AppleIGB and IntelMausi integration
mbarbierato
It works perfectly!
thank you @mbarbierato
Log:
Last login: Fri Nov  4 07:55:36 on console
fabio@Mac-Pro ~ % sudo dmesg | grep -i igb
Password:
[  269.069832]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  269.069852]: bpf0 closed and detached from en1 fcount 0 dcount 0bpf0 attached to en1igb: output: Dropping packet on disabled device
[  272.336153]: 2 duplicate reports for Sandbox: tipsd(962) deny(1) mach-lookup com.apple.metadata.mdsSandbox: analyticsd(227) deny(1) file-issue-extension target:/private/var/db/analyticsd/Library/Preferences/analyticsd.plist class:com.apple.cfprefsd.read-writebpf0 attached to en1igb: output: Dropping packet on disabled device
[  273.097533]: bpf0 closed and detached from en1 fcount 0 dcount 01 duplicate report for Sandbox: analyticsd(227) deny(1) file-issue-extension target:/private/var/db/analyticsd/Library/Preferences/analyticsd.plist class:com.apple.cfprefsd.read-writeSandbox: transparencyd(579) deny(1) user-preference-read com.apple.registrationSandbox: transparencyd(579) deny(1) file-write-create /Users/fabio/Library/HTTPStorages/com.apple.transparencydSandbox: transparencyd(579) deny(1) mach-lookup com.apple.metadata.mdsSandbox: transparencyd(579) deny(1) file-read-data /private/var/db/nsurlstoraged/dafsaData.binbpf0 attached to en1igb: output: Dropping packet on disabled device
[  277.418602]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  277.418617]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  277.486497]: igb: output: Dropping packet on disabled device
[  277.566973]: igb: output: Dropping packet on disabled device
[  277.732621]: igb: output: Dropping packet on disabled device
[  278.058030]: igb: output: Dropping packet on disabled device
[  284.668763]: macl_get_vnode: failed to resolve vnode: 2bpf0 attached to en1igb: output: Dropping packet on disabled device
[  285.721617]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  285.721634]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  285.788147]: igb: output: Dropping packet on disabled device
[  285.871698]: igb: output: Dropping packet on disabled device
[  286.037531]: igb: output: Dropping packet on disabled device
[  286.362961]: igb: output: Dropping packet on disabled device
[  294.227840]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  294.228070]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  294.228085]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  294.298850]: igb: output: Dropping packet on disabled device
[  294.379542]: igb: output: Dropping packet on disabled device
[  294.544408]: igb: output: Dropping packet on disabled device
[  294.869680]: igb: output: Dropping packet on disabled device
[  298.811503]: Sandbox: akd(602) deny(1) file-write-create /Users/fabio/Library/HTTPStorages/com.apple.akdSandbox: akd(602) deny(1) mach-lookup com.apple.metadata.mdsbpf0 attached to en1igb: output: Dropping packet on disabled device
[  302.800747]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  302.800763]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  302.868586]: igb: output: Dropping packet on disabled device
[  302.952243]: igb: output: Dropping packet on disabled device
[  303.117855]: igb: output: Dropping packet on disabled device
[  303.440123]: igb: output: Dropping packet on disabled device
[  311.269815]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  311.270041]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  311.270055]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  311.335914]: igb: output: Dropping packet on disabled device
[  311.418984]: igb: output: Dropping packet on disabled device
[  311.581566]: igb: output: Dropping packet on disabled device
[  311.904241]: igb: output: Dropping packet on disabled device
[  318.206430]: Sandbox: mediaanalysisd(931) deny(1) file-read-data /Users/fabio/Pictures/Photos Library.photoslibrary/private/com.apple.mediaanalysisd/caches/vision/vnpersonsmodel.bin5 duplicate reports for Sandbox: mediaanalysisd(931) deny(1) file-read-data /Users/fabio/Pictures/Photos Library.photoslibrary/private/com.apple.mediaanalysisd/caches/vision/vnpersonsmodel.binSandbox: knowledgeconstructiond(995) deny(1) mach-lookup com.apple.coreduetd.knowledge.userbpf0 attached to en1igb: output: Dropping packet on disabled device
[  319.928543]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  319.928556]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  319.994626]: igb: output: Dropping packet on disabled device
[  320.077292]: igb: output: Dropping packet on disabled device
[  320.239938]: igb: output: Dropping packet on disabled device
[  320.565028]: igb: output: Dropping packet on disabled device
[  328.539629]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  328.539846]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  328.539860]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  328.604956]: igb: output: Dropping packet on disabled device
[  328.687833]: igb: output: Dropping packet on disabled device
[  328.850292]: igb: output: Dropping packet on disabled device
[  329.172943]: igb: output: Dropping packet on disabled device
[  336.559404]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  386.883851]: 1 duplicate report for Sandbox: contentlinkingd(743) deny(1) user-preference-read kCFPreferencesAnyApplicationSandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceigb: output: Dropping packet on disabled device
[  388.401796]: igb: output: Dropping packet on disabled device
[  396.562069]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  397.932892]: 9 duplicate reports for Sandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: trustd(543) deny(1) mach-lookup com.apple.usymptomsdbpf0 attached to en1igb: output: Dropping packet on disabled device
[  400.422399]: Sandbox: contentlinkingd(743) deny(1) user-preference-read kCFPreferencesAnyApplicationSandbox: TextEdit(1044) deny(1) file-write-data /Users/fabio/Downloads/Arrakis I210 Trx40.txtmacl_xlate_uuid_to_appid: failed to find appid for uuid 31A7979B-357D-403F-83F5-D536E829BCFEsuccessfully parsed 1/4 entries for file Arrakis I210 Trx40.txtSandbox apply: mdworker_shared[1047] <bytes>bpf0 attached to en1igb: output: Dropping packet on disabled device
[  400.820105]: bpf0 closed and detached from en1 fcount 0 dcount 0Sandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox apply: QuickLookUIService[1049] <bytes>Sandbox apply: com.apple.CloudDocs.MobileDocume[1050] <bytes>newUserClient: Invalid userClient Type request: 0igb: output: Dropping packet on disabled device
[  402.693222]: igb: output: Dropping packet on disabled device
[  404.997221]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  404.997410]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  404.997424]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  405.063997]: igb: output: Dropping packet on disabled device
[  405.146462]: igb: output: Dropping packet on disabled device
[  405.218261]: 3 duplicate reports for Sandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: revisiond(172) deny(1) mach-lookup com.apple.windowserver.activeSandbox: revisiond(172) deny(1) mach-lookup com.apple.cache_deleteSandbox: revisiond(172) deny(1) mach-lookup com.apple.windowserver.activeSandbox: revisiond(172) deny(1) mach-lookup com.apple.cache_deleteSandbox: revisiond(172) deny(1) mach-lookup com.apple.windowserver.activeSandbox: revisiond(172) deny(1) mach-lookup com.apple.cache_deleteigb: output: Dropping packet on disabled device
[  405.633094]: igb: output: Dropping packet on disabled device
[  407.901350]: Sandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistencebpf0 attached to en1igb: output: Dropping packet on disabled device
[  413.431785]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  413.431802]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  413.498060]: igb: output: Dropping packet on disabled device
[  413.580694]: igb: output: Dropping packet on disabled device
[  413.743346]: igb: output: Dropping packet on disabled device
[  413.908012]: 7 duplicate reports for Sandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: Family(867) deny(1) mach-lookup com.apple.AddressBook.ContactsAccountsServiceSandbox: Family(867) deny(1) mach-lookup com.apple.contactsd.persistenceigb: output: Dropping packet on disabled device
[  421.897856]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  421.898075]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  421.898090]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  421.962684]: igb: output: Dropping packet on disabled device
[  422.047074]: igb: output: Dropping packet on disabled device
[  422.209738]: igb: output: Dropping packet on disabled device
[  422.532390]: igb: output: Dropping packet on disabled device
[  423.175444]: bpf0 closed and detached from en1 fcount 6 dcount 0Waking up reference: 15Thread waiting on reference 15 woke upevaluation result: 15, allowed, cache,  1666721776Waking up reference: 16Thread waiting on reference 16 woke upevaluation result: 16, allowed, cache,  1666721777Waking up reference: 17Thread waiting on reference 17 woke upevaluation result: 17, allowed, cache,  1666721777Waking up reference: 18Thread waiting on reference 18 woke upevaluation result: 18, allowed, cache,  1666721777Waking up reference: 19Thread waiting on reference 19 woke upevaluation result: 19, allowed, cache,  1666721777Waking up reference: 20Thread waiting on reference 20 woke upevaluation result: 20, allowed, cache,  1666721777Waking up reference: 21Thread waiting on reference 21 woke upevaluation result: 21, allowed, cache,  1666721778Waking up reference: 22Thread waiting on reference 22 woke upevaluation result: 22, allowed, cache,  1666721778Waking up reference: 23Thread waiting on reference 23 woke upevaluation result: 23, allowed, cache,  1666721778bpf0 attached to en1igb: output: Dropping packet on disabled device
[  430.780434]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  430.780449]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  430.846719]: igb: output: Dropping packet on disabled device
[  430.929380]: igb: output: Dropping packet on disabled device
[  431.092038]: igb: output: Dropping packet on disabled device
[  431.414339]: igb: output: Dropping packet on disabled device
[  439.342484]: bpf0 attached to en1igb: output: Dropping packet on disabled device
[  439.342670]: bpf1 attached to en1igb: output: Dropping packet on disabled device
[  439.342683]: bpf1 closed and detached from en1 fcount 0 dcount 0igb: output: Dropping packet on disabled device
[  439.409026]: igb: output: Dropping packet on disabled device
[  439.491696]: igb: output: Dropping packet on disabled device
[  439.636619]: newUserClient: Invalid userClient Type request: 0igb: output: Dropping packet on disabled device
[  439.979681]: igb: output: Dropping packet on disabled device
fabio@Mac-Pro ~ %
3 ore fa, Arrakis ha scritto:
@Lorys89 @fabiosun
1-I plugged in the cable, turn off, start.
- Result: same
I have never disabled Lan ports in the bios even when they weren't supported since Big Sur 11.4.
2 - I tried the experiment (with the ethernet cable still connected):
- Disable Lan ports in bios, startup, shutdown.
    Result: same (logic)
- Activation of Lan ports in the bios, startup.
    Result: same
Can you try with this version ?
Thaks
AppleIGB-RELEASE.kext.zipAppleIGB-DEBUG.kext.zip
  • +1 2
On 11/3/2022 at 6:36 PM, mbarbierato said:
Hi all,
i tried to integrate some part of IntelMasui in AppleIGB for activate I210 and I211 intel lan in some platform.
 I need helping for test this kext in some hardware.
Thank you for help
AppleIGB-RELEASE.kext.zip 73.15 kB · 182 downloads AppleIGB-DEBUG.kext.zip 95.63 kB · 13 downloads
Much appreciated. Working well on ASUS X570-F with I211-AT.
  • Like 3
I upgraded to Ventura with this new kext from from Big sur. The upgrade worked after changing the the ventura patches plist. But now my AORUS pro X570 WIFI 1.0 keeps restarting after initial boot. Any settings I should change? I already disabled several kext to just boot normal but no luck. Any tips? thanks in advance
try to disable the kext to see if it is its problem (I do not think so because it is working also in Ventura beta 2)
you must update also Opencore and its drivers and kexts
I already upgraded to the latest drivers and kexts before the upgrade  0.8.6 is the version i'm using.
I can only boot to my second hdd in windows through opencore.
I will boot to recovery and restore to big sur from timeline.
So i can further investigate tommorow.
Edited by henkiewie
Strangely enough Recovery (13) won't boot also. Now I have to make a new USB disk to try to go from there.
And as you already assumed disabeling the driver did'nt work either.
@henkiewie
Opencore updated
Patches updated with a "new"leaf7 patch to add to the list
All max kernel updated for Ventura (in kernel patches section)
then it is mandatory for Monterey and Ventura to have this kext AppleMCEReporterDisabler.kext enabled
If you post your config (put it in your profile / signature) we can try to solve
This version works fine on ASUS formula viii crosshair with x570 i211-AT, I tried before donatengit/AppleIGB version but connection down after a few moments.
One day with no problems using this one.
Is the repository for this kext this mbarbierato/AppleIGB ?  Thank you so much @mbarbierato.
Edited by Meteoro
On 11/9/2022 at 8:46 AM, fabiosun said:
@henkiewie
Opencore updated
O
Thx for the offer. It took me some time to get back to Big Sur 11.7.1 and restore my timemachinebackup. I'm not ready to do another try on Ventura yet. The PC is my daily driver :-).
AppleIGB is working. Will put my my config.plist in my profile hope I don't need extra help though ;-)
No i don’t pull the code there are the problem in i210
  • Cross Finger 2
