fabio8v Posted June 16, 2018 Share Posted June 16, 2018 buonasera a tutti sto provando ad installare el capitan (causa processore non compatibile con versioni più recenti di os x), la prima installazione parte, al riavvio non vedo il disco fisso ma solo l'installer usb, qualche consiglio? Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 Posta cartella Clover , possibile driver64 o driver64UEFI mancante... CREDO Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 grazie per la risposta..intanto controllo Ha scritto dopo 1 minuto 59 secondi: mi sembra che ci sia tutto CLOVER.zip Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 Se istalli Legacy ESP e usi driver64 mancano i driver x supporto HFS ,o HFSPlus o VBoxhfs devi inserire se sei in UEFI gia c'è Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 scusa..in clover ho sempre selezionato (legacy) nvm...e ps2.. Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 Tentar non nuoce alle brutte cancelli il driver installato , la cartella driver64UEFI puoi anche cestinarla .. Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 dove prendo i files che dici? Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 installi Clover sopra Clover e aggiungi la spunta al Driver64 desideri aggiunge , il resto delle impostazioni gia dovrebbe risultare come precedente installazione di clover Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 la spunta su cosa? Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 Ho editato il mess precedente , scusa Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 ho solo questo.. Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 HFSPlus non c'è??? https://postimg.cc/image/e4qd24hb5/"> Aggiungi questo Driver in Driver64 e prova .... HFSPlus-64.efi.zip Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 non cambia nulla Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 OK partiamo da 0 , innanzi tutto specifica l'HW anche se lo hai gia fatto in Topic passati , in maniera dettagliata , come gia sai ,sistemo la clover x il meglio e proviamo ..... Se non ti vede i dischi alla Gui il problema è clover o impostazioni errate in Bios Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 c'è poco da dire..4 gb ram, 1xhd, 1 x dvd Ha scritto dopo 18 secondi: scheda video on board Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 CPU?? Scheda video ??? NON trovo info in merito e se ci sono chiedo scusa .. Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 cpu dula core e5700, scheda video on board, nel chipset g31 Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 https://www.asus.com/Motherboards/P5KPL_SE/">https://www.asus.com/Motherboards/P5KPL_SE/ questa??? Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 si Link to comment Share on other sites More sharing options...
Baio77 Posted June 16, 2018 Share Posted June 16, 2018 e qui NON vedo integrate .... che VGA hai?? Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 scusa..ho sbagliato..p5kpl-am se Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted June 16, 2018 Administrators Share Posted June 16, 2018 grafica onboard? Nahh... monta una scheda video.. altrimenti non ti funzionerà mai... Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 Vabbè...lo so...volevo provare..intanto si ferma dove la scheda grafica non c'entra..poi vediamo.. Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted June 16, 2018 Administrators Share Posted June 16, 2018 aggiungi ahciportinjector nella efi Link to comment Share on other sites More sharing options...
fabio8v Posted June 16, 2018 Author Share Posted June 16, 2018 Grazie gengik84..proverò domani.. Link to comment Share on other sites More sharing options...
