fatto un installazione pulita su un vecchio SSD da 120gb, tutto funziona ok ma le prese USB3 non funzionano, e non riesco a trovare la kexts giusta, qualcuno potrebbe aiutarmi? grazie Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 5, 2018 Administrators Share Posted September 5, 2018 ti manca la patch per port limit... Link to comment Share on other sites More sharing options...
Drupi Posted September 5, 2018 Author Share Posted September 5, 2018 quindi? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 5, 2018 Administrators Share Posted September 5, 2018 mettila sul config Link to comment Share on other sites More sharing options...
Drupi Posted September 5, 2018 Author Share Posted September 5, 2018 ti ringrazio sentitamente ma il problema e, dove la trovo la patch per port limit...? emoticon-occhi_51 questo non ho capito, perdona la mia scarsa conoscenza tecnica nonostante la mia veneranda età emoticon_vergogna Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 5, 2018 Administrators Share Posted September 5, 2018 [code]com.apple.driver.usb.AppleUSBXHCIPCI 83BD8CFE FFFF10 83BD8CFE FFFF1B /code] Link to comment Share on other sites More sharing options...
Drupi Posted September 5, 2018 Author Share Posted September 5, 2018 ok grazie Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 5, 2018 Administrators Share Posted September 5, 2018 la devi mettere in kext to patch Link to comment Share on other sites More sharing options...
Drupi Posted September 5, 2018 Author Share Posted September 5, 2018 emoticon_thanks Link to comment Share on other sites More sharing options...
