13 hours ago, 23d1 said:
@fabiosun Fantastic, thanks! Will try this out after work later today. I've tried every port and BT, so I wonder if it's a missing aml or kext for the specific chipset...
Edit;
I got bluetooth working with IntelBluetoothFirmware.kext, so I could connect keyboard and mouse and subsequently log in. However, while macOS sees the Nvidia GPUs, there is no GPU acceleration. I tried running Cinebench just to see the CPU score on bare metal, but the machine froze completely so I had to hard reset. Will test more later.
Now the more difficult part for us (trx40 and Nvidia owners)
I would advice to proceed in this way
1) uninstall Nvidia web driver
2) if you are using SIP @ 0000000 reboot
3) enter OSX recovery
4) open terminal
5) execute:
    csrutil disable
then nvram -c
6) boot in OSX (no driver installed)
7) install proper Nvidia web driver (as your OSX high Sierra version needs
8:  restart
check if it starts fine and if OSX gatekeeper asks to unlock some Nvidia kext in privacy
be sure in your Nvidia panel you have Nvidia web driver selected
This could be a pain..and I hope for you it will better than me
8 hours ago, Jaidy said:
I would like the EFI too 😛
13 hours ago, Rdak said:
Hi @Ploddles
I'm having issues with my logitech mouse and keyboard that they keep dropping connections. I tried to use a USB hub and it doesn't help.
I also try different SMBIOS but still no luck. Could you share your EFI so I can give a try? Thanks!
You can find it HERE.
18:899 00:012 OCAK: Read kernel version 20.1.0 (200100)
18:900 00:001 OC: Kernel patcher result 0 for kernel (algrey - Disable _i386_switch_lbrs) - Success
18:902 00:001 OC: Kernel patcher result 1 for kernel (algrey - Disable _i386_lbr_init) - Success
18:984 00:081 OCAK: algrey - _i386_init_slave - Remove wrmsr 0x1c8 replace count - 2
18:984 00:000 OC: Kernel patcher result 2 for kernel (algrey - _i386_init_slave - Remove wrmsr 0x1c8) - Success
18:986 00:001 OC: Kernel patcher result 3 for kernel (algrey - Disable _i386_lbr_native_state_to_mach_thread_state) - Success
18:989 00:003 OCAK: commpage_populate -remove rdmsr replace count - 1
18:989 00:000 OC: Kernel patcher result 4 for kernel (commpage_populate -remove rdmsr) - Success
18:991 00:001 OCAK: cpu_topology_sort -disable _x86_validate_topology replace count - 1
18:991 00:000 OC: Kernel patcher result 5 for kernel (cpu_topology_sort -disable _x86_validate_topology) - Success
18:996 00:004 OCAK: cpuid_set_cache_info - cpuid 0x8000001D instead 0 replace count - 1
19:001 00:004 OC: Kernel patcher result 6 for kernel (cpuid_set_cache_info - cpuid 0x8000001D instead 0) - Success
19:001 00:000 OC: Kernel patcher skips kernel (cpuid_set_cache_info - cpuid 0x8000001D instead 0) patch at 7 due to version 170000 <= 200100 <= 189999
19:004 00:002 OCAK: cpuid_set_cache_info - cpuid 0x8000001D instead 4 replace count - 1
19:004 00:000 OC: Kernel patcher result 8 for kernel (cpuid_set_cache_info - cpuid 0x8000001D instead 4) - Success
19:008 00:003 OCAK: cpuid_set_cache_info - don't set cpuid_cores_per_package replace count - 1
19:008 00:000 OC: Kernel patcher result 9 for kernel (cpuid_set_cache_info - don't set cpuid_cores_per_package) - Success
I think we need again of beta 7&8 patches 🙂
  • Sad 1
On 10/13/2020 at 1:43 AM, fabiosun said:
@23d1i think you are the second users to have nvidia and highsierra booting with trx40
for your usb problem
are you using a cabled usb/mouse system to back motherboard usb?
or are you using bt/wifi mouse/keyboard?
when you solve this problem we can go further and i hope nvidia driver is active yet
added ethernet for one of your lan (aquantia 10G should be  seen by default in high Sierra,  2.5 ethernet RTL8125  one no
you have to declare it properly the kext attached in your config
Different users here have the same your board and it could be useful to follow their advice about kext needed..for high Sierra and Nvidia ask to me 🙂
@TheDantee have you solved your problem also with my latest EFI..I need more high Sierra users possible 🙂
is the new EFI in the original post?
1 hour ago, Driftwood said:
Nice n easy update Beta 10 (two reboots and in) Here, in 8K!
Thats sick! Crazy how small everything looks.
these are the patches I am using to Boot Big Sur with Clover Bootloader
Original patches are from AMD OSX Experimental Patches , converted with Clover way to name argument patches
This works also in other platform, it is a WIP and I have to refine better min and max kernel name ..Clover renames it in MatchOs and others stuff
only for BS.plist.zip
5 hours ago, TheDantee said:
it does work in 64C 64T mode stock is 64C 128T just your EFI just the AppleIntelCPUPowerManagmentClient is throwing an error, I've never seen before
try to remove if it is there AMDCPUPOwermangement.kext
but there is no IntelCPUPowerManagment kext is there supposed to be?
No
check in my efi
if you see in kext an amdcpupowrrmanagement kext
disable it in config and see if it boots
patches above is another story and are useful to boot Big Sur with clover bootloader
