Asus z490m i5-10600k iGpu Opencore Catalina
the77joker
Sostituisci nuovamente
apri il terminale e scrivi
sudo kextcache -i /
quando ha finito riavvia
se non andasse ancora, sul config, parte NVram/Add/7C436110-AB2A-4BBB-A880-FE41995C9F82/boot-arg
trovi alcid=1 qui devi provare tutti l'altri layout compatibili per il tuo codec, ossia i "numeri"  che vedi nella foto che hai allegato alcuni post indietro
quindi esempio
alcid=5
etc etc...
ovviamente una modifica alla volta, salvi e riavvii
Archivio 2.zip
sudo kextcache -i /
niente
quindi esempio
alcid=5
etc etc...
provati tutti uno alla volta, niente
1 hour ago, iCanaro said:
none
ho citato guida audio in firma mia e system search.... segui le briciole
system search mi da questo
Binary file /System/Library/Extensions/AppleGFXHDA.kext/Contents/MacOS/AppleGFXHDA matches
Binary file /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/AppleLegacyUSBAudio.kext/Contents/MacOS/AppleLegacyUSBAudio matches
Binary file /System/Library/Extensions/AppleHDA.kext/Contents/MacOS/AppleHDA matches
Binary file /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAController.kext/Contents/MacOS/AppleHDAController matches
Binary file /System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortBrcm4360.kext/Contents/MacOS/AirPortBrcm4360 matches
Binary file /System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirPortBrcmNIC.kext/Contents/MacOS/AirPortBrcmNIC matches
mentre audio codec info
+ Codec: codecs
to
+ AppleALC
Checking GPUs and Audio...
Matched Device: IGPU
IGPU is already named correctly
  IGPU has property hda-gfx = <"onboard-1">
IGPU address is PciRoot(0x0)/Pci(0x2,0)
for more information, read the wiki
use it if you need to inject properties
gfxutil
gfxutil -f HDEF
DevicePath not found!
gfxutil
00:00.0 8086:9b53 /PCI0@0/pci8086,9b53@0 = PciRoot(0x0)/Pci(0x0,0x0)
00:02.0 8086:3e9b /PCI0@0/IGPU@2 = PciRoot(0x0)/Pci(0x2,0x0)
00:14.0 8086:06ed /PCI0@0/XHC@14 = PciRoot(0x0)/Pci(0x14,0x0)
00:14.2 8086:06ef /PCI0@0/pci8086,6ef@14,2 = PciRoot(0x0)/Pci(0x14,0x2)
00:15.0 8086:06e8 /PCI0@0/I2C0@15 = PciRoot(0x0)/Pci(0x15,0x0)
00:15.1 8086:06e9 /PCI0@0/I2C1@15,1 = PciRoot(0x0)/Pci(0x15,0x1)
00:16.0 8086:06e0 /PCI0@0/IMEI@16 = PciRoot(0x0)/Pci(0x16,0x0)
00:17.0 8086:06d2 /PCI0@0/SAT0@17 = PciRoot(0x0)/Pci(0x17,0x0)
00:1b.0 8086:06c0 /PCI0@0/RP17@1B = PciRoot(0x0)/Pci(0x1B,0x0)
00:1c.0 8086:06b8 /PCI0@0/RP01@1C = PciRoot(0x0)/Pci(0x1C,0x0)
00:1d.0 8086:06b0 /PCI0@0/RP09@1D = PciRoot(0x0)/Pci(0x1D,0x0)
00:1f.0 8086:0685 /PCI0@0/LPCB@1F = PciRoot(0x0)/Pci(0x1F,0x0)
00:1f.4 8086:06a3 /PCI0@0/SBUS@1F,4 = PciRoot(0x0)/Pci(0x1F,0x4)
00:1f.5 8086:06a4 /PCI0@0/pci8086,6a4@1F,5 = PciRoot(0x0)/Pci(0x1F,0x5)
00:1f.6 8086:0d4d /PCI0@0/GLAN@1F,6 = PciRoot(0x0)/Pci(0x1F,0x6)
03:00.0 c0a9:5403 /PCI0@0/RP09@1D/PXSX@0 = PciRoot(0x0)/Pci(0x1D,0x0)/Pci(0x0,0x0)
Edited by the77joker
ok trovato era disattivato dal bios che stupido a non averci pensato
+ Codec: ALC887-VD
+ AppleALC Supported layouts: 1, 2, 3, 5, 7, 11, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
2 minutes ago, iCanaro said:
HDEF risulta proprio mancante; hai verificato nel BIOS che l'audio sia attivato? e hai ultimo BIOS?
vedi mio messaggio precedente. grazie mille 😀
(sono stato uno stupido a non pensarci subito)
adesso pero' devo farlo funzionare
ho visto tuo messaggio, il mio ho finito di scriverlo e postarlo pochi secondi dopo il tuo....
eh si! altrimenti arrivano loro
  • whahahah 1
ok fatto
ho rimesso il solo SSDT-Basic rimuovendo SSDT-Audio che mi aveva fatto gentilmente @Gengik84  e ad ora ho un hack semplice e pulito. mi pare funzioni tutto.
ho provato tutte le porte usb e vanno. ho provato anche il card reader su usb-c e funziona.
tutto sommato non é stato neanche troppo difficile o incasinato, grazie a voi.
domani vado in ferie un paio di settimane e al rientro monto la fenvi cosi avro anche il wifi e il BT
edit: audio frontale non va 😅
prova altri layout
di solito i migliori sono 1 e 7
ma provali sino a che non trovi quello più idoneo
grazie a SSDT e app di gengik e guide che trovi qui... diventa tutto relativamente molto più facile 😉
Allora piccolo aggiornamento nel caso altri siano interessati o abbiano la stessa scheda madre o configurazione
ASUS Prime Z490m PLUS
EFI Vanilla con SSDT-Basic
Disco NVME: ok W 1800MB/s | R 2000MB/s
iGPU su hdmi: ok | accelerazione hw é attiva e H.264 H.265 sono supportati
LAN: ok (con Meize/intelimausethernet)
USB posteriore (USB-2 USB-3 e USB-C) : ok (ma non ancora ho testato la velocità)
Audio posteriore: ok
Audio frontale: non va (devo provare altri layout, ho provato solo 1 e 7)
WiFi: no (tra due settimane mi arriva la Fenvi)
BT: no (tra due settimane mi arriva la Fenvi)
Sensori HW: ok aggiungendo SMCProcessor SMCSuperIO
Spegnimento: ok
Sleep: non testato
Monitor in sleep: non resuscita, devo smanettare nel OSD del monitor cambiando ingresso.
Edit: la build mi sembra stabile, oggi ho spostato alcune centinaia di GB e testato alcuni sw, la macchina è accesa da stamattina senza intoppi. Si accende e spegne in fretta.
CPU 35 gradi
Cinebench e geekbench mi danno risultati coerenti con la mia configurazione HW.
Il sensore dice che la GPU è utilizzata a 0% anche durante cinebench 🤔 almeno la CPU è salita sopra i 50 gradi 😄
Tra un paio di settimane proverò anche ad overclocckare tanto per divertirmi.
Arrivata la fenvi T919
Wifi: ok
BT: ok
Una nota: l'ho montata nella seconda PCI 16 per lasciare spazio alla GPU che deve arrivare a giorni e funziona benissimo.
Montate anche 2 ventole noctua 140mm frontali
1 noctua 120mm posteriore
Tutte pwm
Insieme alla già montata noctua 15s sulla CPU ho un sistema molto silenzioso.
Arrivato anche il monitor BenQ per fotografia.
che versione di cinebench usi?
per testare la GPU dovresti usare la versione cinebench 15 e non la 20
non so se si applica anche sulle integrate
Edited by fabiosun
