Hackintosh Acer Aspire E 15 i3
solaris82
Adesso, carlo_67 ha scritto:
riprova ora che hai disabilitato il SIP ad reistallarlo con kext&repair
ok
lo sta installando ma compare sempre messaggio che dice " has no Info.plist file.
come finisce posto l'esecuzione
35 minuti fa, carlo_67 ha scritto:
altra prova, istalla direttamente questo con Kext&Repair
in S/L/E
fatto
Last login: Wed May 19 14:25:42 on console
/Applications/Kext\&Repair ; exit;
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
MacBook-Pro-di-Giuseppe:~ giuseppe$ /Applications/Kext\&Repair ; exit;
This script requires run as root Please.. Enter your Password!! ***************************************************************
Password:
********************** Welcome to Kext&Repair [2.3] **********************
 Welcome... giuseppe
Menù:
1) Maintenance
2) Install kext
3) Exit
Please enter your choice: 2
Drag your kext inside this terminal window and press Enter: /Users/giuseppe/Desktop/IO80211Family.kext
Install kext to:
[1] "/Library/Extensions"
[2] "/System/Library/Extensions"
Choice: 2
Kexts to be installed in /System/Library/Extensions:
1 - /System/Library/Extensions/IO80211Family.kext
kextcache -i /
kextcache -arch x86_64 -local-root -all-loaded -kernel /System/Library/Kernels/kernel -prelinked-kernel /Library/Apple/System/Library/PrelinkedKernels/prelinkedkernel -volume-root / /Library/Extensions /AppleInternal/Library/Extensions /Library/Apple/System/Library/Extensions /System/Library/Extensions
/Library/Extensions/IO80211Family.kext has no Info.plist file.
KernelCache ID: E3268C14667EE71E140FA4ADD514BF80
Kext with invalid signature (-67013) allowed: <OSKext 0x7ffc1dda10b0 [0x7fff878efcf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/", ID = "com.apple.iokit.IO80211Family" }
Kext with invalid signature (-67013) allowed: <OSKext 0x7ffc1dda2be0 [0x7fff878efcf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/IO80211NetBooter.kext/", ID = "com.apple.driver.IO80211NetBooter" }
Kext with invalid signature (-67030) allowed: <OSKext 0x7ffc1dda4520 [0x7fff878efcf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortAtheros40.kext/", ID = "com.apple.driver.AirPort.Atheros40" }
Kext with invalid signature (-67013) allowed: <OSKext 0x7ffc1dda59b0 [0x7fff878efcf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortBrcmNIC.kext/", ID = "com.apple.driver.AirPort.BrcmNIC" }
Done...
Required Reboot...
 Welcome... giuseppe
Menù:
1) Maintenance
2) Install kext
3) Exit
2 ore fa, carlo_67 ha scritto:
poi fai manutenzione
apri anche terminale e digita
sudo kextcache -i /
ho eff. manutezione tramite Kext&Repair riavviato, wifi nada , aperto terminale dato comando " sudo kextcache -i / "
ecco il risultato
Last login: Wed May 19 15:11:09 on console
MacBook-Pro-di-Giuseppe:~ giuseppe$ sudo kextcache -i/
Password:
Sorry, try again.
Password:
kextcache -i/
KernelCache ID: 0C7B38273D516ED7934DCABA9DA4E91E
Kext with invalid signature (-67013) allowed: <OSKext 0x7fd837cbc750 [0x7fff89e44cf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/", ID = "com.apple.iokit.IO80211Family" }
Kext with invalid signature (-67013) allowed: <OSKext 0x7fd837cbe800 [0x7fff89e44cf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/IO80211NetBooter.kext/", ID = "com.apple.driver.IO80211NetBooter" }
Kext with invalid signature (-67030) allowed: <OSKext 0x7fd837cc01d0 [0x7fff89e44cf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortAtheros40.kext/", ID = "com.apple.driver.AirPort.Atheros40" }
Kext with invalid signature (-67013) allowed: <OSKext 0x7fd837cc1d90 [0x7fff89e44cf0]> { URL = "file:///System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortBrcmNIC.kext/", ID = "com.apple.driver.AirPort.BrcmNIC" }
8 minuti fa, carlo_67 ha scritto:
ci sei?
si certo dimmi
wifi non compare
sto riavviando
se premo fn+f3 "sarebbe comando per attivare o disattivare wi-fi " si disattiva o si attiva il Bluetooth
ma il wi-fi non compare 🥺
il Bluetooth anche se presente non rileva nessun dispositivo e se provo con cellulare non viene rilevato il notebook
non vorrei fosse il Bluetooth a fare conflitto con il wi-fi , perché strano do comando per attivare o disattivare wi-fi e si attiva o disattiva Bluetooth
Edited by solaris82
11 minuti fa, carlo_67 ha scritto:
lascialo attivato
metti questo in OC/kext prima prova con uno poi l'altro, non devono essere insieme
definiscilo nel config e riavvia
toledaARPT.kext.zip 3 kB · 0 download ATH9KFixup.kext.zip 21 kB · 0 download
sto provando con toledaARPT.kext.zip
e comunque ti assicuro che funge quella scheda
la fortuna che ho io è epica 😂
ti posso postare la cartella EFI  che sto usando?
se provo a installare big sur? magari è un problema di Catalina
1 minuto fa, carlo_67 ha scritto:
comunque qualcosa non và perche l'icona ci deve essere, magari grigia, perche manca uno di questi 2 kext
stavo pensando di fare installazione pulita di Catalina
ti passo la cartella EFi in uso in questo momento gli dai un occhiata, che ne pensi?
magari prima di far partire installazione pulita di Catalina mi dici se va bene la cartella EFI
avviato con ATH9KFixup.kext nada nessuna icona del wifi 🥺
2 minuti fa, solaris82 ha scritto:
e la cartella con  ATH9KFixup.kext  all'interno
