Hakintosh Lenovo ideacentre 510-15ICK
solaris82
CPU-Z
Binaries
CPU-Z version 1.96.0.x64
Processors
CPU Groups 1
CPU Group 0 6 CPUs, mask=0x3F
Number of sockets 1
Number of threads 6
APICs
Socket 0
     -- Core 0 (ID 0)
         -- Thread 0 0
     -- Core 1 (ID 2)
         -- Thread 1 2
     -- Core 2 (ID 4)
         -- Thread 2 4
     -- Core 3 (ID 6)
         -- Thread 3 6
     -- Core 4 (ID 😎
         -- Thread 4 8
     -- Core 5 (ID 10)
         -- Thread 5 10
Timers
     ACPI timer 3.580 MHz
     Perf timer 10.000 MHz
     Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
     Number of cores 6 (max 6)
     Number of threads 6 (max 6)
     Manufacturer GenuineIntel
     Name Intel Core i5 9400
     Codename Coffee Lake
     Specification Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz
     Package (platform ID) Socket 1151 LGA (0x1)
     CPUID 6.E.A
     Extended CPUID 6.9E
     Core Stepping U0
     Technology 14 nm
     TDP Limit 65.0 Watts
     Tjmax 100.0 °C
     Core Speed 3990.2 MHz
     Multiplier x Bus Speed 40.0 x 99.8 MHz
     Base frequency (cores) 99.8 MHz
     Base frequency (ext.) 99.8 MHz
     Stock frequency 2900 MHz
     Max frequency 4100 MHz
     Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
     Microcode Revision 0xD6
     L1 Data cache 6 x 32 KB (8-way, 64-byte line)
     L1 Instruction cache 6 x 32 KB (8-way, 64-byte line)
     L2 cache 6 x 256 KB (4-way, 64-byte line)
     L3 cache 9 MB (12-way, 64-byte line)
     Max CPUID level 00000016h
     Max CPUID ext. level 80000008h
     FID/VID Control yes
     Turbo Mode supported, enabled
     Max non-turbo ratio 29x
     Max turbo ratio 41x
     Max efficiency ratio 8x
     Speedshift Autonomous
     O/C bins none
     Ratio 1 core 41x
     Ratio 2 cores 40x
     Ratio 3 cores 40x
     Ratio 4 cores 40x
     Ratio 5 cores 39x
     Ratio 6 cores 39x
     IA Voltage Mode PCU adaptive
     IA Voltage Offset 0 mV
     GT Voltage Mode PCU adaptive
     GT Voltage Offset 0 mV
     LLC/Ring Voltage Mode PCU adaptive
     LLC/Ring Voltage Offset 0 mV
     Agent Voltage Mode PCU adaptive
     Agent Voltage Offset 0 mV
     TDP Level 65.0 W @ 29x
     Temperature 0 36 degC (96 degF) (Package)
     Temperature 1 35 degC (95 degF) (Core #0)
     Temperature 2 36 degC (96 degF) (Core #1)
     Temperature 3 34 degC (93 degF) (Core #2)
     Temperature 4 36 degC (96 degF) (Core #3)
     Temperature 5 35 degC (95 degF) (Core #4)
     Temperature 6 34 degC (93 degF) (Core #5)
     Voltage 0 1.24 Volts (VID)
     Voltage 1 +0.00 Volts (IA Offset)
     Voltage 2 +0.00 Volts (GT Offset)
     Voltage 3 +0.00 Volts (LLC/Ring Offset)
     Voltage 4 +0.00 Volts (System Agent Offset)
     Power 00 5.78 W (Package)
     Power 01 4.91 W (IA Cores)
     Power 02 0.08 W (GT)
     Power 03 0.78 W (Uncore)
     Power 04 1.43 W (DRAM)
     Clock Speed 0 3990.24 MHz (Core #0)
     Clock Speed 1 3890.48 MHz (Core #1)
     Clock Speed 2 3890.48 MHz (Core #2)
     Clock Speed 3 3890.48 MHz (Core #3)
     Clock Speed 4 3990.24 MHz (Core #4)
     Clock Speed 5 3990.24 MHz (Core #5)
     Core 0 max ratio 41.0 (effective 40.0)
     Core 1 max ratio 41.0 (effective 40.0)
     Core 2 max ratio 41.0 (effective 40.0)
     Core 3 max ratio 41.0 (effective 40.0)
     Core 4 max ratio 41.0 (effective 40.0)
     Core 5 max ratio 41.0 (effective 40.0)
Chipset
Northbridge Intel Coffee Lake rev. 07
Southbridge Intel IDA2CC rev. 00
Bus Specification PCI-Express 3.0 (8.0 GT/s)
Graphic Interface PCI-Express
Memory Type DDR4
Memory Size 32 GBytes
Channels Dual
Memory Frequency 1330.1 MHz (1:20)
CAS# latency (CL) 19.0
RAS# to CAS# delay (tRCD) 19
RAS# Precharge (tRP) 19
Cycle Time (tRAS) 43
Row Refresh Cycle Time (tRFC) 467
Command Rate (CR) 2T
Uncore Frequency 3691.0 MHz
Host Bridge 0x3EC2
Memory SPD
DIMM # 1
     SMBus address 0x51
     Memory type DDR4
     Module format UDIMM
     Module Manufacturer(ID) Crucial Technology (7F7F7F7F7F9B00000000000000)
     SDRAM Manufacturer (ID) Micron Technology (2C000000000000000000000000)
     Size 16384 MBytes
     Max bandwidth DDR4-3200 (1600 MHz)
     Part number CT16G4DFD832A.C16FJ
     Serial number E38CDDAE
     Manufacturing date Week 41/Year 20
     Nominal Voltage 1.20 Volts
     EPP no
     XMP no
     AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
     JEDEC #1 10.0-10-10-24-34 @ 727 MHz
     JEDEC #2 11.0-11-11-26-37 @ 800 MHz
     JEDEC #3 12.0-12-12-28-40 @ 872 MHz
     JEDEC #4 13.0-14-14-31-44 @ 945 MHz
     JEDEC #5 14.0-14-14-33-47 @ 1018 MHz
     JEDEC #6 15.0-15-15-35-50 @ 1090 MHz
     JEDEC #7 16.0-16-16-38-54 @ 1163 MHz
     JEDEC #8 17.0-17-17-40-57 @ 1236 MHz
     JEDEC #9 18.0-18-18-42-60 @ 1309 MHz
     JEDEC #10 19.0-19-19-45-64 @ 1381 MHz
     JEDEC #11 20.0-20-20-47-67 @ 1454 MHz
     JEDEC #12 21.0-21-21-49-70 @ 1527 MHz
     JEDEC #13 22.0-22-22-52-74 @ 1600 MHz
     JEDEC #14 23.0-22-22-52-74 @ 1600 MHz
     JEDEC #15 24.0-22-22-52-74 @ 1600 MHz
DIMM # 2
     SMBus address 0x53
     Memory type DDR4
     Module format UDIMM
     Size 16384 MBytes
     Serial number E38CDDAF
     EPP no
     XMP no
     AMP no
Monitoring
Mainboard Model 3714 (0x000000CF - 0x00002240)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6686
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xD4
LPCIO Revision ID 0x41
Hardware Monitors
Hardware monitor Nuvoton NCT6683
     Voltage 0 39.55 Volts [0xCE] (+12V)
     Voltage 1 16.55 Volts [0xCE] (+5V)
     Voltage 2 3.17 Volts [0xC6] (+3.3V)
     Voltage 3 0.96 Volts [0x3C] (3VSB)
     Voltage 4 0.70 Volts [0x2C] (VCCIN)
     Voltage 5 0.29 Volts [0x12] (PCH)
     Voltage 11 0.24 Volts [0xF] (VIN11)
     Voltage 13 0.54 Volts [0x22] (VIN13)
     Voltage 16 0.82 Volts [0x33] (VIN16)
     Voltage 17 0.80 Volts [0x32] (VIN17)
     Voltage 18 0.24 Volts [0xF] (VIN18)
     Temperature 0 36 degC (96 degF) [0x24] (CPU)
     Temperature 1 47 degC (116 degF) [0x2F] (PCH)
     Temperature 2 35 degC (95 degF) [0x23] (eSIO)
     Temperature 3 15 degC (59 degF) [0xF] (DRAM)
     Fan 0 785 RPM [0x311] (CPU)
     Fan 1 740 RPM [0x2E4] (Front)
Hardware monitor D3D
Hardware monitor Intel I/O
     Temperature 0 35 degC (95 degF) [0x23] (GPU)
     Clock Speed 0 0.00 MHz [0x0] (Graphics)
     Clock Speed 1 n.a. (Memory)
     Clock Speed 2 n.a. (Processor)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0x3EC2
     Revision ID 0x07
Description VGA Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0x3E92
     Revision ID 0x00
Description USB Controller (xHCI)
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0xA2AF
     Revision ID 0x00
Description Data Aquisition and Signal Processing Device
Location bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
     Vendor ID 0x8086
     Model ID 0xA2B1
     Revision ID 0x00
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0xA2BA
     Revision ID 0x00
Description RAID Controller
Location bus 0 (0x00), device 23 (0x17), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0x2822
     Revision ID 0x00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0xA295
     Revision ID 0xF0
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0xA2CC
     Revision ID 0x00
Description Memory Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
     Vendor ID 0x8086
     Model ID 0xA2A1
     Revision ID 0x00
Description High Definition Audio (HDA)
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
     Vendor ID 0x8086
     Model ID 0xA2F0
     Revision ID 0x00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 4 (0x04)
Common header
     Vendor ID 0x8086
     Model ID 0xA2A3
     Revision ID 0x00
Description Ethernet Controller
Location bus 0 (0x00), device 31 (0x1F), function 6 (0x06)
Common header
     Vendor ID 0x8086
     Model ID 0x15B8
     Revision ID 0x00
Description Network Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID 0x8086
     Model ID 0x3166
     Revision ID 0x99
DMI
SMBIOS Version 3.0
DMI BIOS
     vendor LENOVO
     version O4KKT11A
     date 09/23/2020
     ROM size 8192 KB
DMI System Information
     manufacturer LENOVO
     product 90LU001RIX
     version ideacentre 510-15ICK
     serial PC1F5QDM
     UUID {07845600-6C9D-11EA-8CFB-6B0B2A5F2200}
     SKU LENOVO_MT_90LU_BU_Lenovo_FM_ideacentre 510-15ICK
     family ideacentre 510-15ICK
DMI Baseboard
     vendor LENOVO
     model 3714
     revision SDK0J40700 WIN 3258164201703
     serial unknown
DMI System Enclosure
     manufacturer LENOVO
     chassis type Desktop
     chassis serial PC1F5QDM
DMI Port Connector
     designation J1A1 (internal)
     designation PS2Mouse (external)
     port type Mouse Port
     connector PS/2
DMI Port Connector
     designation Keyboard (external)
     port type Keyboard Port
     connector PS/2
DMI Port Connector
     designation J2A1 (internal)
     designation TV Out (external)
     connector Mini Centronics Type-14
DMI Port Connector
     designation J2A2A (internal)
     designation COM A (external)
     port type Serial Port 16550A
     connector DB-9 male
DMI Port Connector
     designation J2A2B (internal)
     designation Video (external)
     port type Video Port
     connector DB-15 female
DMI Port Connector
     designation J3A1 (internal)
     designation USB1 (external)
     port type USB
     connector Access Bus (USB)
DMI Port Connector
     designation USB2 (external)
     port type USB
DMI Port Connector
     designation USB3 (external)
     port type USB
DMI Port Connector
     designation J9A1 - TPM HDR (internal)
DMI Port Connector
     designation J9C1 - PCIE DOCKING CONN (internal)
DMI Port Connector
     designation J2B3 - CPU FAN (internal)
DMI Port Connector
     designation J6C2 - EXT HDMI (internal)
DMI Port Connector
     designation J3C1 - GMCH FAN (internal)
DMI Port Connector
     designation J1D1 - ITP (internal)
DMI Port Connector
     designation J9E2 - MDC INTPSR (internal)
DMI Port Connector
     designation J9E4 - MDC INTPSR (internal)
DMI Port Connector
     designation J9E3 - LPC HOT DOCKING (internal)
DMI Port Connector
     designation J9E1 - SCAN MATRIX (internal)
DMI Port Connector
     designation J9G1 - LPC SIDE BAND (internal)
DMI Port Connector
     designation J8F1 - UNIFIED (internal)
DMI Port Connector
     designation J6F1 - LVDS (internal)
DMI Port Connector
     designation J2F1 - LAI FAN (internal)
DMI Port Connector
     designation J2G1 - GFX VID (internal)
DMI Port Connector
     designation J1G6 - AC JACK (internal)
DMI OEM Strings
     string[0] LENOVO ThinkCentre Embedded Controller -[O4KCT01A-1.01]-
     string[1] LENOVO ThinkCentre BIOS Boot Block Revision 1.11
     string[2] Lenovo Service Engine Not Supported
DMI Physical Memory Array
     location Motherboard
     usage System Memory
     correction None
     max capacity 64 GB
     max# of devices 2
DMI Memory Device
     designation ChannelA-DIMM1
     format DIMM
     type DDR4
     total width 64 bits
     data width 64 bits
     size 16 GB
DMI Memory Device
     designation ChannelB-DIMM1
     format DIMM
     type DDR4
     total width 64 bits
     data width 64 bits
     size 16 GB
DMI Processor
     manufacturer Intel(R) Corporation
     model Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz
     clock speed 2900.0 MHz
     FSB speed 100.0 MHz
     multiplier 29.0x
DMI Extension Slot
     designation PCI-Express
     type AA
     populated no
DMI Extension Slot
     designation PCI-Express 6
     type A5
     populated no
DMI Extension Slot
     designation PCI-Express 7
     type A5
     populated no
DMI Extension Slot
     designation PCI-Express 8
     type A5
     populated no
DMI Extension Slot
     designation PCI-Express 14
     type A5
     populated no
Graphics
Number of adapters 1
Graphic APIs
API D3D
API Intel I/O
Display Adapters
Display adapter 0
     ID 0x4000000
     Name Intel(R) UHD Graphics 630
     Board Manufacturer Lenovo
     Codename Coffee Lake GT2
     Technology 14 nm
     PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
         Vendor ID 0x8086 (0x17AA)
         Model ID 0x3E92 (0x3714)
         Revision ID 0x0
     Performance Level 0
         Core clock 449.0 MHz
     Driver version 27.20.100.9466
     WDDM Model 2.7
Win32_VideoController AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController DriverVersion = 27.20.100.9466
Win32_VideoController DriverDate = 03/30/2021
Monitor 0
     Model S27F350 (Samsung)
     ID SAM0D22
     Serial H4ZN802044
     Manufacturing Date Week 35, Year 2020
     Size 27.2 inches
     Max Resolution 1920 x 1080 @ 60 Hz
     Horizontal Freq. Range 30-81 kHz
     Vertical Freq. Range 50-75 Hz
     Max Pixel Clock 170 MHz
     Gamma Factor 2.2
Monitor 1
     Model R19BAC/H/S/U (Lite-On Technology)
     ID LTN0241
     Serial 613280007
     Manufacturing Date Week 13, Year 2006
     Size 19.1 inches
     Max Resolution 1280 x 1024 @ 60 Hz
     Horizontal Freq. Range 30-82 kHz
     Vertical Freq. Range 56-76 Hz
     Max Pixel Clock 140 MHz
     Gamma Factor 2.2
40 minuti fa, Giaccaz ha scritto:
Scheda video consigliata..... a scelta AMD, come ti ho suggerito prima sarebbe il top una 6XXX, di seguito una 5XXX, ma le trovi a prezzi folli.
Ad oggi se trovi al prezzo giusto una 570/580/590 da 4/8 gb sei a a cavallo ( pensa che io la 570 4gb l'ho presa ad luglio dell'anno scorso di seconda mano a 100€ e ora la vendono al doppio).
Se invece sei un fanboy di nvidia puoi optare per una gt710 che su osx e nativa ( la utilizzo su un i7 2600 ) ma ovviamente e una entry level.
Poi ovviamente dalla serie 1XXX alla serie 3XXX..... sotto osx sei obbligato ad usare la igpu del cpu (dovrai  allora optare al momento per una cpu serie 10XXX che han ancora la uhd630 che funziona al 100% non so se la uhd750 della seire 11XXX viene riconosciuta ....) e  disabilitare la gpu (nvidia) ovviamente  utilizzandola solo sotto winzoz/linux.
p.s. ma recuperare tutto hw che hai ( che non e malaccio ) e cambiando solo mobo, gpu, case,ali ?
proprio oggi ho aperto il case (comprato questo inverno a 700 euro) il problema che quando l'ho comprato era in piena pandemia unico negozio aperto era euronics ma aveva solo questo desktop rimanente non avevano più nulla
  • Processore : Intel Core i5-9400 (frequenza base 2.9 GHz, fino a 4.1 GHz, 9 MB di cache, Hexa Core)
  • Ram : 32 GB di DIMM DDR4-2666
  • Scheda grafica integrata : Intel UHD Graphics 630
il problema con questa macchina e le dimensioni del case ridotte, come dicevo prima oggi l'ho aperto per sostituire il case ma come l'ho aperto mi sono reso conto subito che con un altro case (standard) avrò problemi con le uscite frontali della scheda madre, allego foto.
come si può vedere la parte frontale della scheda madre dove ci sono le 4 porte usb3 - typec- uscita audio e microfono, finirebbero all'interno del case (standard)
attualmente con le impostazioni attuali l'audio funzionante è quello frontale (verde) quello retro non funziona (rosso) con big sur
oltre al problema evidenziato, c'é anche il problema dell'alimentatore gli attacchi sono proprietari no standard con alimentatore proprietario non si può collegare scheda video alimentata, se si poteva fare avrei già sostituito il case (che già ho per altro) comprato scheda video potente , senza ordinare scheda video modesta per questa macchina.
per questi motivi sto optando per sostituire la macchina prendendone una dove non avrò questo tipo di problema
Edited by solaris82
oggi ho scollegato cavo hdmi lasciando solo il vga, a mia gran sorpresa si avvia il caricamento di os,  al fine del caricamento lo schermo rimane nero, ho collegato cavo hdmi mi ha rilevato due monitor, vga monitor 1,  hdmi monitor 2, il monitor dove è collegato vga rimane nero con scritta nessun segnale, ma nel pc viene rilevato come se fosse in funzione🧐  allego video
in attesa che arrivi la scheda video ordinata, mi piacerebbe poter usare entrambi i monitor e capire come mai non dà segnale alla fine del caricamento.
Edited by solaris82
Analogico e digitale in macOS difficilmente convivono, forse in automatico fino a Yosemite... puoi provare a smanettare coi valori di edid del monitor che attacchi all'hdmi ricavandoli da windows / linux.
come mai compare caricamento di Mac e poi alla fine quando si avvia scompare 🤔
Se non venisse riconosciuta da os non ci sarebbe nemmeno la parte del caricamento iniziale,
Se apro Hackintool vengono riconosciuti entrambi e viene anche riconosciuto il monitor dove è collegato vga
Edited by solaris82
Se non venisse riconosciuta da os non sarebbe nemmeno la parte del caricamento
Fa così perché la fase di caricamento è diversa da quella in cui partono i driver accelerati di macOS, è lì che non gli inietta l'edid corretto!
quindi avvio ubuntu in live,
che comando devo dare per sapere gli edid corretti?
14 minuti fa, carlo_67 ha scritto:
se attacchi un solo monitor, su vga funziona?
come si vede nel video, parte il caricamento di os, finito di caricare os, al momento dell'avvio da nessun segnale, collegando hdmi  andando su imp/monitor vengono rilevati entrambi, ho anche provato a cambiare la frequenza 50/60/75 hertz al monito (vga) ma nulla da nessun segnale (come dimostrato nel video )
riallego il video
(spegno la macchina, entrami collegati (hdmi e vga) viene rilevato solo hdmi.
6 minuti fa, carlo_67 ha scritto:
Appunto vga non è supportato
perché parte il caricamento? 🤔  non si doveva neanche vedere il caricamento 🧐
in più aprendo Hackintool in display ci sono entrami sia quello hdmi che vga 🤔🧐
2 minuti fa, carlo_67 ha scritto:
puoi provare con adattatore
io lo uso, ma per il monitor vga, questo
cosi servirebbe a te, ma non l'ho provato
in realtà i monitor dove è collegato vga supporta vga / dvi esiste adattatore da vga a dvi? penso di si ormai esiste adattatore di ogni 🤣
Edited by solaris82
in realtà i monitor supportano vga/ dvi esiste adattatore da vga a dvi? penso di si ormai esiste adattatore di ogni 🤣
Perché macOS prima parte in vesa poi appena si caricano i kext di macOS questi non si filano il monitor vga, o lo fanno parzialmente. Prova l'adattatore dvid - vga ma la veggo buia
Edited by tomnic
stavo anche pensando a prendere uno Splitter HDMI 1×2, Ripartitore HDMI 1 input 2 ouput
razzisti 😒
e si può fare dividi schermo? o solo duplica?
Mirroring = duplica
Avessi avuto una DP e un HDMI eri a cavallo, ma la porta vga su Intel HD da Ivy Bridge in su macOS non se la c*ga più, se va è pura fortuna
Edited by tomnic
4 minuti fa, tomnic ha scritto:
Mirroring = duplica
già vero 😅
mi tocca attendere metà del prossimo mese che arrivi la scheda video nuova 😔
per adesso sarò costretto a riavviare far partire windows ( 🤢  )per poter lavorare lm.....
Adesso, carlo_67 ha scritto:
@solaris82 quando ti arriva la scheda video,
mi metto in malattia😂😂
quando arriva la scheda video nuova non mi sentirete più 🤣🤣  (se funziona ovviamente 🤣 )
tutto questo è accaduto perché l' imac che avevo in piena pandemia è andato a farsi f... 🤣  lms..... :default_hysterical:
unico disponibile i5 desktop era rimasto solo questo, imac -macbook terminati
altri desktop erano i3
Edited by solaris82
