Nvidia gt620
boupojp
Hi, thank you for your reply. I know that gt710 supports metal, but I don't say if gt620 do! Let's hope!
I have successfully installed mojave on the i7 920 computer, but to install it I must change my graphics card (an old radeon hd4650) because of boot loop.
Now, I want to try if, after install, my hackintosh starts with gt620, but I need some kext.
Do you know where I can find these kexts?
Edited by boupojp
Do you mean for graphics card?
WhateverGreen.kext maybe it's enough...
if you use clover, in case try with or w/o inject nvidia
ok
Adesso, boupojp ha scritto:
I have installed WhateverGreen.kext.
Whats do you mean?
copy and paste into EFI's folder and not in system folder like at /Library/Extension or /System/Library/Extension
Btw... don't forget lilu too
Yes yes, of course!
Also lilu is in /EFI folder.
Thanks for your help!
