8 hours ago, Driftwood said:
Not getting a Install Mac OS on the OpenCore Boot screen which is really odd. Catalina attempt. both iso's have been uploaded!
conf looks like this:
args: -device isa-applesmc,osk="ourhardworkblahblahblah$ smbios type=2 -device usb-kbd,bus=ehci.0,port=2 -cpu Penryn,kvm=on,vendor=GenuineIntel,+kvm_pv_unhalt,+kvm_pv_eoi,+hypervisor,+invtsc,+pcid,+ssse3,+sse4.2,+popcnt,+avx,+avx2,+aes,+fma,+fma4,+bmi1,+bmi2,+xsave,+xsaveopt,check
bios: ovmf
boot: cdn
bootdisk: ide2
cores: 8
cpu: Penryn
efidisk0: local-lvm:vm-100-disk-1,size=4M
ide0: local:iso/macOS86_Catalina.iso,cache=unsafe,size=9G
ide2: local:iso/OpenCore.iso,cache=unsafe
machine: q35
memory: 32000
net0: vmxnet3=blah:blah:blah:blah,bridge=vmbr0,firewall=1
numa: 0
ostype: other
sata0: local-lvm:vm-100-disk-0,cache=unsafe,size=64G,ssd=1
scsihw: virtio-scsi-pci
smbios1: uuid=blahablahblah...
sockets: 1
vga: vmware
vmgenid: blaha blah blah ....
I would like to start from here , to be honest latest post seems to me a bit ungrateful.. I can do a mistake in this...I would like clarify a bit
1)
Your problem with 9 Gb full iso..have you read updated part of the guide when we create (@gengik84) new option for VM_Assistant?...I would like also inform you that also nick's site after that updated his site 😉
2)
opencore stuff...If you read always nick's site, maybe you can understand by yourself who discovered that opencore was a better option..overall for initial graphics problem on boot
He forgot to give proper credits for it...and if you read in comment I have remembered him this fact ( I could say also others things but I do not want to polemic more!
3)
all "researches" for understanding boot args part were done in latest December time..from there I have started to test others combinations from Penryn to host CPU and adding some @algrey patches to avoid also in vm initial hang like trx40 users have in "real" hack environment
4)
@PavoGitHub is a great resource for users with a radeon card because he has one and he is trying to resolve annoying reset bug..I have no radeon card (and here we do not ask to send one to solve problems 😛 ). In his GitHub Is also well defined the initial inspiration for his journey in proxmox
5)
this guide is free it is not perfect but it does not hide anything..and if you want you can participate on it with your ideas and your point of you in all aspects you think we can improve (with we I mean you and me in a word community). I appreciate in particular way @iGPUand @AllubzVmessages here
No polemic only to clarify things. I am not a hackintosh  Guru and my job is not related to this passion. I hope you understand in a right way this my "clarification" 😉
have a nice day
@Driftwood I quoted you but not for particular problem with you 🙂
4 hours ago, fabiosun said:
@Driftwood, @AllubzV take a look to below image..it could solve your missing full ISO icon:
Thanks fabiosun.  Yeah I did a those arguments & settings first time round. The problem is I tried two full installs - one I originally downloaded from app store with my macbook pro and the other with the VM Assistant but both wouldn't work with OC but did with Clover. The 2gb base DMG did work with OC. Also option 3 on VM Assistant menu return an error for Catalina server querying, where as the VMA command line help variables work. Options 1 HS and 2 for mojave seem to work fine. Maybe (@gengik84) will take a look. Good app though.
Anyways, I'm in now and analysing devices to pass thru and configs...
BTW I'm very grateful for your guide, Sherlock's guide, Pavos stuff and all the thread members here. It's an amazing resource.
Edited by Driftwood
VM Assistant
@Driftwood
starting from a working full installer (downloaded with Vm assistant or in other ways) is possible to convert rename it in iso with vm assistant tool
you have only to use it as a cd rom image and put that option in vm config when you set full iso disk
basesystem dmg is not a proper iso file so it must used as a normal vm disk with cache=unsafe option.
When you hit the menu option 3 here in UK it doesn't work. Neither does a python s script I tried so it must be country related.
The arguments work. Just the menu. Just thought I'd note it for you guys
@fabiosun I want to thankyou for all the amazing work you have provided here. Without this 3970x users would be a bit lost. Awesome work and a helluva lot of gratitude to you.
Now I move on to getting Radeon VII working and a m2 NVME. I guess I can use the Proxmox working VM as a template for a more thorough install. I know you cant share VMs to the same drive else it will screw up - each needing a separate drive. So I experimented on a SSD got it working, copied over the vanilla working boot EFI to the main drive with this resource's help and a bit of Nick Sherlock stuff in order to begin all the other stuff like kexts, config plists, etc...
I keep reading about different setups & ROMs people are using to pass through for the Radeon VII, what is the most reliable found to date anyone?
@Driftwood
in my knowledge Radeon VII could pass without any rom
always in my knowledge it will be affected from reset bug
so when you restart your OS X vm hangs
vm subject
usually i copy my working one
rename it ie from 100 to 101
then I modify 101 an do my test
may I ask which motherboard do you have?
Very curious about your audio FireWire card
in my case the only problem I have is internal and usb audio
nvidia dp audio is perfect instead
@iGPU
to test I have inserted my Asus Tb ex3 card
it is  not detected at all
no group available for it
about (my) internal audio problem:
23:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
passed as hostpciX: 23:00.4 and dpcimanager app see it as below:
you can also see here a weird audio device:
08086293E (intel related??)
if I do not blacklist  blacklist snd_hda_intel  when I boot on proxmox I see a message snd_hda_intel codec not found.
this message seems related to  starship/matisse HD Audio controller (famous 23:00.4)
So or Proxmox Ve associated internal ALC audio to intel codec..or we should think how to eliminate that weird audio device you can see in pictures above
If you have some ideas to share it is welcomed as usual 🙂
@Driftwood about VM Assistant
option 2 is not working also here so it is a common problem(maybe some path are changed)
  • fabios-iMac:~ fabio$ /Users/fabio/Desktop/VM_Assistant-2 -dcata
  • fabios-iMac:~ fabio$ /Users/fabio/Desktop/VM_Assistant-2 -dhs
  • fabios-iMac:~ fabio$ /Users/fabio/Desktop/VM_Assistant-2 -dmoja
these are the commands to download full iso installer (Catalina, High Sierra and Mojave)
@Gengik84will check as soon he can
On 5/5/2020 at 3:52 PM, AllubzV said:
When trying to start the VM with the following config I get
kvm: -device vfio-pci,host=0000:4b:00.0,id=hostpci11,bus=pci.2,addr=0x14: vfio 0000:4b:00.0: failed to open /dev/vfio/60: No such file or directory
TASK ERROR: start failed: QEMU exited with code 1
So we have exact same issue.
I've been trying to attack this problem on several fronts. I'll have another go tonight. I think the problem is that Linux does not natively support Thunderbolt. A key, I believe is in activating TB for Linux. I tried this 2 days ago (and was going to write about it yesterday when I alluded to the complicated reply), but it didn't work out. I've now got a variation to try out and will report if this works.
I've been scouring the Internet for Linux/TB and found this one comment about PCI pipes/tubes not being established until TB is authorized.
If I cannot authorize my card, then I'll ask you to try and authorize your un-flashed card. (I'll write in detail how; there are a few tools to install and a couple of odd-ball commands.) If you can then authorize, then I'll know my problem is failure to authorize due to flashed firmware. In which case I'll re-flash my card, authorize and try again to pass-thru TB.
In any event, I'll report back later.
Edited by iGPU
I'm still having issues with TB: I'll work on more tomorrow.
Tonight, the extra DDR4 finally arrived, so total is now 128GB running XMP. I also switched out the Vega 56 for a Radeon VII... so tonight I I ran tests. The Radeon VII benefits from a modified CMMChris kext and DevProperty SoftPowerPlayTable injection (and I disable WEG as it does not play nicely with the Radeon VII---at least on the Z390 buld).
GeekBench-4: CPU, OpenCL and Metal
LuxMark v3.1: GPU and GPU+CPU
Cinebench-15
Cinebench-20
Corona
Attached is the CMMChris kext file used for the above tests. This kext file also inject AGPM and works with almost all AMD GPUs (see internal info.plist file).
And in below Spoiler is OpenCore DeviceProperties code for speeding up the Radeon VII as well as keeping voltages as low as practical. The code also  populates the Syst-Info/PCI section.
Do note, however, that the PCIRoot(...) address will need changing for any other mobo. Use Hackintool' to determine for your mobo if different and ProperTree to copy and paste.
			<key>PciRoot(0x1)/Pci(0x1C,0x0)/Pci(0x0,0x0)</key>
			<dict>
				<key>@0,name</key>
				<string>ATY,Adder</string>
				<key>@1,name</key>
				<key>@2,name</key>
				<key>@3,name</key>
				<key>AAPL,slot-name</key>
				<string>Slot-1</string>
				<key>ATY,EFIVersion</key>
				<data>
				MDEuMDAuMzE4MA==
				</data>
				<key>PP_DisablePowerContainment</key>
				<integer>1</integer>
				<key>PP_FuzzyFanControl</key>
				<integer>0</integer>
				<key>PP_PhmSoftPowerPlayTable</key>
				<data>
				wgYLAALCBjQIAACkNQAAfAAJAAAAGkUBRQFFAQAAAAB2
				AAELAAAACQcAAG4EAADMAwAAzAMAAMwDAADoAwAAyQQA
				AG4EAABuBAAANAQAACoDAAAAAAAAAAAAAAAAAAAAAAAA
				AAAAALwCAABmAQAANgEAADYBAAA2AQAAXgEAACYCAABm
				AQAAZgEAAJMAAAAOAQAAAAAAAAAAAAAAAAAAAAAAAAAA
				AAABDgAAAAEBAQEBAQEBAQEBAQEBAAAAAAAAAAAAAAAA
				AAAAAAAAHQAAAJ4HAACeBwAAngcAADMEAACeBwAAMwQA
				AJ4HAAAzBAAATAQAABQAAAAKDwAAKAoAAF8AAABuAAAA
				AgAAAAAAAAABAAAAAQAAAAEAAABfAAAAZAAAAF8AAABk
				AAAAXwAAAGQAAABfAAAAZAAAAF8AAABkAAAAAAAAAAAA
				AAAAAAAAKAMAACgDAAAoAwAA4gIAACgDAADiAgAAKAMA
				AOICAABeAQAAFAAAAMIBAADCAQAAGQAAADIAAAAAAAAA
				AAAAAAAAAAAAAAAAAAAAABkAAAAUAAAAGQAAABQAAAAZ
				AAAAFAAAABkAAAAUAAAAGQAAABQAAAAAAAAAAAAAAAAA
				AAAAAAAAAAAAAAAAAwAAAP/v9DkAAAAARQEAAAAAAAAA
				AAAAAAAAAEUBAAAyAAAASgEAAGQAbgBeAHMAcwD/////
				//8AAAAAAAAAAAEAcwAAAAAAAAAAAFQLIAvMEDARJgAA
				AAEBCQAAAAAAAAAAAFuxvz7sUfi+ZRlSPwABCABkO58/
				Ft6lvQAAAAAAAAAAAAAAAAABCAA1Xpo/jzYuPgAAAAAA
				AAAAAAAAAAABCABpb7A/SDMWPQAAAAAAAAAAAAAAAAAB
				CADlYaE/EvdYvQAAAAAAAAAAAAAAAAABAwC1FYM/wt0Z
				PgAAAAAAAAAAAAAAAAABCACGOIY/Dr4wPgAAAAAAAAAA
				AAAAAAABCACDwFo/TaHzPQAAAAAAAAAAAAAAAAIBCAAA
				AAAAAAAAAKRwjT/kFIW/1ecyPwIBAwAAAAAAAAAAAAAA
				AAAAAAAA1ecyPwEBCAAAAIA/AAAAANGR/D4fhSu/Mnd1
				P7wCKANuBFwFCgaTBtUG7QaeBwAAAAAAAAAAAAAAAAAA
				ZgHmAWsC9AJSA8wDbgRuBDYBkAEMAmsCqAL0AlIDzAM2
				AZABDAJrAqgC9AJSA8wDNgEMAjcCawKoAvQCUgPMA14B
				IANMBEwEJgJiArIC+AJmA8ADOATJBGYBxgE3AqgC9AJS
				A8wDbgRmAcYBNwKoAvQCUgPMA24EkwDyAFgB5AEVAqoD
				EwQ0BA4BHAIqAwAAAAAAAAAAAAAJB24EzAPMA8wD6ANu
				BG4ENAQqA8kEAADIACwBYAnwCigDAAAAAAAAAAAAAAAA
				AAAAAAAAAAAAAJ4HAQAAAAAAAAIGBlAANAEAAAAAAAAA
				AAAAAACQAZABkAGQAZABkAGQARQAKApUCwoPXwAAAAAC
				AAAAAAAAAAAAAQAAAAAAAFCNlzwK16M7AAAAAOqymDyH
				okA9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
				AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
				AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoAABAAAA
				AAAAAKAAAAAIEAIQGgRMBOgD6APoA+gDAAAAAAAAAAAA
				AAAAAAAAAAAAAAAAAACGCyILVAsAAJABkAE4AAAAAAAA
				AAAAAAAAAAAAAAAAAAA=
				</data>
				<key>device_type</key>
				<string>Display Controller</string>
				<key>hda-gfx</key>
				<string>onboard-2</string>
				<key>model</key>
				<string>Radeon VII 16GB (Vega 20)</string>
				<key>name</key>
				<data>
				QVRZLEFkZGVyUGFyZW50
				</data>
			</dict>
			<key>PciRoot(0x1)/Pci(0x1C,0x0)/Pci(0x0,0x1)</key>
			<dict>
				<string>Multimedia Controller</string>
				<key>model</key>
				<string>Radeon VII HDMI Audio (Vega 20)</string>
			</dict>
RadeonBoost-v1-4.kext.zip
Edited by iGPU
added code and kext
@iGPU
have you tested that Kext in a real applications?
I mean in app like DaVinci Resolve or others?
I my opinion and in our tests it improves Geekbench benchmarks but it has no other real application benefit in using osx with AMD gpu card.
try ie CAndle test benchmark in DaVinci and you will see it is useful or not
Corona test
@iGPUlink posted it is useful for windows to update drivers in it?
it not seems bios related
Or maybe I miss something?
The new 1.0.0.5 Microcode can be applied to CPU directly via Windows. When AMD updates microcode, the mobo manufacturers will usually update their BIOS at a later date to include this microcode as well as make any changes they see fit (MSI has updated some mobo for X570 style). When the microcode is made available, it can be flashed independently of the BIOS. If later the BIOS is updated to same microcode, then nothing changes with the microcode.
It is probably safer to simply wait for manufacturer's updated BIOS. (I've never flashed microcode before.)
Modest update on TB.
While I still don't have it fleshed out, it does look promising if I can get the 'bridge' portions (addresses 49:00 and 4a:00 passed through), I truly think it will work. The problem is on the Linux/Proxmox side.
In the screen shots below of IORegistryExplorer, I used a very modified SSDT to change the USB section and it worked, perfectly generating the USB section. This now shows up in the Sys Info/PCI section as well as in Hackintool. Unfortunately, hot-plugging a USB or TB drive does not yet mount, but this is not surprising since the whole TB tree is not present.
IORegistryExplorer:
Before custom SSDT:
With custom SSDT (only for USB section, so starts at DSB2, not usual UPSB):
System Information / PCI Section:
Hackintool USB Section:
Edited by iGPU
I was monitoring Proxmox on a Mac laptop: when running Cinebench 20, there is an expected increase in CPU usage over that during idle stand-by.
Idle:
Cinebench 20:
Edited by iGPU
On 5/5/2020 at 7:37 PM, AllubzV said:
The difference is  that I am now passing through the entire NVME Controller (43:00.0) rathern than /dev/disk/by-id, which you can see in my previous
post. Perhaps there lies the difference.
Good tips in here about finding out the NVME controller device settings.
Edited by Driftwood
my microcode is 1.0003 patch c
i see some gigabyte /asus mb have 1.0003 patch b
i do not know if this difference could create problem for our task
in my case I have flashed back bios to test
i haven’t see any difference doing this
