Marco_ Posted January 2, 2021 Share Posted January 2, 2021 (edited) Ciao, ho installato macOS Big Sur sul mio portatile ma non vanno trackpad (i2C) e tastiera (PS/2) i3 7130U Intel HD graphics 630 EFI.zip Edited January 5, 2021 by Marco_ ho aggiunto kext intel Link to comment Share on other sites More sharing options...
Administrators Solution Gengik84 Posted January 2, 2021 Administrators Solution Share Posted January 2, 2021 Ciao, ma senza vedere nulla, come si potrebbe aiutarti? Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 scusa...ti ho allegato la EFI Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 5, 2021 Administrators Share Posted January 5, 2021 se non li aggiungi definendoli sul config, non verranno mai caricati quindi normale che non funzionino Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 Non lo so fare Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 5, 2021 Administrators Share Posted January 5, 2021 Guarda come sono definiti l'altri kext sul config e fai lo stesso per quelli mancanti Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 Potresti farmelo te? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 5, 2021 Administrators Share Posted January 5, 2021 Devi imparare però, non puoi sempre dipendere da qualcuno per queste operazioni che sono di base in hackintosh sostituisci il config e prova config.plist.zip Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 Mi da memory panic Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 5, 2021 Administrators Share Posted January 5, 2021 memory panic? non ho toccato driver etc Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 Ti mando la foto Link to comment Share on other sites More sharing options...
Marco_ Posted January 5, 2021 Author Share Posted January 5, 2021 IMG_8403.HEIC.zip Link to comment Share on other sites More sharing options...
