marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ecco boss....ioreg e ti metto anche il config attuale Archivio 2.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 non è caricato Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 dove ho sbagliato...ho visto ora che ci sono due file che si chiamano cosi....uno è nel primo gruppo...l'altro in basso come non detto..uno è serie s...l'altro serie v2 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 prova questo https://www.macos86.it/applications/core/interface/file/attachment.php?id=11620 Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ecco MacBook Air di valter.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 nulla, allegami un boot.log, puoi farlo anche da clover configurator poi lo guardo e domani con calma vediamo Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ehm...come si fa Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 clover configurator, sulla sinistra --> boot.log 😄 Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ecco bootlog.txt.zip intanto mille grazie boss...lo sai che sto pc è proprio una ficata...funziona pure l'audio hdmi 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 scusa ma ssdt l'hai messo in acpi/patched senza DSDT? metti questo assicurati che sia nominato come lo vedi allegato e ovviamente senza .zip SSDT-390series.aml.zip Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 provo subito...comunque avevo fatto tutto...riprovo Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 strano perchè clover non lo trovava Inserting table[0]:SSDT-390series.aml from EFI\CLOVER\ACPI\patched: ... Not Found l'hai definito in SortedOrder, per quello pensavo o che non ci fosse in patched o avesse un nome diverso Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ecco...ti avevo allegato il config...se vuoi dare un'occhiata MacBook Air di valter.zip 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 Ora ci siamo 🙂 ti faccio una rifinitura.. aspetta che poi te lo ripasso Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 😁😁😁😁 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 sostituisci e rifai ioreg SSDT-390series.aml 2.zip Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ecco boss MacBook Air di valter.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted April 16, 2020 Support Team Share Posted April 16, 2020 non mi pare che sia caricato Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 aaaahhhh Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 16, 2020 Administrators Share Posted April 16, 2020 no ritorna al precedente, rifiniamo ormai domani dai compreso la mappatura 🙂 Link to comment Share on other sites More sharing options...
marzillo Posted April 16, 2020 Author Share Posted April 16, 2020 ok...a domani😅😅😅 1 Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 buongiorno boss stavo provando anche a far partire catalina nel frattempo....lo schermo vga è normale,hdmi è viola Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted April 17, 2020 Administrators Share Posted April 17, 2020 può essere un problema di connettori, weg e lilu sono aggiornati ad ultime versioni? comunque io prima avrei finivo di mappare le usb Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 si si era solo una prova...comunque con la patch port limit mi funziona solo una usb 3...come ho un attimo metto ioreg Link to comment Share on other sites More sharing options...
marzillo Posted April 17, 2020 Author Share Posted April 17, 2020 ecco ioreg boss MacBook Pro di Marzillo.zip Link to comment Share on other sites More sharing options...
