Asrock TRX40 Creator 3970X threadripper SSd samsung 970 pro 1Tb, 64Gb air cooled, radeon vii
SQA
I this I will have to purchase a external drive adapter for a M.2 ti achieve the cloning process for the mac or laptop, I think I would rather do the laptop for it has catalina and the imac has Mojave, What usb M.2 encloser do you recommend?
I think the real problem is that i don't know how to get the efi folder you sent me on the usb that I have the OS on for it to be properly mounted, as I mention in the beginning I'm a newbie, I did a 1950x couple years ago, got it to work with a good youtube vid, But opencore is totally new to me and I'm lost and uncertain. I think if I can just get the EFI on the usb catalina pen the correct way, I'll get over this hump.
I did also clone the hhd on the laptop, but not sure what to do to get the EFI folder on it either. feeling overwhelmed, feeling close to the goal, but need to find the missing link to get up and running. My ignorance is clear, I need so much more understanding of what I'm doing.
@SQA
do not worry we will win
on your Imac
download clover configurator
then insert USB you have done with Installmaker or the method you use to create a Catalina OSX installer
in clover configurator choose mount EFi and select your USB
put your password if requested
then you will have on your desktop an EFI disk
open it
inside Nothing or an EFI folder
replace it with mine
then you should have a working and booting EFI
i hope
I try python to do the usb and I got it to go into the area to select but the external disk show like something is missing  with a circle with a slash, but for me thats a step ahead, now what?
Hey had a funeral yesterday, I’m going to give it a go today, I’ll download clover and see if I can get your efi folder on the cloned drive 🤞if you have a method the gets the USB created for install that should work, please share step by step detail instructions 🙌
@SQA
From your Imac
1) download instalmaker from our download area
2) download from apple OSX you want to install
3) insert an empty USB pen on your Imac
4) Run InstallMaker app and follow the instructions
it will ask to select an OSX installer (previously downloaded from apple store /site)
then it will ask to choose USB for installation
it will format it and it will put inside all OSX installation files
5) then with Clover Configurator mount the EFI inside in this USB pen
Put my EFI inside it
sorry I cannot explain better of this 🙂
Hey I’m not sure what I did to the usb pin, I was able to get as far as the Mac OS utilities and I formatted the drive for installation and when I go to do the install, it says this copy of the install Mac OS Catalina is damaged and can’t be used to in stall Mac OS, more closer, I’m excited, what can I do from here?
3 minutes ago, SQA said:
When I open the ACPI the folder is empty, is that ok? does it need to have files?
Yes for now
for the error you have it seems usb was built badly
you have to download macOS Catalina again and to do again step above with installMaker app or similar
you have to use an icon called macintosh HD or similar after the first reboot (after first installation step i see above
Then you have called Untitled2 your main OSX disk??? 🙂 🙂
no problem but is weird (untiltled 1 is usually windows)
1 hour ago, SQA said:
You have to insert a kext for your Ethernet
if your keyboard is an usb one I do not know
try to change USB port
to use WiFi or Bluetooth you have also to declare others kext
you have also to build your mmio part....
