Hackintosh dual boot su Hp pavilion 15-bc200nl
checco_99
Ciao a tutti. Vorrei fare il mio primo hackintosh sul pc in questione. Vi chiedo quale versione di mac os convenga installare e come fare. Vi invio le specifiche. Inoltre allego una cartella trovata su un sito che contiene dei file utilizzati su un portatile hp con scheda tecnica praticamente identica, non so se possono essermi utili e vi chiedo nel caso come possa usarli.
Processor series    Intel Core i7-7700 Mobile Series
Processor family   7th gen Intel Core i7
Processor frequency   2.8 GHz
Motherboard chipset     Intel HM175
Processor boost frequency   3.8 GHz
Processor codename      Kaby Lake
Thermal Design Power (TDP)   45 W
Processor model     i7-7700HQ
Processor cores    4
Processor threads    8
Processor cache    6 MB
Processor lithography   14 nm
Processor socket   BGA 1440
Internal memory type   DDR4-SDRAM
Internal memory    16 GB
Memory clock speed     2400 MHz
Memory layout (slots x size)   2 x 8 GB
On-board graphics adapter    Y
On-board graphics adapter family    Intel HD Graphics
Discrete graphics memory type     GDDR5
On-board graphics adapter DirectX version   12.0
Discrete graphics adapter   Y
On-board graphics adapter model    Intel HD Graphics 630
Discrete graphics adapter model    NVIDIA GeForce GTX 1050
On-board graphics adapter base frequency    350 MHz
On-board graphics adapter dynamic frequency (max)   1100 MHz
Maximum on-board graphics adapter memory   64 GB
On-board graphics adapter OpenGL version    4.4
Discrete graphics adapter memory   2 GB
Total storage capacity    1128 GB
Number of SSDs installed   1
SSD capacity   128 GB
Total SSDs capacity   128 GB
Number of HDDs installed  1
HDD capacity   1000 GB
HDD speed   7200 RPM
HDD size   2.5"
SSD interface   M.2
HDD interface   SATA
Total HDDs capacity    1000 GB
Compatible memory cards   SD
Card reader integrated    Y
Storage media     HDD+SSD
Ethernet LAN    Y
Ethernet LAN data rates    10, 100, 1000 Mbit/s
Wi-Fi   Y
Wi-Fi standards   Wi-Fi 5 (802.11ac)
Bluetooth  Y
Bluetooth version   4.2
4G  N
3G  N
USB 3.2 Gen 2 (3.1 Gen 2) Type-A ports quantity   1
Charging port type    DC-in jack
DVI port    N
Docking connector  N
Combo headphone/mic port  Y
USB 2.0 ports quantity  1
HDMI ports quantity   1
Ethernet LAN (RJ-45) ports  1
HP-OMEN-AX205-HACKINTOSH-mojave.zip
Sto provando a installare catalina su una partizione di hard disk. In pratica su ssd rimane installato Windows, una metà di hdd contiene i dati di Windows, l’altra metà dovrebbe contenere Mac OS. Sto scaricando catalina tramite macchina virtuale. Potete fornirmi una guida per fare il resto? Inoltre la cartella allegata all’inizio della discussione dovrò usarla in qualche modo?
Sto seguendo la guida nella creazione della usb, sono arrivato con non poche difficoltà (maledetta macchina virtuale) a installare sulla chiavetta Mac OS catalina, ora sto installando clover. Ho scaricato l’ultima versione disponibile, ma non trovo osxaptiofix3drv da spuntare. Inoltre allego le immagini del bios, dato che non vedo le solite cose da modificare.
Si ho un ssd dove sta Windows, è un hdd con una partizione con i dati di Windows è un’altra metà dove volevo mettere macOS . Se dovessi formattare tutti il disco, poi potrei partizionarlo comunque e usarne una metà per i dati di Windows? L’ssd è solo da 128gb.
Edited by checco_99
