HP Probook 4710s
A23SS4NDRO
niente, se tolgo il kext disabler ancora mi panica con il DSDT custom
provo ad avviare con il kext disabler attivo
Per il trackpad comunque confermo che è un Synaptics PS/2 Port Trackpad con nome:
\_SB.PCI0.LPCB.PS2M
e la tastiera è anche lei una "standard PS/2 keyboard" con Bios device path:
\_SB.PCI0.LPCB.PS2K
a posto allora mi faccio un bel giretto di tutti i possibili macbook/macbookpro/macbookair con Penryn... Ho spulciato a fondo tutto everymac.com, segno qui i possibili SMBIOS del Core 2 Duo Penryn
MacBookAir2,1: (Penryn) https://everymac.com/systems/apple/macbook-air/specs/macbook-air-core-2-duo-2.13-13-mid-2009-specs.html
MacBook4,1: (Penryn) https://everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.1-white-13-early-2008-penryn-specs.html
MacBook5,1: (Penryn) https://everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.0-aluminum-13-late-2008-unibody-specs.html
MacBook5,2: (Penryn) https://everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.0-white-13-early-2009-nvidia-specs.html
MacBook6,1: (Penryn) https://everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.26-white-13-polycarbonate-unibody-late-2009-specs.html
MacBook7,1: (Penryn) https://everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.4-white-13-polycarbonate-unibody-mid-2010-specs.html
MacBookPro4,1: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.4-15-early-2008-penryn-specs.html
MacBookPro5,1: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.4-aluminum-15-late-2008-unibody-specs.html
MacBookPro5,2: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.66-aluminum-17-early-2009-unibody-specs.html
MacBookPro5,3: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.66-aluminum-15-mid-2009-sd-unibody-specs.html
MacBookPro5,4: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.53-aluminum-15-mid-2009-sd-unibody-specs.html
MacBookPro5,5: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.26-aluminum-13-mid-2009-sd-firewire-800-unibody-specs.html
MacBookPro7,1: (Penryn) https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-2-duo-2.53-aluminum-15-mid-2009-sd-unibody-specs.html
Ho fatto il giro di tutti gli SMBIOS ma niente, il panic non vuole andarsene senza il kext che disabilita UHCI
Ho provato anche a mettere flag come RebaseRegions (on e off) dal momento che caricavo il DSDT custom, ReleaseUSBOwnership on/off, (e anche se era inutile, XhciPortLimit)
Allego subito qui sotto...
Mi chiedevo se dal momento che su questo portatile ci sono sia i controller EHCI che UHCI, se si possono temporaneamente disabilitare i controller UHCI lasciando solo EHCI (magari con il rename) per vedere se almeno parte senza il disabler
Allego anche l'ultima EFI con cui avvio con successo (con il disabler attivo) anche con il DSDT su True e il disabler su off ancora panica
Esiste uno spoof per le USB o qualcosa del genere?
EFI-disabler-on-booting-ok.zipFetching info...
lspci.zipFetching info...
Ho cercato in giro, e ho visto che nel mio DSDT sono presenti da USB1 a USB6 - difatti questi sono i controller gestiti dal kext che panica...
If you look deeper in your IOReg, you'll noticed that:
  • EUSB@fd000000 is associated with IOClass AppleUSBEHCIPCI, i.e. USB2.0 ports. Under that, you have your USB2.0 webcam for instance.
  • All USBn ports under are associated to IOClass AppleUSBUHCIPCI, i.e. they're UHCI (i.e. USB1) ports
  • USBE@fa000000 is associated with IOClas AppleUSBEHCIPCI, i.e. USB2.0 ports. Under that specific USBE hub, there are 6 ports located @fa1 to fa6
You can Google for USB types and the way they're managed under OS X. Here for instance.
Fonte: https://www.insanelymac.com/forum/topic/315114-im-a-newer-someone-can-help-me-fix-my-dsdt-for-usb20thinks/?do=findComment&comment=2279049
