Supervisor fabiosun Posted November 1, 2021 Author Supervisor Share Posted November 1, 2021 no problem 🙂 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 5, 2021 Author Supervisor Share Posted November 5, 2021 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 8, 2021 Author Supervisor Share Posted November 8, 2021 Basemark GPU Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted December 29, 2021 Author Supervisor Share Posted December 29, 2021 all is fine as usual (we can say! 🙂 🙂 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted February 26, 2022 Author Supervisor Share Posted February 26, 2022 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 19, 2022 Author Supervisor Share Posted April 19, 2022 (edited) First 18's beta is out It seems fine! 🙂 new features video Edited April 19, 2022 by fabiosun 1 Link to comment Share on other sites More sharing options...
Arrakis Posted April 19, 2022 Share Posted April 19, 2022 Yes, I'll be sure to test...😃 1 Link to comment Share on other sites More sharing options...
Arrakis Posted June 8, 2022 Share Posted June 8, 2022 Beta 3 Resolve 18 works perfectly on Ventura. While it is not yet validated for Ventura. It bodes well. 1 Link to comment Share on other sites More sharing options...
Arrakis Posted July 28, 2022 Share Posted July 28, 2022 Installed Resolve 18.0.1 without issue under Ventura beta 4. 1 Link to comment Share on other sites More sharing options...
Giaccaz Posted August 2, 2022 Share Posted August 2, 2022 (edited) tried now with metal Edited August 2, 2022 by Giaccaz Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted August 2, 2022 Author Supervisor Share Posted August 2, 2022 @Giaccazin English please 🙂 have you unlocked project settings/set metal/saved and realaunched completely the app? if so it is a good result for your system! Link to comment Share on other sites More sharing options...
Giaccaz Posted August 2, 2022 Share Posted August 2, 2022 (edited) i followed the video you posted at the head of the thread. loaded the project, set metal , saved, closed and restarted davvinci. Edited August 2, 2022 by Giaccaz 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted August 2, 2022 Author Supervisor Share Posted August 2, 2022 2 minutes ago, Giaccaz said: i followed the video you posted at the head of the thread. loaded the project, set metal , saved, closed and restarted davvinci. also this is mandatory to unlock frame rate if your GPU could go faster than 24 FPS for sure with only 6 nodes it can go faster 2 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted November 11, 2022 Author Supervisor Share Posted November 11, 2022 on macOS Ventura 13.1b2 and 13.01 Candle Benchmark: 6 TRN Nodes 41 66 Blur Nodes 31 3 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 27, 2023 Author Supervisor Share Posted January 27, 2023 Davinci Resolve Benchmark with new rig in my signature: 6TRN node 49 fps 66 Blur nodes 32 FPS 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 28, 2023 Author Supervisor Share Posted January 28, 2023 On 5/18/2021 at 3:12 PM, fabiosun said: OpenCl is not supported well from Apple but these are my 6900xt results Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 27, 2023 Author Supervisor Share Posted April 27, 2023 (edited) app is starting fine with AMD cpu also in new beta Candle Benchmark: 6TRN node 49 fps 66 Blur nodes 33 FPS Edited April 27, 2023 by fabiosun 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted May 15, 2023 Author Supervisor Share Posted May 15, 2023 I updated my GPU to 6950 xt Candle Benchmark: 6TRN node 50 fps 66 Blur nodes 34 FPS Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 22, 2023 Author Supervisor Share Posted September 22, 2023 18.6 and Sonoma 🙂 🙂 on AMD 7950x 2 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted September 23, 2023 Author Supervisor Share Posted September 23, 2023 new Maxon Cinebench (in OSX Sonoma GPU benchmark does not work in my system) 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 27, 2023 Author Supervisor Share Posted October 27, 2023 macOS Sonoma 14.2 B1 66 nodes 35fps 6 TRN nodes 51fps 1 Link to comment Share on other sites More sharing options...
Arrakis Posted April 18, 2024 Share Posted April 18, 2024 (edited) Installing and using Resolve 19 Beta1. Works perfectly with Sonoma 14.4.1. @fabiosunI can no longer upload an image to your site. I have a message with a maximum weight limitation of 1,878 kB, Return to the prehistory of the internet 😂🤣 Edited April 21, 2024 by Arrakis 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted April 18, 2024 Author Supervisor Share Posted April 18, 2024 @Arrakisis not my forum🥹 @Gengik84will check as soon as he can Link to comment Share on other sites More sharing options...
Arrakis Posted July 14, 2024 Share Posted July 14, 2024 Resolve beta 4 still good with Sequoia beta 3. 2 Link to comment Share on other sites More sharing options...
Arrakis Posted July 25, 2024 Share Posted July 25, 2024 Resolve beta 5 still good with Sequoia beta 4. 1 Link to comment Share on other sites More sharing options...
