Gigabyte B550 Ryzen 9 5900x didn't work EFI Properly............
Karigor_Bari
1 hour ago, Karigor_Bari said:
sir all r input this kext ok. my EFI post
sir, I am saying you have this ethernet :
Realtek® 2.5GbE LAN
you can use only an ethernet kext for this
Maybe the right one is LucyRTL8125Ethernet.kext
and I mean you should disable the others
For WIFI/BT I think it is an Intel chip one and you can find also in this site the right combinations of kext you have to use
For this I have no experience at all (sorry)
maybe @antunedducan help you if he has some time to do it!
1 hour ago, fabiosun said:
@Karigor_Bari
if you want try this
check only if your ethernet works well as before
Sir I posted my used config.plist to see you.
I've used it. i have matched mine with the config.plist given by you.
The ones you gave false are True to my list.
Please check and confirm once sir....
config.plist.zip
This EFI r 100% install macOS Monterey 12.0.1 download Image files by Olarila.com
Sir can keep in your collection. I give it to you because you want to help me.
So if necessary, you can for the cooperation of others who have problems with the PC Configuration
Thank U sir
EFI 01.zip
Edited by Karigor_Bari
6 minutes ago, fabiosun said:
@Karigor_Bari
sorry maybe it is a misunderstood for different language
Here is all free and your EFI is not good 😛
you have too much ethernet kexts on there!
and you DOESN'T need of all them!
But if you are happy..I am happy also for you!
peace
Then I will use the config.plist given by you with confidence..
  • 2 years later...
6 hours ago, chand said:
Motherboard=B550 AC
Processor= AMD Ryzen 9 5900x 12 Core
GPU=nvidia geforce RTX 3060
Ram - 16 x 16 DDrR 4
sir dont suppot mac os
welcome @chand
your Nvidia GPU is not compatible with OSX
so it is not possible to have a good experience with any macOS
Sorry
