VoodooPS2Controller by RM
Rilasciata una versione aggiornata del driver per tastiere e trackpad su base PS2 dei notebook
Change Log:
2018-09-28 v1.9.1
Fix panic caused by notifications that sometimes happen during HID registration (reported issue #166 and elsewhere)
2018-09-22 v1.9.0
VoodooPS2Daemon is deprecated, replaced with kernel level functionality (courtesy the-darkvoid)
"ignore built-in trackpad" now works with USB mice as well as bluetooth mice (courtesy the-darkvoid)
use system notifications for keyboard integration with VoodooI2C project (courtesy the-darkvoid)
2018-05-6 v1.8.34
fix bug with DisableDevice when used with the Synaptics profile
2018-05-05 v1.8.33
change BogusDeleteThreshX and BogusDeltaThreshY for Thinkpad_Trackpad profile (Lenovo T420)
change default delay for findMouseDevice to 100ms
2018-04-24 v1.8.32
add trackpad prefpane properties for VoodooPS2Mouse when ActLikeTrackpad is set
no release v1.8.31
merge jcsnider's pull request for better Thinkpad trackpoint support
2018-04-18 v1.8.30
Wait (default) 500ms before checking for PS2 mouse in findMouseDevice
FindMouseDelay can be overriden in VoodooPS2Controller.kext Info.plist or with kernel flag vps2_findmousedelay
Pagina di riferimento: https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/overview">https://bitbucket.org/RehabMan/os-x-voo ... r/overview">https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/overview
Download: https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/">https://bitbucket.org/RehabMan/os-x-voo ... downloads/">https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/
Aggiornata da poche ore la build, riportati sopra i cambiamenti
il file però non lo vedo, o ha modificato quello del 18 aprile o lo deve ancora mettere...
PS: la deve ancora mettere, ho scaricato l'ultima disponibile ed è sempre quella del 18 aprile
Ha scritto dopo 1 ora 30 minuti 43 secondi:
Zompando da un repo ad un'altro ho trovato questo, magari a qualcuno può essere utile, è un fork del VoodooPS2 di RM
Voodoo PS2 Controller X1 Carbon
This is a the compiled kext to get the trackpoint devices working on X1 Carbon (2015 model) Hackintoshes.
info e download: https://github.com/jcsnider/OS-X-Voodoo-PS2-Controller/releases">https://github.com/jcsnider/OS-X-Voodoo ... r/releases">https://github.com/jcsnider/OS-X-Voodoo-PS2-Controller/releases
Change Log:
2018-05-05 v1.8.33
  • 4 months later...
Change Log:
2018-09-22 v1.9.0
RehabMan-Voodoo-2018-0922 https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/RehabMan-Voodoo-2018-0922.zip">https://bitbucket.org/RehabMan/os-x-voo ... 8-0922.zip">https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/RehabMan-Voodoo-2018-0922.zip
New Release VoodooPS2Controller by RehabMan https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/">https://bitbucket.org/RehabMan/os-x-voo ... downloads/">https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/
2018-10-08 v1.9.2
Tapping stability: ignore moves while waiting for tap gestures (eg. pointer will not move while making a tap or double tap gesture)
Increase TapThreasholdX/Y, DoubleTapThresholdX/Y (from 50/100 to 75/150)
