Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 si ho provato prima a 64mb e poi a 128mb,ma uguale Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Se hai settato nel bios la shared memory "framebuffer-stolenmem" nel config non va usato perché inutile, anzi deleterio. Toglilo dal config e riprova sia con 64 che con 128mb di memoria e posta uno ioreg con quello che funziona, se funziona con entrambi 2 ioreg Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 posso mettere 0 a stolenmem se si che platform-id dovrei usare? Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Cancella proprio la riga, non deve esserci. Riguardo ig platform quello corretto da mettere nel config è 07009B3E eventualmente in caso di problemi provare 00009B3E Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 risolto, era stolenmem che creava problemi ora funziona grafica e audio grazie Jolly ora rimane il bt Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Mi fai uno ioreg per favore? Hai cambiato ig-platform oltre a togliere stolen-memory? Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 ora non mi fa aprire ioregistry Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Mi rispondi alle domande che ti ho fatto per favore? Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 comunque ho usato 07009B3E e tolto stolenmem hackcheck puo esserti utile perché ioregistryexplorer non lo vuole aprire e non so il perchè Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Ok. Con "Funziona Audio" intendi HDMI giusto Ora prova questo config, però fa in modo di avere un boot alternativo se non funziona. config.plist 2.zip Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 allora lo provo su usb Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Naturalmente se funziona fai ioreg Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 ok jolly mi è nato un imprevisto è devo andare appena mi libero se sei disponibile continuiamo, grazie di tutto per ora Link to comment Share on other sites More sharing options...
Matteo88 Posted February 21, 2021 Author Share Posted February 21, 2021 jolly ho provato carica tutto il verbose, poi quando dovrebbe arrivare sulla scrivania il segnale video si interrompe come se non ci fosse collegato nulla al monitor, ma il pc è acceso normalmente Link to comment Share on other sites More sharing options...
Moderators Jolly Posted February 21, 2021 Moderators Share Posted February 21, 2021 Senza ioreg era un tentativo al buio. Torna pure alla situazione precedente dove ti funzionava tutto Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 Il 21/2/2021 at 12:09, Gengik84 ha scritto: poi @Matteo88 come detto prima devi verificare il config BootProtect è stato rimosso, idem per DuplicateBootOrder ultima release 0.6.6 Replaced BootProtect with LauncherOption and LauncherPath release 0.6.5 Removed no longer required DeduplicateBootOrder quirk il tuo config è vecchio... @Gengik84 ho sistemato il config ed ora non ho piu nessun messaggio, poi come da guida https://github.com/acidanthera/BrcmPatchRAM ho usato BrcmPatchRam3.kext, BrcmFirmwareData.kext, BrcmBluetoothInjector.kext, ma il BT non funziona. cosa posso fare altro? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 allega ioreg i kext li hai definiti? Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 i kext si sono definiti nel config, ma ioreg non posso allegarlo perché mi da il seguente errore: hackcheck può aiutarti? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 prova questo IORegistryExplorer_3.0.2.zip Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 ecco iMac di Matteo.ioreg.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 in kernel/quirk hai abilitato XhciPortLimit? Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 si perchè poi devo fare la mappatura usb Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 hai alcune porte usb disattive, potrebbe dipendere da questo non hai niente che riguarda la mappatura di queste, giusto? in caso metti usbinjectall e rifai ioreg poi allega anche le acpi pulite Link to comment Share on other sites More sharing options...
Matteo88 Posted February 23, 2021 Author Share Posted February 23, 2021 io ho notato che nel bios ho una sezione dove sono elencate tutte(almeno credo) le usb con la possibilità di disattivarle, ma io le ho attivate tutte,. comunque ora provo con usbinjectall... per le acpi con oc devo scaricare la versione debug se non sbaglio giusto? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 23, 2021 Administrators Share Posted February 23, 2021 3 minuti fa, Matteo88 ha scritto: per le acpi con oc devo scaricare la versione debug se non sbaglio giusto? si esatto Link to comment Share on other sites More sharing options...
