Lilu Plugins [Beta] Builder
WhateverGreen Changelog
v1.3.1
Fixed an issue that LSPCON driver fails to set the mode after the adapter power is off, i.e. sleep/wake up cycle.
Unified release archive names
Enforce complete IGPU modeset on Skylake and newer (overridable by igfxfcmsfbs bootarg or complete-modeset-framebuffers device property)
Disable VRAM testing on AMD GPUs on 10.14.4+ (based on vladie's patch)
Edited by Gengik84
AppleALC Changelog
v1.4.0
Added AMD Zen 2 controller patches by camielverdult
Added ALC274 layout-id 21 for Dell Inspiron 27-7777 AIO Series by Andres ZeroCross
Added ALC257 layout-id 18 for Lenovo Legion Y540 and Y7000-2019 by xiaoMGitHub
Added ALC289 layout-id 23 for Acer PT515-51 By Bugprogrammer and Rover
Added ALC285 layout 31 for Thinkpad X1E 8750H version by Flymin
Edited by Gengik84
v1.3.2
Added more GPUs for detection
Enable IGPU graphics kernel panic workaround on 10.14.4+ on SKL
Ha scritto dopo 1 minuto 49 secondi:
HibernationFixup Changelog
v1.2.8
Fixed memory leaks
Fixed EmuVariableUefiPresent detection (nvram.plist will be properly saved if EmuVariableUefiPresent == Yes in ioreg)
Improve auto-hibernate feature: modify next wake time only before regular sleep
Edited by Gengik84
v1.2.9
Improve auto-hibernate feature: if power nap is enabled, hibernation will start after next Maintenance/SleepService wake (standbyDelay value is respected)
Edited by Gengik84
  • 4 weeks later...
Lilu Changelog v1.3.9
Added QEMU/KVM vendor compatibility to device detection logic
AppleALC Changelog v1.4.3
Added support for No-hda-gfx HDEF property disabling IGPU digital audio
Edited by Gengik84
Beta WEG 1.3.4
#### v1.3.4
- Added support for disabled AppleGraphicsDevicePolicy in AMD drivers on 10.15.1
- Added basic support for `-radcfg` and `-radgl` on AMD Navi GPUs
Edit: rimosso allegato, i kext beta li troverete da ora in poi in download.
Edited by Gengik84
  • 4 weeks later...
v1.3.5
Dropped legacy boot arguments (-shikigva, -shikifps)
Fixed handling agdpmod GPU property (in IGPUs and in conjunction with boot-arg)
Added -wegtree boot argument to force device renaming
Fixed FairPlay DRM playback patches on 10.15
file disponibile nella sezione download kext beta
  • 10 months later...
