iLoveOSX Posted September 11, 2020 Author Share Posted September 11, 2020 Direi di metterci una pietra su... pazienza. Sto facendo un pensierino su questo intel nuc8i7beh2. Credo sia un ottimo compromesso qualità/costi. Che ne pensi? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 11, 2020 Support Team Share Posted September 11, 2020 qualsiasi pezzo hardware miri, assicurati che almeno ce ne sia uno identico funzionante in hack io mi farei un bel ITX con la Z490 asrock Link to comment Share on other sites More sharing options...
iLoveOSX Posted September 11, 2020 Author Share Posted September 11, 2020 Da quel che vedo in giro sembrerebbe essere compatibile... Preferirei qualcosa del genere per esigenze di spazio sulla scrivania. Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 11, 2020 Support Team Share Posted September 11, 2020 https://github.com/sarkrui/NUC8i7BEH-Hackintosh-Build Link to comment Share on other sites More sharing options...
iLoveOSX Posted September 11, 2020 Author Share Posted September 11, 2020 (edited) C'è anche il modello più recente... con intel di decima gen: NUC10i7FNK con relativa repo https://github.com/eGust/Intel-10th-gen-NUC-Hackintosh Edited September 11, 2020 by iLoveOSX Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 11, 2020 Support Team Share Posted September 11, 2020 li usano OC eh Link to comment Share on other sites More sharing options...
iLoveOSX Posted September 11, 2020 Author Share Posted September 11, 2020 7 minutes ago, iCanaro said: li usano OC eh quindi preparati perché se dovessi acquistarlo... dovrò romperti le balls 😄 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 11, 2020 Support Team Share Posted September 11, 2020 http://macos86.it/OpenCore/#/ 😁 Link to comment Share on other sites More sharing options...
iLoveOSX Posted September 11, 2020 Author Share Posted September 11, 2020 Battute a parte... tra i 2 modelli credo di optare per il primo... è più datato e presumo allo stesso tempo più ottimizzato. Link to comment Share on other sites More sharing options...
