Dennis0_o Posted October 20, 2020 Share Posted October 20, 2020 Ciao, quando avvio la mia USB da OpenCore, in verbose mode mi appare questo errore, ossia "Legacy shim 2", sapete aiutarmi? Grazie. Vi lascio allegato la cartella di OC e l'errore. OC.zip Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 @Gengik84 non riesci a darmi un aiuto veloce? Link to comment Share on other sites More sharing options...
Administrators Solution Gengik84 Posted October 20, 2020 Administrators Solution Share Posted October 20, 2020 Ciao, hai FakeSMC che ti crea problemi o metti la versione di Slice oppure passi a virtualSMC Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 (edited) 5 minuti fa, Gengik84 ha scritto: Ciao, hai FakeSMC che ti crea problemi o metti la versione di Slice oppure passi a virtualSMC Edited October 20, 2020 by Dennis0_o Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 (edited) 5 minuti fa, Gengik84 ha scritto: Ciao, hai FakeSMC che ti crea problemi o metti la versione di Slice oppure passi a virtualSMC ho fatto diverse prove in precedenza e ho già provato a mettere virtualsmc ed invece di fermarsi su fakesmc si ferma su virtual. Non so più cosa provare. dove le trovo le versioni di slice? Edited October 20, 2020 by Dennis0_o Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 ma avvii un installer o una installazione fatta? Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 1 minuto fa, Gengik84 ha scritto: ma avvii un installer o una installazione fatta? si avvio da opencore Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 (edited) 16 minuti fa, Gengik84 ha scritto: Ciao, hai FakeSMC che ti crea problemi o metti la versione di Slice oppure passi a virtualSMC ho messo slice e ora mi da questo errore.. Edited October 20, 2020 by Dennis0_o Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 fai una foto più da vicino Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 2 minuti fa, Gengik84 ha scritto: fai una foto più da vicino Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 hai problemi a fake, quale versione hai? Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 2 minuti fa, Gengik84 ha scritto: hai problemi a fake, quale versione hai? non lo so, trovo solo klozlek, e non so dove trovare slice. se riesci a passarmi tu qualcosa adatto al mio hardware posso provare, grazie. Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 9 minuti fa, Gengik84 ha scritto: hai problemi a fake, quale versione hai? ho controllato la versione ed è 3.5.0 credo Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 https://github.com/CloverHackyColor/FakeSMC3_with_plugins/releases Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 Adesso, Gengik84 ha scritto: https://github.com/CloverHackyColor/FakeSMC3_with_plugins/releases copio ogni file dentro kext? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 io metterei solo fakesmc Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 24 minuti fa, Gengik84 ha scritto: hai problemi a fake, quale versione hai? ho messo un 'altra versione di fakesmc e mi da questo Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 20, 2020 Author Share Posted October 20, 2020 (edited) 44 minuti fa, Dennis0_o ha scritto: @Gengik84 mettendo Fakesmc che mi hai detto te mi da questo errore, secondo me è un problema di bios magari Edited October 20, 2020 by Dennis0_o Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 20, 2020 Administrators Share Posted October 20, 2020 prova a estrarre le acpi, anche se non dovrebbe servire appena riesco guardo Link to comment Share on other sites More sharing options...
Dennis0_o Posted October 23, 2020 Author Share Posted October 23, 2020 Il 20/10/2020 at 17:49, Gengik84 ha scritto: prova a estrarre le acpi, anche se non dovrebbe servire appena riesco guardo ciao come faccio ad estrarre acpi???? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 24, 2020 Administrators Share Posted October 24, 2020 Il 23/10/2020 at 09:44, Dennis0_o ha scritto: ciao come faccio ad estrarre acpi???? leggi nella sezione regolamento, richiesta di supporto Link to comment Share on other sites More sharing options...
