i have updated from Catalina using this:
it downloads a beta 6 full installer
now I am downloading from there beta 8
interesting thing is I have unlocked my Catalina system volume to read/write and beta 6 as maintained this status
in this way I have also unlocked again web drivers previously used in Catalina
beta 6 disk situation:
/dev/disk8 (synthesized):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      APFS Container Scheme -                      +249.8 GB   disk8
                                 Physical Store disk5s2
   1:                APFS Volume ⁨Dati - macOS-BM⁩         10.1 GB    disk8s1
   2:                APFS Volume ⁨macOS-BM⁩                14.8 GB    disk8s2
   3:              APFS Snapshot ⁨com.apple.os.update-...⁩ 14.8 GB    disk8s2s1
   4:                APFS Volume ⁨Preboot⁩                 311.5 MB   disk8s3
   5:                APFS Volume ⁨Recovery⁩                754.6 MB   disk8s4
   6:                APFS Volume ⁨VM⁩                      1.1 MB
7 hours ago, fabiosun said:
@meina222i see your memory are set correctly to 3200
i see 1600 in my rig
did you do something for this?
No, just a manual frequency profile in BIOS. I set it at 3200 (and infinity fabric at 1600) manually and do not use XMP1 profile. But even with XMP1, MacOS sees it as 3600, so perhaps it's not that.
@Jaidy .. you always fall for it! 🙂
only the possibility of having all the ports of the graphics card working and with the possibility of setting the correct resolutions for the monitors
no video acceleration
no cuda 🙂
I am not an Nvidia engineer just a geek 🙂
  • Haha 1
Judging by the price rumors ($499) is probably falling short a bit of the 3080. That said, this is a very good price if you can actually get it and beat the 2080ti. I'll be happy if the card is even available to buy. Radeon Pro VII turned out to be vaporware (announced in May, still nowhere to be found).
Here's what I've heard about the Big Navi and other AMDs
(RTX 3090 $1499)
Navi 21 (Big)     RX 6900 XT    16GB 80 CU    $999
(RTX 3080TI 20gb)
Navi 21            RX 6800 XT    16GB 72 CU    $799
Navi 21            RX 6800        12GB 72 CU    $699
(RTX 3080 $699)
Navi 22        RX 6700 XT    16GB ?? CU
(3070TI 16gb)
Navi 22        RX 6700        8 GB ?? CU
(RTX 3070 $499)
Navi 23        RX 6500 XT
6 minutes ago, meina222 said:
The Samsung 980 pro is listed on Amazon with very competitive price with 2-4 weeks delivery estimate.
https://www.amazon.com/SAMSUNG-980-PRO-SSD-500GB/dp/B08GL575DB/
Wait for Sabrent...
3 hours ago, fabiosun said:
this is an AMD problem..often is a marketing vaporware
Well I'm pretty happy with the 3970x performance, if the next Video card matches that I will definitely get one.
3 hours ago, fojerhar said:
Is anyone here tried who has Asrock trx40 board here, if the asrock thunderbolt 3 aic r2.0 will work with it under Catalina?
On the site these boards are not supported, but I have Thunderbolt enable menu in my bios?
Not yet but I'm interested in this as well.
no cuda 🙂
Haha! I so want one of these Ampere cards to be able to run CUDA
I spoke to Asrock weeks ago, there is no chance of Thunderbolt support on this board. This was there response:
Hello,
 Our TRX40 models have no header for a Thunderbolt add-in card. No way to add Thunderbolt support to these boards, sorry.
Kind regards,
ASRock Support
ASRock Europe B.V.
Bijsterhuizen 1111
6546AR Nijmegen
The Netherlands
  • Sad 1
