Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 ecco con usbinjectall.ioreg.zip Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 (edited) questo è quello che ho nel bios Edited February 23, 2021 by Matteo88 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 potrebbe dipendere dalle acpi, allega quelle pulite Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 😅😅ho scaricato la versione debug, ma non ricordo come si fa... comunque ho dovuto togliere usbinjectall perchè il sistema era instabile anzi mi correggo, ho provato ad usare anteprima per modificare delle foto e si chiude dando un messaggio di errore quindi non credo sia usbinjectall il problema Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 Qualcuno può indicarmi come si fa ad estrarre le acpi con oc? Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 @Gengik84 ecco le acpi origin.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 ma sono estratte con clover... come fare è scritto nel topic "richiesta di supporto" Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 ecco quelle con oc ACPI.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 allega anche il config Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 ecco config.plist.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 Aggiungi ssdt e sostituisci il config poi rifai ioreg Archivio.zip Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 eccoprovaSSDT5.ioreg.zip funziona✌️✌️✌️ Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 ok ottimo la porta usb del BT è attiva adesso Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 (edited) quindi era una questione di mappatura usb? Edited February 23, 2021 by Matteo88 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 non proprio esattamente, il discorso è che di natura le tue acpi hanno la relativa porta del BT disattiva Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 ok, io ora vorrei aggiornare a Big Sur, credi che con il mio m2 wifi BCM94352Z/BT 4.0 ci siano problemi? Link to comment Share on other sites More sharing options...
damiandrake Posted February 24, 2021 Share Posted February 24, 2021 (edited) 10 ore fa, Matteo88 ha scritto: ok, io ora vorrei aggiornare a Big Sur, credi che con il mio m2 wifi BCM94352Z/BT 4.0 ci siano problemi? Ciao, scusa se ti rispondo solo ora e se rispondo io e non @Gengik84 ma è da quando è iniziato questo topic che volevo contribuire anch'io 🙂 Ho controllato e la tua scheda risulta compatibile con Big Sur Edited February 24, 2021 by damiandrake 1 Link to comment Share on other sites More sharing options...
Matteo88 Posted February 24, 2021 Author Share Posted February 24, 2021 Ok grazie👍🏼 Link to comment Share on other sites More sharing options...
