kernel26 Posted November 5, 2022 Share Posted November 5, 2022 sera gente, qualcuno con big sure o monte rey, mi puo' gentilmente passare il driver ntfs? dovrebbe trovarsi dentro la dir /sbin o dentro /usr/sbin newfs_ntfs o qualcosa di simile. su ventura non c'è. forse neanche in monterey e forse forse neanche su big sure... Link to comment Share on other sites More sharing options...
T19 Posted November 8, 2022 Share Posted November 8, 2022 (edited) Prova il software tuxera ntfs Legge e scrive perfettamente ntfs. Edited November 8, 2022 by T19 Link to comment Share on other sites More sharing options...
kernel26 Posted November 12, 2022 Author Share Posted November 12, 2022 volevo qualcosa di gratis. ricordo che prima ci scrivevo editando fstab Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 12, 2022 Supervisor Share Posted November 12, 2022 24 minutes ago, kernel26 said: volevo qualcosa di gratis. ricordo che prima ci scrivevo editando fstab e si ci sono un paio di guide anche da noi ma forse con i nuovi OS non vanno piu'? io lo usavo per leggere solo un portatile della maxtor ma c'era ancora Catalina o meno Link to comment Share on other sites More sharing options...
Moderators tomnic Posted November 12, 2022 Moderators Share Posted November 12, 2022 33 minutes ago, kernel26 said: volevo qualcosa di gratis. ricordo che prima ci scrivevo editando fstab Usavo questo, che faceva tutto lui con fstab: https://mounty.app Ma se mai passerai a (s)Ventura: Why Mounty will not function with macOS 13 Ventura anymore Apple has changed the entire mount process from the previous kernel based architecture toward one that runs in user space. The ability to mount NTFS file systems in read/write mode was never a supported end-user function, and was only implemented in NTFS kext to support the BootCamp install process. This is now obsolete in Ventura and deactivated in the UserFS NTFS plugin. And sadly Mounty will not work anymore. Link to comment Share on other sites More sharing options...
Extreme™ Posted November 12, 2022 Share Posted November 12, 2022 (edited) Anni fa io acquistai sia Tuxera che Paragon NTFS. Attualmente con Ventura sto usando Tuxera e va bene. Edited November 12, 2022 by Extreme™ Link to comment Share on other sites More sharing options...
damiandrake Posted November 12, 2022 Share Posted November 12, 2022 Il 5/11/2022 at 18:14, kernel26 ha scritto: sera gente, qualcuno con big sure o monte rey, mi puo' gentilmente passare il driver ntfs? dovrebbe trovarsi dentro la dir /sbin o dentro /usr/sbin newfs_ntfs o qualcosa di simile. su ventura non c'è. forse neanche in monterey e forse forse neanche su big sure... Vai di Paragon NTFS, 20€ licenza a vita per un PC (puoi disinstallarlo da uno e installarlo in un altro quante volte vuoi), mai dato problemi Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted November 12, 2022 Support Team Share Posted November 12, 2022 54 minuti fa, Extreme™ ha scritto: Anni fa io acquistai sia Tuxera che Paragon NTFS. Attualmente con Ventura sto usando Tuxera e va bene. Io li ho entrambi, e preferisco tuxera. Li comprai anni fa per mbp e imac originali 1 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted November 12, 2022 Moderators Share Posted November 12, 2022 6 ore fa, kernel26 ha scritto: volevo qualcosa di gratis. ricordo che prima ci scrivevo editando fstab Giusto, 😁 quindi chiedo a tutti cortesemente di rispettare il regolamento Link to comment Share on other sites More sharing options...
Extreme™ Posted November 13, 2022 Share Posted November 13, 2022 15 hours ago, Lorys89 said: Io li ho entrambi, e preferisco tuxera. Li comprai anni fa per mbp e imac originali Anch’io preferisco Tuxera. 👍 1 Link to comment Share on other sites More sharing options...
