Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 serve il relativo kext ma tu oltre a un atheros che non è supportato, hai un modello ancor più particolare e problematico Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 ok, ma sarebbe una cosa fattibile? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 https://www.macos86.it/files/file/93-atheros-wifi-bigsur-ready-work-clover/ Scarica WIFI atheros, poi prendi e decomprimi lo zip ar9485 poi prendi il kext e aggiungilo insieme all'altri poi definiscilo sul config ma presta attenzione perchè devi definire anche il plugins se non sai come fare, usa questo https://www.macos86.it/files/file/57-oc-kext-path-info/ ti genera tutta la lista e relativa definizione dei kext, quindi tu prendi quello riferito al kext e quello riferito a AirPortAtheros40.kext Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 scusa l'ignoranza ma non saprei definire il plugins Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 leggi quello che ho scritto e usa il mio script Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 Poi come non lo sai? L'hai già fatto per VoodooPS2 quindi per il plugins sarebbe BundlePath: HS80211Family.kext/Contents/PlugIns/AirPortAtheros40.kext ExecutablePath: Contents/MacOS/AirPortAtheros40 PlistPath: Contents/Info.plist Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 (edited) correggimi se sbaglio, io inserisco il Kext nella cartella, edito il config con proopertree e con Command r seleziono la cartella di oc e mi importa lui il Kext Edited February 26, 2021 by Fabio_64 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 Adesso, Fabio_64 ha scritto: edito il config con proopertree e con Command r seleziono la cartella di oc e mi importa lui il Kext te lo fa lui? se è così bene sinceramente non lo uso quindi non saprei di quell'app Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 si si, questo lo consiglia dortania ed è semplice da usare, adesso mi è partito per errore l'aggiornamento quindi appena termina provo il kext 1 Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 perfetto, wi-fi sistemato, l'unica cosa ora è il trackpad, ma con i kext che ho provato non si risolve Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 Quello di Rehabman? mi sembra strano, ha sempre funzionato Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 si, con quello la tastiera non funziona neppure bene, e il trackpad non risolve nulla Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 26, 2021 Administrators Share Posted February 26, 2021 quello acidanthera stesso comportamento? di fatto il trackpad è PS2 e rehab dovrebbe andare, in caso sarebbe da vedere l'ordine di come sono dichiarati i kext sul config Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 26, 2021 Author Share Posted February 26, 2021 si, stesso comportamento, riguardo all'ordine cosa potrei fare ? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 27, 2021 Administrators Share Posted February 27, 2021 allega l'attuale config Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 allego la EFI completa e config singoloConfig.plist.zip EFI.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 27, 2021 Administrators Share Posted February 27, 2021 disabilita la patch ACPI sul config, stessa cosa per ssdt xosi Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 scusa l'ignoranza ma non ho capito cosa devo disabilitare e in che sezione Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 27, 2021 Administrators Share Posted February 27, 2021 sezione ACPI Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 e disabilito la patch e tutti gli ssdt ? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 27, 2021 Administrators Share Posted February 27, 2021 la patch e un solo ssdt quello xosi Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 ok, provo a fare il boot e vediamo se si sistema il trackpad Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 nulla, ancora lo stesso problema al trackpad Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 27, 2021 Administrators Share Posted February 27, 2021 con quello di rehabman? voodooInput disabilitalo sul config Link to comment Share on other sites More sharing options...
Fabio_64 Posted February 27, 2021 Author Share Posted February 27, 2021 allora, con quello di rehabman il trackpad penso si risolva, ma la tastiera quando avevo provato non funzionavano alcune lettere Link to comment Share on other sites More sharing options...
