ASUS Zenith Extreme II 3960x [Help]
cleverhome
  On 3/30/2022 at 2:19 PM, fabiosun said:
Have you disabled both ethernet card in bios
also in my rig with ethernet card enabled I have a freeze in login stage or after few seconds after login
Expand
Yes, I did. So my conclude is that stay with Big Sur and wait for OC till they can do something more with Monterey.
Here're latest update after reinstall BigSur with some refinements
Is it good?😅
Hi @fabiosun
A gently ask for help,
I facing
PCI: There was an error while gathering PCI device information (Before it shows properly (exactly this EFI, somehow I reset NVRAM and all gone, try many times but no way to get its shown again)
Profiles: ** Error ** *** -[__NSDictionaryM setObject:forKey:]: object cannot be nil (key: _name):
Please help,
And I would like to hide The UEFI Shell, I would like to hide it, just leave only ResetNVRAM,
also there's SystemRESET.efi but it not show, would you mind to have a look into my EFI and tell me what wrong.
Thanks bro,
EFI.zipFetching info...
@cleverhomeI can't recognize this EFI and I think it is not a our product 🙂
I see a DSDT.aml?
Why?
Then you do not have enabled reset system in your config and also config.plist has some error
check in bottom part if you see a button
Edited by fabiosun
Yes, this EFI is not the EFI you gave me, someone help me to refine the EFI your to be this one, I works well, (some like generic SSD be come Apple SSD…), and I don’t have to declare Device Properties but it still show correctly.
I just don’t like the way he leave advertising words on the boot screen, so I do replaced all the .efi (Opentime, Boot, Opencannopy…), the advertising disappeared, and some errors occurred as well, the ACPI some how, I don’t know, he said that he complied all the files to be 2 *.aml.
I just wanna try can I get it better, but I don’t think I do need another advertisement on my screen again.
Please help me.
Sorry @cleverhome
i am not confident with dsdt and I think we do not need of it
i do not know also what you achieve with it declared
so I can’t say more
in My system I have no those errors you show above in profile and pci tabs
maybe it is better to ask help to the guy who prepared for you this EFi
  • 4 weeks later...
Hi @fabiosun
I'm come back with good news, as I promised myself I can't give up.
Have been asked the guy who helped me, but the result came no joy.
I know that I must help myself,
What did I tried:
Changed (again) all PCI Slots -failed
Changed to another adapter TP-Link T9E Archer (native in BS) - failed
Replaced the memo original slot M.2 NGFF (Intel) with BRCM493602CS - failed
Apple Orginal Wifi card with M.2 adapter - failed.
Then, it must be st concern my mono and Monterey - I told myself.
I started from scratch again,
https://github.com/luchina-gabriel/BASE-EFI-AMD-RYZEN-THREADRIPPER my EFI reference - Credit to luchina (because with this config I get higher bench score in Bigsur ), you can have a look in it, I don't know much in detail of the config file.)
Use the DSDT (with it, I can boot from OC Picker to my Windows and the Windows works as it should, with SSDT some functions is disabled)
Your MMIO - Thanks to you, without your MMIO, my system is nothing.
and finally, what I figure out that not because of my mb, Monterey change something which mentioned here https://github.com/acidanthera/AirportBrcmFixup
  • brcmfx-delay delays start of native broadcom driver for specified amount of milliseconds. It can solve panics or missing wi-fi device in Monterey. You can start with 15 seconds (brcmfx-delay=15000) and successively reduce this value until you notice instability in boot."
which I've never notice, since I keep thinking the fenviT919 should works natively.
ForceAquantiaEthernet= Truefor Aquantia ethernet.
added AirportBrcmFixup with boot-arg as attached , and Whooala....
My case is 7000 (7s)
I started for weeks for fixing it, and this last chapter started at 19:00PM last night, now is 12:30PM overhear, but yeah, this morning is a nice morning with bird songs.
Again, thanks for your all kindness and help, you are the first who helped me and the only one I report my case.
grazie mille ðŸ¥°
Here are mine
Edited by cleverhome
  • 3 months later...
  On 4/29/2022 at 5:39 AM, cleverhome said:
Hi @fabiosun
What did I tried:
grazie mille ðŸ¥°
Here are mine
Expand
Can you share your EFI. I'm trying to get my Aquantia and Fenvi T919 working on my Zenith II Extreme . Can you also export to Bios config  and also share it .
