[Discussion] AMDFriend, for (almost) all of your library patching needs
Nyaomi
  • 2 months later...
Hi guys,
I have problem with Photoshop 25, after installed Sonoma, PS 25 started, I checked only .jpg but all worked.
When i tried to edit tiff from Lightroom to PS crashed, so I exported .jpg but PS crashed when I tried to use liquify or right after saved photo.
So I downloaded amdfriend, doing all steps, but I'm not sure that I properly install amdfriend, because nothig has changed.
Could someone look at logs from terminal?
It should looking like this?
@fabiosuni had a lot of work so I left my osx and work from Windows. But i'm back to my hackintosh - downloaded from github, and:
1.
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
2.
brew install nodejs
3. xattr -c /Users/shotem/Downloads/AMDFriend/amdfriend
4. chmod +x/Users/shotem/Downloads/AMDFriend/amdfriend
5. sudo npm install -g /Users/shotem/Downloads/AMDFriend/amdfriend
And right now i've got error:
So i put amdfriend to /usr/local/bin
6. sudo npm install -g amdfriend
7. sudo amdfriend --in-place --sign --directories /Applications/Adobe\ Photoshop\ 2024/Adobe\ Photoshop\ 2024.app
And get the same error, and PS doesn't work 😞
Any idea?
Well, I had a comprehensive reading of the topic thanks to my twin Guru @fabiosun 🙂 .
My main question in mind at this stage is the following:
Does this patch work for 99% of the apps (I saw some Adobe Suite softwares, DaVinci and so on...). I guess it is useless for Parallels Desktop.
I use many of them, but not always on the latest build because of compatibility issues.
I have no intellectual problem "playing" with the AMD hack, but if each time there is an Adobe release, the patch needs to be tuned (I am honestly unable to do that on my own), It's going to be somehow a bit crazy.
You can't of course, predict Adobe developers behaviour, but as of today has it been pretty smooth or a bit tricky? 🙂
I already have an AMD setup, it can become my kindergarten for fun, but I need to rely on a pretty stable setup as well.
Intel is safe (Casey has a powerful one to be upgraded to Z70 Creator version).
I rely on your expertise my friends!
The patch is only useful if the apps use MKL Intel Libraries
Davinci doesnt need of it
Photoshop, Premiere pro and After Effects need it
this below is an example how it is difficult to apply it :
sudo /Users/fabio/Desktop/amdfriend --in-place --sign --directories /Applications/Adobe\ Photoshop\ 2024/Adobe\ Photoshop\ 2024.app
AMDFriend does all the job for us
and yes it is useless in Parallels Desktop (there is another problem there)
Il 26/10/2022 at 18:18, fabiosun ha scritto:
before to have the chance to patch any app you want you have to install well the script
Devs has prepared an executable file which could help you
https://github.com/NyaomiDEV/AMDFriend/releases/tag/v1.0.2
download it
then
from terminal
xattr -c /Users/fabio/Downloads/amdfriend
and then
chmod +x /Users/fabio/Downloads/amdfriend
then you can try to patch photoshop
sudo /Users/fabio/Downloads/amdfriend --in-place --sign --directories /Applications/Adobe\ Photoshop\ 2023/Adobe\ Photoshop\ 2023.app
Good evening, I'm trying to install "AMD friend", but it gives me this error, can you tell me what I should do?
@danydownload directly the binary fom developer:
then you can open a terminal window and type:
applying exact path for your system and apps
Where am I wrong? with Adobe it went well.
There's a non-escaped space in the application path.
Do not type paths! Use shell autocompletion (<TAB> key). Something like
/A<TAB>Au<TAB>A<TAB>A<TAB>
should give the correct syntax ( AutoCAD\ 2022 ).
Or wrap the path in quotes.
@danyi do not remember well but of I am not completely wrong you have to backup before those two files
apply the patch with amdfriend
then put back those backupped files again back
Edit
only those two file must be patched
AMDFriend in this case patches also others libs
you have to put back them
Edit
forgive me but...if I understood correctly the two files do not have to be patched, I simply have to put the two files aside, which do not have to be patched, and after having patched everything I put the two files back??
it's correct?
it's correct?
Edit
forgive me, I misunderstood, you said on the contrary that only these two files need to be patched.
except that I patched everything, what should I do to uninstall AutoCad and reinstall it again?
No sorry..
only those two needs to be patched, amdfriend find also some false positive you have to put them back
i do not remember which files you have to restore ( @tomnic could help here 🙂 )
Before patching backup all autocad folder and then replace some libs (sorry i cant be more precise)
6 minuti fa, fabiosun ha scritto:
No scusa..
solo quei due devono essere riparati, amico trova anche qualche falso positivo devi rimetterli a posto
non ricordo quali file devi ripristinare (@tomnicpotrebbe aiutare qui 🙂  )
Prima di applicare la patch, eseguire il backup di tutte le cartelle di AutoCAD e quindi sostituire alcune librerie (scusate, non posso essere più preciso)
ok don't worry, you are always a great help anyway 👍
@dany from an old brainstorming with tomnic 🙂
Routines found for /Users/tomnic/Desktop/org/libaccore.dylib:
<53 48 83 EC 20 8B 35 15 39 5C 00> at offset 6478068 (Hex: 62d8f4)
File /Users/tomnic/Desktop/org/libaccore.dylib was patched.
put back that lib and Autocad will start again
thank you, I have now uninstalled autoCad, tomorrow I will try as soon as I have reinstalled it.
If I succeed I'll be fine otherwise I'll do without it on this PC
