Lilu
Rilasciata la release ufficiale 1.2.4
    [list=]Internalize new APIs from 1.2.3
    Added new EFI runtime API with custom variable extensions
    Added new RTC storage API
    Added centralised entitlement hooking API
    Added lilu_os_qsort export (the supported interface is Apple-private)
    Added liludelay=1000 boot argument to insert a 1s delay after each print
    Added new symbol routing API with simplified interface
    Fixed a kernel panic in userspace patching code on 10.14b1
@Gengik84[/mention] leggendo il thread su IM
https://www.insanelymac.com/forum/topic/325987-whatevergreen-support-topic/?do=findComment&comment=2620821">https://www.insanelymac.com/forum/topic ... nt=2620821">https://www.insanelymac.com/forum/topic/325987-whatevergreen-support-topic/?do=findComment&comment=2620821
Nei prossimi aggiornamenti, per semplicità, manutenibilità e miglioramenti della velocità di avvio non quantificabili, alcuni plugin Lilu dedicati per il patching GPU verranno uniti in uno e verranno visualizzati come un singolo modulo.
Tu che sei in contatto con le alte sfere, sai già come lo chiameranno e dove lo rilasceranno?
Release UFFICIALE
v1.2.5 https://github.com/acidanthera/Lilu/releases">https://github.com/acidanthera/Lilu/releases
Added new DeviceInfo API
Added checkKernelArgument API
Added enforced LiluAPI interfaces
Added KextInfo::switchOff API
Added cpuid API
Allowed for onKextLoad to accept no callback
Removed GPU detection code from CPUInfo API
Enabled by default on 10.14
  • 4 weeks later...
NUOVA VERSIONE
v1.2.6
Added Cannon Lake and Ice Lake definitions
Added missing typed getOSData APIs
Added -liluuseroff boot-arg to disable user patcher (for e.g. shared cache manipulation)
Added lilucpu=N boot-arg to assume CPU generation
Added CPU topology detection APIs
Fixed routeMultiple kernel panic and log report
Switched to Apple lzvn implementation
  • 5 weeks later...
v1.2.7
Added support for detecting optimus switch-off
Added Sanitize target with ubsan support (thx to NetBSD)
Added disk log dump in DEBUG builds via liludump=N boot-arg (requires plugin rebuild)
Fixed multiple Mach-O parsing issues
Fixed support of PCI devices without compatible property
Fixed PCI class-code masking not detecting HDEF devices
v1.2.8
Fixed CPU generation detection for Coffee Lake-U
Fixed PEGP detection with 3D Controller class-code
Fixed userspace patcher compatibility with macOS Mojave
Allow manually specified reservation in evector
Improved version information printing in DEBUG builds
v1.2.9
Added kern_atomic.hpp header to support atomic types with old Clang
Added ThreadLocal APIs
Added KernelPatcher::eraseCoverageInstPrefix API
Fixed race condition during bootstrap (thx @Download-Fritz)
Fixed potential race condition during user patching
v1.3.1 *nov* https://github.com/acidanthera/Lilu/releases">https://github.com/acidanthera/Lilu/releases
Lowered version compatibility to 1.2.0 to let plugins load
Note: This release is functionally not different from 1.3.0, but it fixes plugin loading from /Library/Extensions if absolutely necessary.
Compatibilità della versione ridotta a 1.2.0 per consentire il caricamento dei plugin
Nota: questa versione non è funzionalmente diversa dalla 1.3.0, ma risolve il caricamento dei plugin da / Library / Extensions se assolutamente necessario.
v1.3.0
Fixed a rare kernel panic on user patch failure
Removed unimplemented genPlatformKey API
Release rilasciata
v1.3.3
Added support for modern AMD device scanning by @AlGreyy
Added support for VMware device scanning
Extended supported firmware vendor list
Ha scritto dopo 7 minuti 35 secondi:
  • 2 months later...
Lilu 1.3.7 Release è stata rilasciata
[code]Allow loading on 10.15 without -lilubetaall
Add support for Xcode 11 analysis tools
Add workaround to 10.15 SDK Dispatch method (use old Xcode when possible)
[/code]
Lilu 1.3.8 Release
[code]Compile Xcode 11 OSObject stubs into plugins to allow mixing compilers
Unified release archive names
Added multirouting support to routeFunction API enabling functions to have multiple proxies
Added explicit routing type to routeFunction APIs
Made Lilu use long function routes to ease third-part multirouting
[/code]
  • 2 months later...
Release v1.4.0
  • Fixed mishandling user patches process list after processKernel API call
  • Fixed extra I/O in user patcher even when no patches were needed
  • Added support for per-process (LocalOnly) userspace patches
Release 1.4.1
Made applyLookupPatch support kernel patches by passsing null kext
Export hde64 interface
Added evector deleter without copying for improved performance
Allow C strings as module prefix argument to the logging functions
