21 hours ago, shutterbug168 said:
@Rox67er, your BIOS settings fixed my shutdown/reboot problem! THANK YOU, THANK YOU!!! Now, I will work on getting the TR TB3 card to work... Do you happen to know any Asrock mobo users using the TR TB3 card with a working SSDT for our mobo?  Many thanks again!!!
Does sleep now also work for you or still no sleep???
I have no info on TR TB3 card, sorry.
Edited by Rox67er
18 hours ago, shutterbug168 said:
No, sleep is still not working... but at least it's NOT stuck in sleep mode if I force it to sleep. Thanks again!
Maybe @Driftwood is willing to share his BIOS settings, he showed that sleep works but apparently it is not related to EFI but must be something in the BIOS settings.
1 hour ago, Driftwood said:
big sur stable 3-7.BIN.zip I think this is the last bios I saved for my Asrock TRX40 Creator. Ill check on reboot later to see if anything has changed.
So, it still wakes up immediately, and it's caused by DarkWake:
2020-12-14 20:06:16 -0600 Sleep               Entering Sleep state due to 'Software Sleep pid=142': Using AC (Charge:0%)
2020-12-14 20:06:51 -0600 DarkWake            DarkWake from Normal Sleep [CDN] : due to D0A1 D0A2 D0A3 D0A4 D0A5 D0A6 D0A7 D0B0 D0B1 D0B2 D0B3 D0B4 D0B5 D0B6 D0B7 D1A0 D1A1 D1A2 D1A3 D1A4 D1A5 D1A6 D1A7 D1B0 D1B1 D/ Using AC (Charge:0%) 6 secs
2020-12-14 20:06:57 -0600 Wake                DarkWake to FullWake from Normal Sleep [CDNVA] : due to UserActivity Assertion Using AC (Charge:0%)
No idea on how to interpret these codes...:-(
@shutterbug168
to try to solve your sleep problems you should use debug version
Post debug log every time, with config.plist you are using
For now, in my experience , only gigabyte board have some problems (not solvable by now) with sleep/wake
Others manufacturers have great chances of success..if problem happens in this case it could be an usb devices  related problem
8 hours ago, fabiosun said:
@shutterbug168
Okay, here's the debug archive...
OpenCoreArchive.zip
5 minutes ago, shutterbug168 said:
@fabiosun it's still waking up immediately...🤨 At least my Apple Watch is unlocking my Ryzentosh properly!
config.plist.zip
if you do not change anything else post only debug.log (latest after every boot)
I will use the same config (I will change only things in config.plist
backup always previous and working config
Hmm... the latest config.plist is rebooting the machine shortly after I select the macOS drive.  Need to take the drive out and replace the config.plist...
sorry you have to test with an USB pen to recover problems like above..
I am playing with MMIO
and system could hang  as you see
a test you could do is to detach all usb devices and to have connected only a mouse and a keyboard
Okay, no problem.  Will get the drive going later today... Thanks again!
Will try driftwood bios but until now I have the exact same Darkwake.
