legatimatteo Posted January 20, 2021 Share Posted January 20, 2021 (edited) Ciao, sto cercando di sistemare la batteria sul mio surface pro 7 1035g4, però quando cerco 'EmbeddedControl' nel DSDT.dsl con maciasl non compare nulla. Qualche aiuto? Grazie mille. EFI Surface.zipFetching info... SysReport.zipFetching info... Edited January 20, 2021 by legatimatteo Ho aggiunto la EFI Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 20, 2021 Administrators Share Posted January 20, 2021 Era meglio se allegavi le acpi pulite.. Link to comment Share on other sites More sharing options...
legatimatteo Posted January 20, 2021 Author Share Posted January 20, 2021 (edited) On 1/20/2021 at 8:16 PM, Gengik84 said: Era meglio se allegavi le acpi pulite.. Expand Aggiunte Edited January 20, 2021 by legatimatteo Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 20, 2021 Administrators Share Posted January 20, 2021 Si non c'è la batteria viene gestita da _SAN Link to comment Share on other sites More sharing options...
legatimatteo Posted January 20, 2021 Author Share Posted January 20, 2021 Quindi come potrei fare? Link to comment Share on other sites More sharing options...
legatimatteo Posted January 21, 2021 Author Share Posted January 21, 2021 On 1/20/2021 at 8:32 PM, Gengik84 said: Si non c'è la batteria viene gestita da _SAN Expand Ciao, ho guardato un po' su internet ma non capisco, che significa che è gestita da _SAN? Cioè, patchare la batteria è una cosa fattibile? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 21, 2021 Administrators Share Posted January 21, 2021 intendevo dire che quel device gestisce la batteria Link to comment Share on other sites More sharing options...
legatimatteo Posted January 21, 2021 Author Share Posted January 21, 2021 Quindi cosa dovrei fare? ammesso che ci sia un modo per sistemarla Link to comment Share on other sites More sharing options...
legatimatteo Posted January 23, 2021 Author Share Posted January 23, 2021 Comunque ho un'altro problema. Quando uso HiDPi lo schermo sbarbella. Però quando ho aggiornato Big sur da 11.0 a 11.1 l'hidpi si era attivato da solo e non sbarbellava, quando ho riavviato ha riiniziato. Link to comment Share on other sites More sharing options...
