Administrators Gengik84 Posted April 19, 2021 Administrators Share Posted April 19, 2021 Rilasciata Versione 1.1.0d11 allegata nel primo post ChangeLog: Here is a first development build of version 1.1.0d11, which involves the following changes: Updated Linux sources to 9.005.01. Fixed auto-negotiation with 1 Gigabit switches. Using 2.5 Gigabit requires manual selection of the medium. Added support for adaptive poll interval in 2.5 Gigabit mode. 1 Link to comment Share on other sites More sharing options...
Giaccaz Posted April 25, 2021 Share Posted April 25, 2021 (edited) e uscita una altra versione.... LucyRTL8125Ethernet-V1.1.0d12 Edited April 25, 2021 by Giaccaz 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 25, 2021 Administrators Share Posted April 25, 2021 Allegato al primo post Link to comment Share on other sites More sharing options...
Giaccaz Posted April 25, 2021 Share Posted April 25, 2021 (edited) con questi ultimi due kext si riesce a far funzionare in maniera automatica eth ( sia 1 gb che 2,5gb )? o bisogna sempre impostarlo manualmente? io non ho ancora provato.... Edited April 25, 2021 by Giaccaz Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 25, 2021 Administrators Share Posted April 25, 2021 sembra supporti i 2,5 gb Cita Mieze: I managed to further improve the driver so that auto-negotiation is working with all supported speeds (including 2.5 GBit/s) in version 1.1.0d12. The attached archive includes a debug and a release build, which I'm using on my primary work machine. Link to comment Share on other sites More sharing options...
Giaccaz Posted April 25, 2021 Share Posted April 25, 2021 si ho letto ,speravo che tu avessi gia provato 😝 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 25, 2021 Administrators Share Posted April 25, 2021 non ho provato, sono appena rientrato a casa 😄 e comunque uso principalmente il wifi, quindi con comodo poi lo proverò 🙂 1 Link to comment Share on other sites More sharing options...
Giaccaz Posted April 25, 2021 Share Posted April 25, 2021 (edited) come te provero piu tardi ....prima devo finire un lavoro. Edited April 25, 2021 by Giaccaz 1 Link to comment Share on other sites More sharing options...
Giaccaz Posted April 25, 2021 Share Posted April 25, 2021 confermo!!! finalmente funziona in maniera automatica , l'ho provato a 1gb . ringrazio molto mieze....gran bel lavoro. 1 Link to comment Share on other sites More sharing options...
tuxy Posted April 27, 2021 Share Posted April 27, 2021 Gran bel risultato!!!! Tutto funzionante! 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted May 2, 2021 Author Support Team Share Posted May 2, 2021 rilasciata la versione 1.1.0 stable --> https://www.macos86.it/files/file/83-lucyrtl8125ethernet-by-mieze/ 1 Link to comment Share on other sites More sharing options...
maurzit Posted November 20 Share Posted November 20 Buongiorno a tutti, ho installato una Ethernet PCI card FenVI RTL8125B Chip 100/1000/Mbps/2.5Gbps su MacPro 5.1 avente la seguente configurazione - Dual Inel Xeon X5680 @ 3.33 - Ram 64Gb - Gpu Nvidia GT 730 4Gb - Os 12.7.6 (con OCLP) - Rete TIM FTTH @ 2.5Gb non riesco a farla riconoscere dal MacPro in MacOs Monterey 12.7.6 Qualcuno puo' darmi dei suggerimenti ? Grazie Link to comment Share on other sites More sharing options...
