MACCA Posted January 16, 2021 Share Posted January 16, 2021 Seguito guida iCanaro settaggio bios asRock In più Decodifica sopra 4G - Abilitato Multi-monitor IGPU - Abilitato DVMT Pre-Allocated(iGPU Memory): 64MB Cpu i5 9600k MoBo AsRock Z370M pro4 Rx 560 4GB. M2 nVme 250GB Chiedo se o configurato bene OC E vorrei provare un ssdt by Gengik quale consigliate . iMac_19,1.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 16, 2021 Administrators Share Posted January 16, 2021 Ciao, in caso SSDT-Kaby_Coffelake se prendi quello con dicitura +PM non ti serve altro altrimenti lascia questo e anche ssdt-plug Rimuovi usbinjectall, non usarlo XHCI-unsupported.kext idem, rimuovilo non ti serve Link to comment Share on other sites More sharing options...
MACCA Posted January 16, 2021 Author Share Posted January 16, 2021 (edited) grazie per la risposta. ti allego ioreg con ssdt SSDT-Kaby_Coffelake+PM Edited January 16, 2021 by MACCA Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 16, 2021 Administrators Share Posted January 16, 2021 devi mettere il rename dsm to zdsm Link to comment Share on other sites More sharing options...
MACCA Posted January 16, 2021 Author Share Posted January 16, 2021 ti allego ioreg iMac di Toni.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 16, 2021 Administrators Share Posted January 16, 2021 ora va bene 🙂 Link to comment Share on other sites More sharing options...
mastermiller Posted January 18, 2021 Share Posted January 18, 2021 salve ragazzi potete aiutarmi , ho installato big sur tutto è andatyo bene ma quando devo avviare dal ssd si va in loop su questa schermata EFI.zip la mia config è xt 550 intel i3 8gb ram scheda madre asus Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted January 18, 2021 Support Team Share Posted January 18, 2021 @mastermiller se la mettessi in firma la tua build, sarebbe più idoneo, magari specificando il modello di asus poi perché hai postato qui, visto che la tua build è differente da quella di questo thread? Link to comment Share on other sites More sharing options...
mastermiller Posted January 18, 2021 Share Posted January 18, 2021 ASUS P8H61-M/LX scusami ho posta qui perchè ho visto che hai una scheda video simile alla mia Link to comment Share on other sites More sharing options...
