Administrators Gengik84 Posted September 18, 2018 Administrators Share Posted September 18, 2018 si si esatto Link to comment Share on other sites More sharing options...
army2003 Posted September 18, 2018 Author Share Posted September 18, 2018 Ok ora funziona tutto grazie mille Sempre gentili e veloci Link to comment Share on other sites More sharing options...
army2003 Posted September 18, 2018 Author Share Posted September 18, 2018 @Gengik84[/mention] c'è un modo per mappare i tasti della tastiera per esempio i tasti del volume e della riproduzione( avanti pausa ecc.) funzionano solo la luminosità non riesco a comandarla dai tasti Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 18, 2018 Administrators Share Posted September 18, 2018 bisognerebbe fare un debug con il dsdt... oppure semplicemente collega una tastiera usb, poi vai nelle preferenze/monitor/abbreviazioni e imposti come preferisci Link to comment Share on other sites More sharing options...
army2003 Posted September 18, 2018 Author Share Posted September 18, 2018 è troppo difficile fare il debug dsdt? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 18, 2018 Administrators Share Posted September 18, 2018 C'è una guida sul forum.. quali kext usi per tastiera e trackpad? Link to comment Share on other sites More sharing options...
army2003 Posted September 18, 2018 Author Share Posted September 18, 2018 perchè comunque quando stacco la tastiera usb non funzionano i comandi con la tastiera normale Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 18, 2018 Administrators Share Posted September 18, 2018 Come no? tu devi impostarli esempio F1 e F2 una volta impostati poi funzionano Link to comment Share on other sites More sharing options...
army2003 Posted September 18, 2018 Author Share Posted September 18, 2018 "Gengik84" post_id="14215" time="1537298370" user_id="2"> C'è una guida sul forum.. quali kext usi per tastiera e trackpad? SYNAPTIC Ha scritto dopo 42 secondi: "Gengik84" post_id="14217" time="1537298566" user_id="2"> Come no? tu devi impostarli esempio F1 e F2 una volta impostati poi funzionano li ho impostati ma quando tolgo la tastiera non vanno Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 18, 2018 Administrators Share Posted September 18, 2018 un altra cosa che puoi usare per esempio è Ukelele che ti permette di crearti tutto un layout personalizzato per la tastiera Ha scritto dopo 1 minuto 25 secondi: "army2003" post_id="14218" time="1537298643" user_id="212"> li ho impostati ma quando tolgo la tastiera non vanno Questo è strano..l'unica cosa è che osx non riconosce esattamente la loro "posizione" nel senso tu imposti F2, premi F2 ma nella gestione della tastiera da parte di osx lui non esegue F2 ma per ipotesi F8 Ha scritto dopo 39 secondi: Quindi come kext usi VodooPS2? Link to comment Share on other sites More sharing options...
army2003 Posted September 19, 2018 Author Share Posted September 19, 2018 fatto risolto devo fare fn e poi i tasti della luminosità Ha scritto dopo 2 minuti 23 secondi: raga devo cambiare il modulo wifi questo va bene funziona tutto ( air drop wifi bt. ecc..) Se no consigliatemi voi qualcosa Grazie in anticipo Ha scritto dopo 48 secondi: BCM94352Z NGFF 802.11ac Modulo scheda wireless dual band wireless Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted September 20, 2018 Supervisor. Share Posted September 20, 2018 "army2003" post_id="14265" time="1537386939" user_id="212"> raga devo cambiare il modulo wifi questo va bene funziona tutto ( air drop wifi bt. ecc..) BCM94352Z NGFF 802.11ac Modulo scheda wireless dual band wireless Sì, ve bene. Servono un paio di "fix" e non andrà come una scheda nativa, ma funziona. Link to comment Share on other sites More sharing options...
army2003 Posted September 20, 2018 Author Share Posted September 20, 2018 mi sapete consigliare una buona scheda wifi ? Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted September 20, 2018 Supervisor. Share Posted September 20, 2018 Non fraintendere quello che ho scritto. La BCM94352Z è ottima. emoticon_sorriso2 Di meglio ci sono quelle basate su chip 4360 o 43602. Link to comment Share on other sites More sharing options...
army2003 Posted September 20, 2018 Author Share Posted September 20, 2018 okk Grazie mille Link to comment Share on other sites More sharing options...
army2003 Posted October 18, 2018 Author Share Posted October 18, 2018 Buona sera ho installato la scheda wifi BCM94352Z e ho seguito una guida ma non funziona mi potete dare una mano Grazie in anticipo Vi allego la efi EFI.zip Link to comment Share on other sites More sharing options...
Baio77 Posted October 18, 2018 Share Posted October 18, 2018 Prova a fare manutenzione con Kext & Repail , sembra su 10.13 NON abbia bisogno di alcuna Kext quindi , TOGLI tutto ciò hai introdotto in Kext x cercare di attivarla .... Fatto tutto ciò se ancora NON va , posta IORegistry e la foto della riga riguardo la Scheda WI-FI in DCPIManager x poter leggere ID ecc ecc .... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 18, 2018 Administrators Share Posted October 18, 2018 disinstalla l'app del usb wifi e rimuovi i relativi kext Link to comment Share on other sites More sharing options...
army2003 Posted October 18, 2018 Author Share Posted October 18, 2018 @Baio77[/mention] non va allego DCPI Ha scritto dopo 2 minuti 37 secondi: IOReg Ha scritto dopo 3 minuti 57 secondi: allego pure efi attuale MacBook Pro di Armando.zip EFI.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 18, 2018 Administrators Share Posted October 18, 2018 Leggi e fai quello che ti ho consigliato. Link to comment Share on other sites More sharing options...
army2003 Posted October 18, 2018 Author Share Posted October 18, 2018 @Gengik84[/mention] ho fatto un installazione pulita del sistema ho cancellato tutto e reinstallato Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 18, 2018 Administrators Share Posted October 18, 2018 Hai i kext nella efi Link to comment Share on other sites More sharing options...
army2003 Posted October 18, 2018 Author Share Posted October 18, 2018 Quali quelli del wifi no Ha scritto dopo 25 secondi: La efi che ti ho allegato è quella che ho attualmente sul pc Link to comment Share on other sites More sharing options...
Baio77 Posted October 19, 2018 Share Posted October 19, 2018 Gengik intende di togliere anche le Kext x il WI-FI usavi prima e la relativa App , allego Kext aggiornate alla versione attuale , la foto x DCPIManager intendevo era quella di PCI List https://postimg.cc/V0NYv38z"> kexts.zip Link to comment Share on other sites More sharing options...
army2003 Posted October 19, 2018 Author Share Posted October 19, 2018 Ho provato a cambiare la cartella con quella che mi hai allegato ho riavviato ma non la riconosce ancora Link to comment Share on other sites More sharing options...
