army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 Come lo aggiungo ? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 https://postimg.cc/image/vtoobufr5/"> Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 Fatto che devo fare ora Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 Ora avvi gli intel power gadget e lo lasci fermo per qualche minuto, poi magari fai un bechmark e vedi se la CPU riposa e lavora Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 ecco la temperatura a riposo la stessa sia con la batteria che in carica il processore ha il moltiplicatore x29 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 Non va bene, stà andando a palla! però francamente non saprei che consigliarti visto che non conosco bene l'hardware e non ho seguito la messa punto... ora sei con la EFI/Clover di gengik giusto Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 si Ha scritto dopo 38 secondi: ecco Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 Prova a togliere la spunta e Generate C&P states e mettila a plugin type e vedi nuovamente come va Ha scritto dopo 10 minuti 39 secondi: L'SSDT.aml presente in patched l'hai creato tu?! Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 Sto provando Ha scritto dopo 19 secondi: No é stato creato con il programma Ha scritto dopo 4 minuti 49 secondi: Stessa cosa ho messo plugin type senza ssdt e il moltiplicatore sale e scende Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 Hai fatto la prova giusta togliendo l'SSDT e spuntando plugin type (hai fatto senza SSDT anche con C&P states?). Se il moltplicatore sale e scende vuole dire che sta lavorando correttamente, bisogna vedere se a riposo la CPU stà a 900Hz e quando lavora và al massimo e a che temperatura stai a riposo Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 Allora si tutte le prove sono state fatte senza ssdt Ha scritto dopo 20 minuti 54 secondi: questo è a riposo Ha scritto dopo 7 minuti 56 secondi: questo è sotto stress @iCanaro[/mention] secondo te va bene Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted June 26, 2018 Support Team Share Posted June 26, 2018 Rispetto agli altri mi sembra molto ma molto meglio, la CPU lavora, non hai picchi intorno ai 100 gradi come ho visto nell'altro. Al momento sembra sia il miglior risultato ottenuto... :) poi come ogni vero hackintosher che non si crogiola sugli allori, stà sempre all'erta e appena capitano novità da provare con kext, triks o conoscenze maggiori si testa per vedere se possibile migliorare ancora ;) Quel notebook ha mai avuto una bella pulizia alle griglie dei dissipatori soffiandoci NON violentemente aria compressa? Link to comment Share on other sites More sharing options...
army2003 Posted June 26, 2018 Author Share Posted June 26, 2018 Si si le ventole sono pulite ! Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted June 27, 2018 Administrators Share Posted June 27, 2018 Hai installato qualche app? Fai una nuova installazione e con l'attuale EFI con ssdt.. e controlla il discorso dopo aver installato Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted June 28, 2018 Administrators Share Posted June 28, 2018 @army2003[/mention] ho fatto variazioni per la batteria.. sostituisci la EFI però aggiungi in patched il tuo ssdt per il PM Come prima cosa controlla se la batteria continua a funzionare e poi anche il resto EFI.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 1, 2018 Support Team Share Posted July 1, 2018 Mi domandavo se CPUFriend potesse avere una sua utilità per questo hack https://github.com/PMheart/CPUFriend">https://github.com/PMheart/CPUFriend Link to comment Share on other sites More sharing options...
army2003 Posted September 8, 2018 Author Share Posted September 8, 2018 @Gengik84[/mention] No la batteria non funziona Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 8, 2018 Administrators Share Posted September 8, 2018 estrai nuovamente le acpi e allega l'origin Poi non ricordo ma si in apfs? Link to comment Share on other sites More sharing options...
army2003 Posted September 17, 2018 Author Share Posted September 17, 2018 Ho risolto le temperature si sono stabilizzate grazie lo stesso Ora mi chiedo come faccio ad aggiornare a Mac os Mojave? Link to comment Share on other sites More sharing options...
Baio77 Posted September 17, 2018 Share Posted September 17, 2018 Scarichi da App Store l'installar e installi con la solita EFI stai usando adesso ... Controlla la compatibilità della tua VGA e della WI-FI , adesso NON leggo che CPU , VGA e WI-FI monta il tuo PC EDIT Ho letto il topic e vai tranquillo x VGA hai HW recente ... default_wink_anim Link to comment Share on other sites More sharing options...
army2003 Posted September 17, 2018 Author Share Posted September 17, 2018 Si blocca qua Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 17, 2018 Administrators Share Posted September 17, 2018 Fai la foto alla parte precedente o un piccolo video Link to comment Share on other sites More sharing options...
army2003 Posted September 17, 2018 Author Share Posted September 17, 2018 https://wetransfer.com/downloads/150324bee0d456e92407de38959ecc6620180917203556/7c8d576e05e03a34f040d392c318f80f20180917203556/d16e05">https://wetransfer.com/downloads/150324 ... 556/d16e05">https://wetransfer.com/downloads/150324bee0d456e92407de38959ecc6620180917203556/7c8d576e05e03a34f040d392c318f80f20180917203556/d16e05 Ecco non sono riuscito a caricarlo direttamente sulla piattaforma Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted September 17, 2018 Administrators Share Posted September 17, 2018 Che versione di clover stai usando? Sul config è selezionato kernel lapic? Link to comment Share on other sites More sharing options...
army2003 Posted September 17, 2018 Author Share Posted September 17, 2018 Versione 4439 Link to comment Share on other sites More sharing options...
