Just now, fabiosun said:
well well well..
Big Sur does not start anymore
i thing some changement in MMIO group...
tomorrow i will investigate about it
I've seen elsewhere that macOS will not run with Re-Size Bar enabled, it must be disabled.
confirmed!
it hangs in early stage, no way also virtualizing all MMIO group..
It is enough deselect that option and system boots again
I have no checked if MMIO have been changed by new bios , i will check when 6900 xt will be supported 🙂
Anyone with the sTRX40 Aorus Xtreme, there is a new beta bios available - F4n.
I can't try it yet as my mrs has cleared our bedroom into the office so we can decorate and I can't get in there atm. If you want to try it it can be downloaded from HERE
Edited by Ploddles
does sleep & wake work for you?
I’ve never got it to work reliably but I haven’t spent much time trying as I just turn it on and off when I want to use it, so sleep isn’t an issue for me. At some point I’ll probably look into it a bit more.
I won’t get a chance to try the new bios until next week sometime, busy decorating the bedroom for the time being.
