Asus z490m i5-10600k iGpu Opencore Catalina
the77joker
Ciao sono al mio primo hackintosh, sto usando opencore 0.6.1.
mi sono imbattuto in questo problema macserial non mi genera un seriale per iMac20,1 mentre con 19,1 funziona.
sulla guida per il mio i5 10600k suggerisce iMac20,1
Ho provato iMac19,1generato seriale e uuid per iMac19,1 ma non partiva, allora ho semplicemente cambiato iMac19,1 con iMac20,1 ed é andato avanti un altro po', ma adesso ho lo schermo nero.
Suggerimenti?
ho seguito i passaggi sulla guida:
Note: GenSMBIOS has not been updated to reflect the new repo of MacSerial, to resolve issues with generating iMac20,x, you'll need to do the following:
  • Downloaded the latest release of OpenCorePkg
  • Navigate to Utiltiies/macserial/ folder and grab either the macserial or macserial.exe file(.exe is for Windows)
  • Run chmod +x /path/to/macserial if you're in a Unix environment, otherwise GenSMBIOS will throw a permissions error
  • Place this macserial executable under GenSMBIOS's Scripts folder
questo il log
Quote
00:000 00:000 AAPL: [EB|#LOG:INIT] 2020-09-09T15:59:41
00:023 00:023 AAPL: [EB|#VERSION] bootbase.efi 422.140.3~2 (Official), built 2020-06-07T17:23:12-0700
00:072 00:048 AAPL: [EB|#BUILD] BUILD-INFO[306]:{"DisplayName":"bootbase.efi","DisplayVersion":"422.140.3~2","RecordUuid":"D49FA16E-32C0-433B-A742-7405C713BE39","BuildTime":"2020-06-07T17:23:12-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"422.140.3","BuildVersion":"2","BuildConfiguration":"Release","BuildType":"Official"}
00:095 00:023 AAPL: [EB|#H:IS] 0
00:119 00:023 AAPL: [EB|#WL:MODE] 0
00:142 00:023 AAPL: [EB|#CONFIG:SRC] <default>
00:166 00:023 AAPL: [EB|#CONFIG| 0] boot-save-log : 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) <default>
00:189 00:023 AAPL: [EB|#CONFIG| 1] wake-save-log : 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) <default>
00:213 00:023 AAPL: [EB|#CONFIG| 2] console       : 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) <default>
00:237 00:024 AAPL: [EB|#CONFIG| 3] serial        : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:261 00:024 AAPL: [EB|#CONFIG| 4] embed-log-dt  : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:285 00:023 AAPL: [EB|#CONFIG| 5] timestamps    : 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) <default>
00:308 00:023 AAPL: [EB|#CONFIG| 6] log-level     : 0x0000000000000001 (0x0000000000000001 & 0x0000000000000001) <default>
00:331 00:023 AAPL: [EB|#CONFIG| 7] breakpoint    : 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) <default>
00:355 00:023 AAPL: [EB|#CONFIG| 8] kc-read-size  : 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) <default>
00:378 00:023 AAPL: [EB|#H:IS] 0
00:402 00:023 AAPL: [EB|#WL|0] 0x01 0x01   0 0x00
00:425 00:023 AAPL: [EB|#BRD:NV] Mac-CFF7D910A743CAAF
00:473 00:048 AAPL: [EB|#WL|1] 0x01 0x01   2 0x00
00:497 00:023 AAPL: [EB|`BST:IDT] {
00:520 00:023 AAPL: [EB|`BST:IDT] }
00:544 00:024 AAPL: [EB|#WL|2] 0x01 0x01   3 0x00
00:568 00:023 AAPL: [EB|#WL|3] 0x01 0x01   4 0x00
00:591 00:023 AAPL: [EB|#BRD:NV] Mac-CFF7D910A743CAAF
00:615 00:023 AAPL: [EB|#WL|4] 0x01 0x01   5 0x00
00:639 00:024 AAPL: [EB|`H:CHK] BM: 0x0000000000000000
00:663 00:024 AAPL: [EB|`H:CHK] Err(0xE) @ GV boot-signature
00:687 00:023 AAPL: [EB|#WL|5] 0x01 0x01  23 0x0E
00:710 00:023 AAPL: [EB|`H:CPM] Err(0xE), (24, 24) @ GV Persistent-memory-note
00:735 00:024 AAPL: [EB|#SB:P] 0x0
00:759 00:023 AAPL: [EB|#LIMG:DP] Acpi(PNP0A03,0)/Pci(14|0)/Usb(15, 0)/HD(Part2,Sig28845735-8C11-45BF-8AD3-9E3AA92E834D)
00:782 00:023 AAPL: [EB|#LIMG:FP] \System\Library\CoreServices\boot.efi
00:806 00:023 AAPL: [EB|#LIMG:OPT] ()
00:830 00:024 AAPL: [EB|#RPS] R?0 P?0 S?0
00:881 00:050 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:904 00:022 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\com.apple.Boot.plist, DP: 0
00:929 00:025 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:953 00:023 AAPL: [EB|`OPT:LXF] Err(0xE) @ 'LF
00:977 00:023 AAPL: [EB|`OPT:LXF] 'LF (Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist)
01:000 00:023 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist, DP: 0
01:033 00:033 AAPL: [EB:#KF] (root-dmg=file:///Install%20macOS%20Catalina.app/Contents/SharedSupport/BaseSystem.dmg)
01:057 00:023 AAPL: [EB|#MBA:CL] ()
01:080 00:023 AAPL: [EB|#MBA:NV] (-v keepsyms=1 debug=0x100 alcid=1)
01:104 00:023 AAPL: [EB|#MBA:KF] (root-dmg=file:///Install%20macOS%20Catalina.app/Contents/SharedSupport/BaseSystem.dmg)
01:127 00:023 AAPL: [EB|#MBA:OUT] (-v keepsyms=1 debug=0x100 alcid=1 root-dmg=file:///Install%20macOS%20Catalina.app/Contents/SharedSupport/BaseSystem.dmg)
01:151 00:023 AAPL: [EB|#LOG:VERBOSE] 2020-09-09T15:59:43
01:174 00:023 AAPL: [EB|#OPT:BM] 0x4082
01:198 00:023 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\PlatformSupport.plist)
01:221 00:023 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
01:250 00:028 AAPL: [EB|#B:VAw]
01:297 00:047 AAPL: [EB|#P:CPR] N
01:321 00:023 AAPL: [EB|#P:MPI] N
01:344 00:023 AAPL: [EB|#P:BPI] N
01:368 00:024 AAPL: [EB|`CS:CSKSD] {
01:392 00:024 AAPL: [EB|`CS:CSKSD] Err(0xE) @ GV 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF:boot-info-payload
01:416 00:023 AAPL: [EB|`G:CS] } Ok(0)
01:440 00:023 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
01:497 00:057 AAPL: [EB|`B:SBS] SZ: 621112
01:524 00:026 AAPL: [EB|#B:SHA] 4f3bba9614aa0dbae1943ab55b83beac7e278986
01:547 00:023 AAPL: [EB|`WL:PWLFNV] Err(0xE) @ GV wake-failure
01:571 00:023 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFNV
01:595 00:023 AAPL: [EB|`WL:PWLFRTC] ! @ RTC:R
01:618 00:023 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFRTC
01:642 00:023 AAPL: [EB|`LD:LKC] BPDK -> (System\Library\PrelinkedKernels\prelinkedkernel.development)
04:634 02:992 AAPL: [EB|`LD:LKFS] } Ok(0)
04:658 00:024 AAPL: [EB|`LD:LKC] } Ok(0)
04:709 00:050 AAPL: [EB|#FWFM] 0xFFDFFF7F
04:732 00:023 AAPL: [EB|#FWFT] 0xFD8FF576
04:756 00:023 AAPL: [EB|#CSR:IN] 0x00000040
04:780 00:024 AAPL: [EB|#CSR:OUT] 0x00000040
04:806 00:026 AAPL: [EB|`BST:FBS] {
04:829 00:023 AAPL: [EB|`BST:FBS] BA.ADSZ: 0
04:853 00:023 AAPL: [EB|`BST:FBS] BA.KSDSZ: 0
04:878 00:024 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
04:902 00:024 AAPL: [EB|#LOG:DT] 2020-09-09T15:59:46
04:926 00:023 AAPL: [EB|#LOG:EXITBS:START] 2020-09-09T15:59:46
scusate se ho omesso dei dettagli é il mio primo vero post su problemi
Edited by the77joker
Ok ho un problema, la LAN non va. macOs non me la rileva.
ancora non mi é arrivata la Fenvi quindi sono senza internet
la mia asus Z490m ha una intel i219-v
ho usato IntelMausiEthernet.kext
22 minutes ago, iCanaro said:
ora attiva la grafica
cioè? ho solo la iGpu non ho ancora comprato la gpu.
ma va? pensavi che non me ne fossi accorto?  quanti mb di vram indica la tua UHD630
ora non sto a ripetere qui quanto ho scritto qua
https://www.macos86.it/topic/3415-hackintosh-con-ethernet-non-funzionante/
la minestra è simile, quindi valgono le stesse cose
2 ore fa, the77joker ha scritto:
sto usando opencore 6.1.
0.6.1
deve ancora uscire la 1.0 stable
stai usando una EFI recuperata sul web, ho hai fattto tutto da solo seguendo qualche guida?
0.6.1
Vado subito a leggere l'articolo grazie ☺️
Giusto 0.6.1 ho scritto male.
EFI fatta da me leggendo la guida e vari video. Ho anche scaricato EFI fatte da altri su Asus z490 anche se i modelli di scheda sono diversi, li ho usati per comparazione.
In ultimo ho testato il tutto con opencore slowgeek
Riguardo alla vram ti rispondo domani 14MB
Grazie mille
21 hours ago, iCanaro said:
usa unicamente SSDT-Basic che trovi in download
fatto or ora. nessun miglioramento:
senza -igfxvesa va in KP
no audio
log
panic(cpu 10 caller 0xffffff7f82dbc72f): assertmsg@/Library/Caches/com.apple.xbs/Sources/GPUDriversIntel/GPUDriversIntel-14.7.8/IONDRV/CFL/AppleIntelFramebuffer/AppleIntelController.cpp:29098
Backtrace (CPU 10), Frame : Return Address
0xffffff83adacba10 : 0xffffff800031a65d mach_kernel : _handle_debugger_trap + 0x49d
0xffffff83adacba60 : 0xffffff8000454a75 mach_kernel : _kdp_i386_trap + 0x155
0xffffff83adacbaa0 : 0xffffff80004465fe mach_kernel : _kernel_trap + 0x4ee
0xffffff83adacbaf0 : 0xffffff80002c0a40 mach_kernel : _return_from_trap + 0xe0
0xffffff83adacbb10 : 0xffffff8000319d27 mach_kernel : _DebuggerTrapWithState + 0x17
0xffffff83adacbc10 : 0xffffff800031a117 mach_kernel : _panic_trap_to_debugger + 0x227
0xffffff83adacbc60 : 0xffffff8000ac1abc mach_kernel : _panic + 0x54
0xffffff83adacbcd0 : 0xffffff7f82dbc72f
0xffffff83adacbce0 : 0xffffff7f82d60ecd
0xffffff83adacbd50 : 0xffffff7f82d5d543
0xffffff83adacbde0 : 0xffffff8000a075c6 mach_kernel : __ZN9IOService14startCandidateEPS_ + 0xf6
0xffffff83adacbe40 : 0xffffff8000a07101 mach_kernel : __ZN9IOService15probeCandidatesEP12OSOrderedSet + 0xad1
0xffffff83adacbef0 : 0xffffff8000a0649e mach_kernel : __ZN9IOService14doServiceMatchEj + 0x2de
0xffffff83adacbf50 : 0xffffff8000a08c56 mach_kernel : __ZN15_IOConfigThread4mainEPvi + 0x186
0xffffff83adacbfa0 : 0xffffff80002c013e mach_kernel : _call_continuation + 0x2e
BSD process name corresponding to current thread: kernel_task
Boot args: -v keepsyms=1 debug=0x100 alcid=1
Mac OS version:
19G2021
Kernel version:
Darwin Kernel Version 19.6.0: Thu Jun 18 20:49:00 PDT 2020; root:xnu-6153.141.1~1/RELEASE_X86_64
Kernel UUID: 1D3A0F3D-D908-397B-BD16-8F48C0823A2E
__HIB  text base: 0xffffff8000100000
System model name: iMac20,1 (Mac-CFF7D910A743CAAF)
System shutdown begun: NO
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 15906518147
allego EFI con SSDT-Basic e ioreg
EFI_SSDT-Basic.zip
ioreg.ioreg.zip
aggiunti allegati
chiedo ad un admin se possibile rinominare questo topic visto che dalla domanda originale siamo passati in generale ai problemi del mio hack, oppure é meglio chiudere questo e ne riapro uno dedicato?
nel caso rinominate potrei suggerire "Asus z490m i5-10600k iGpu Opencore Catalina" ?
  • Gengik84 changed the title to Asus z490m i5-10600k iGpu Opencore Catalina
12 minutes ago, Gengik84 said:
prova il config...
Grande funziona alla grande! ho rimosso -igfxvesa ovviamente dopo averlo testato. vedo che in
PciRoot(0x0)/Pci(0x2,0x0)
mi hai messo
AAPL,ig-platform-id     <00009B3E>
mentre sulla guida di opencore c'é scritto 07009B3E
posso chiederti da dove vengano sti id? cosi da capirci meglio.
grazie per aver rinominato il topic.
1 minute ago, Gengik84 said:
prova il layout anche se per ora sembra che AppleALC/WEG stiano fallendo il rename riguardo all'audio
Credo di essere troppo niubbo per capire cosa devo fare 😅
Comunque il mio é chip audio é ALC887
Realtek ALC887 0x100202, 0x100302, layout 1, 2, 3, 5, 7, 11, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99 13 (10.9)
si in quel modo...
se non va c'è un problema a monte ossia che come dicevo prima i kext non eseguono correzioni (rename) a riguardo dell'audio e quindi senza il relativo device l'audio non funzionerà mai
credo sia quello il problema, nella guida ho seguito il troubleshooting e a questo punto https://dortania.github.io/OpenCore-Post-Install/universal/audio.html#checking-if-applealc-is-patching-correctly
cercando con ioreg non vedo la HDEF
questo l'elenco delle mie kext
