@fabiosun, I'll mount it tonight. I need to remount my front radiator 1st as the hoses would get in the way as the card is longer than the 5700XT I currently have. Didn't mean to resell it but I haven't even gotten a chance to play on the 6800 in my mini ITX yet. I will try some VR games like Half Life over the weekend.
Edited by meina222
if you lucky boys (TM 🙂 ) have a windows installation..you could try something like Cinebench r15 (gpu) and also luxmark3.1 if they work fine 🙂
@Ploddles a puget benchmark for AE or DaVinci if you use them...will be a dream 🙂
Edited by fabiosun
added Trademark :)
could you try to boot with key function and choose your disk with inside EFI?
see also if you have in the bios boot disks list an "Opencore" disk
imy motherboard the key is F11 , i do not know yours
