@Arrakis - wow - so I don't how long it took to load the clip, but it was definitely more than a minute  - I left it alone and minimized the window and when I checked 20 min later it was there. This is really bad in practice. So on the Windows VM it's averaging only 21 fps after a long run. It only uses 190w which is about 60-70% of the cards TDP and card doesn't get hot at all.
Edited by meina222
2 hours ago, Ploddles said:
Has anyone else tried OC 0.6.5 and using the built in Intel WiFi on Gigabyte boards? My wifi has stopped working. Will troubleshoot it later but wondering if anyone else has this issue.
@Ploddles
I upgraded to Opencore 0.6.5 today and just tested the wifi. It works for me.
Edited by Arrakis
2 hours ago, Jaidy said:
Did you use some alert bot or just got lucky?
I said above
a telegram group posted in this thread (@meina222 posted it)
you have to be very fast because many users are checking it😂
On 1/7/2021 at 11:24 AM, Ploddles said:
I can boot with it but there is no hardware acceleration etc.
@Ploddles, do you mind sharing your 065 EFI again?  Just got my "repaired" Designare mobo back from Gigabyte and plan to reinstall it because I can't get the TR TB3 card working with my Asrock mobo🤨Thanks!
