iHack20.1 : ASRock Z490 Extreme 4, CPU Ix 10x00
12 minuti fa, ghj ha scritto:
how can i get access to efi through windows?
Hi , Do you have minitool partition tool? https://www.partitionwizard.com/free-partition-manager.html
assign a letter to the osx efi partition, it will be available on explorer but you can only navigate in it via Explorer ++ run it as admin https://explorerplusplus.com/
i mounted efi with cmd and now using explorer++ for browsing files
thanks!
20 minutes ago, Giaccaz said:
meanwhile try the efi2.
see if it works
wow
nice job
thanks a lot
i'm thinking that boot is now even faster.
ethernet is connected with automatically configuration....
but site cant be reached
  • +1 2
here I am again
I can use telegram on PC with Ethernet but Spotify/safari/ chrome are not working properly
the only thing that I could open is YouTube main page without thumbnails (pic related)
(translation: no connection to the internet. please check your connection)
can you tell me what's wrong?
12 minutes ago, Giaccaz said:
i'm sorry, l explained myself badly do a save of the eth. setting  mac ....tcp/ip , Dns...then set 1000 instead of 100 on speed in eth
 when I change speed to 1000 and 2500 , there is no Ethernet at all
3 minutes ago, Giaccaz said:
allora then in ethernet--->dns delete that ip and set ip of yuor router 192.168.1.1
1419193343_Schermata2021-11-08alle22_23_21.thumb.png.96da763e76a0cb2b12318c0c21198dfe.png
the go to hardware set manual and in speed set 1000 the put back in automatic
pure genius.
thank you very much
 and by the way your English in not that bad as you wrote earlier
  • 4 months later...
