marzillo Posted October 25, 2021 Share Posted October 25, 2021 Buongiorno a tutti...causa aggiornamento bios non voluto il sistema ora non si avvia piu......avrei bisogno se possibile di un nuovo dsdt...a tal scopo allego il necessario....grazie mille CLOVER.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2021 Administrators Share Posted October 25, 2021 Ciao, rimuovi il dsdt e ssdt.aml, metti ssdt-basic2 che trovi in download sostituisci il config e aggiungi https://github.com/1Revenger1/ECEnabler/releases/download/1.0.2/ECEnabler-1.0.2-RELEASE.zip per la batteria config.plist.zip Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 Boos mito vivente....provo subito Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 Boos mito vivente....provo subito Grande come al solito Boss....il sistema riparte....è solo sparito l'audio...non so se devo cambiare codec...faccio alcune prove Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 Boss ti allego un file iMac di Marzillo (2).zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2021 Administrators Share Posted October 25, 2021 config.plist 2.zip Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 non funziona...provo alcuni codec 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2021 Administrators Share Posted October 25, 2021 In caso da provare con properties Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 aaah Link to comment Share on other sites More sharing options...
marzillo Posted October 25, 2021 Author Share Posted October 25, 2021 seguito la guida dell'ottimo Canaro.....funziona....Grazie Boss 1 Link to comment Share on other sites More sharing options...
