Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 ok, provi tu a modificare ssdt per la mappatura? Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ehm....veramente non ho la concentrazione necessaria boss...mi chiamano tutti i minuti per assistenza i colleghi in smart working...poi insomma ancora non mi è ben chiara Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 ok, in caso vai in download e scarica KEAX posta poi il log è stato fatto un oggetto molto simile al tuo e aveva altri problemi, quindi vorrei controllare Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ecco boss....scusa le lunghe pause ma sono sempre in giro per il palazzo LOG.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 ok come immaginavo, finisco alcune cose e poi ti guardo il tutto Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 grazie boss Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 allegami il config Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ecco config.plist.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 sostituisci il config e aggiungi in patched rimuovi usbinjectall Archivio.zip Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 subito Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ecco ioreg MacBook Air di valter.zip arrgg dimenticato usbiniecall Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ecco ioreg giusto MacBook Air di valter.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 ok... controlla se le usb sono tutte ok Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 gia fatto boss...funzionano tutte 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 ok ottimo 🙂 Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 che ficata..sto a posto cosi??? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 si, salvati la efi mi raccomando Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 per chi avesse bisogno ecco la efi funzionante...a chi servisse un pc tipo mac mini ne consiglio senz'altro l'acquisto...con mojave è perfetto...da testare bene con catalina...un enorme grazie al munifico boss EFI.zip 1 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 28, 2020 Administrators Share Posted April 28, 2020 @marzillo a comodo me la faresti una prova? Link to comment Share on other sites More sharing options...
marzillo Posted April 28, 2020 Author Share Posted April 28, 2020 certo che si boss....dimmi tutto...domani mattina come ho un attimo libero faccio Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 28, 2020 Administrators Share Posted April 28, 2020 4 minuti fa, marzillo ha scritto: certo che si boss....dimmi tutto...domani mattina come ho un attimo libero faccio prova a rimuovere momentaneamente il DSDT e sostituire il config allega ioreg e controlla se le usb funzionano Grazie in anticipo 🙂 config.plist.zip Link to comment Share on other sites More sharing options...
marzillo Posted April 28, 2020 Author Share Posted April 28, 2020 ma scherzi....grazie a te amico mio 1 Link to comment Share on other sites More sharing options...
marzillo Posted April 29, 2020 Author Share Posted April 29, 2020 ciao boss...togliendo il dsdt e sostituendo il config ottengo questo se puo servire ho provato a partire con il vecchio config ma senza dsdt...arrivo alla scrivania ma non funzionano le usb Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 29, 2020 Administrators Share Posted April 29, 2020 ok grazie, in caso ti faccio risapere 🙂 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted May 3, 2020 Administrators Share Posted May 3, 2020 @marzillo mi rifaresti una prova, ovviamente a comodo? come prima niente DSDT, sostituisci il config... ovviamente rinominalo tu a modo. Grazie in anticipo 🙂 config-Marzillo.plist.zip Link to comment Share on other sites More sharing options...
