invisible00 Posted April 12, 2020 Share Posted April 12, 2020 (edited) An Intel Wifi Adapter Kernel Extension for macOS, based on the OpenBSD Project. Development Status Only the non-encrypted Wi-Fi connection including mobile hotspot is currently supported. Wi-Fi SSID is hardcoded as Redmi and will auto-connect once the Kext is loaded. WPA 4way-handshake has implemented, but encryption and decryption still have some issues that need to be fixed. Supported Devices https://openintelwireless.github.io/itlwm/Compat.html Res:https://github.com/zxystd/itlwm Edited September 10, 2020 by iCanaro Migliorie e Aggiornamenti Link to comment Share on other sites More sharing options...
alboz Posted June 10, 2020 Share Posted June 10, 2020 Il 12/4/2020 at 15:53, invisible00 ha scritto: An Intel Wifi Adapter Kernel Extension for macOS, based on the OpenBSD Project. Development Status Only the non-encrypted Wi-Fi connection including mobile hotspot is currently supported. Wi-Fi SSID is hardcoded as Redmi and will auto-connect once the Kext is loaded. WPA 4way-handshake has implemented, but encryption and decryption still have some issues that need to be fixed. Supported Devices 3xxx: 3160, 3165, 3168 7xxx: 7260, 7265 8xxx: 8260, 8265 9xxx: 9260、9560、9462 Res:https://github.com/zxystd/itlwm Ciao, ho scoperto per caso ieri questo kext, ne esiste anche un altro chiamato AppleIntelWifi e fanno un lavoro che mai mi sarei aspettato. Siccome ho una Gigabyte con scheda Wifi integrata, ma che usa un'interfaccia proprietaria di Intel che mai sarebbe stata compatibile col Mac (CNVi), invece questi due kext la fanno miracolosamente funzionare. Oggi però improvvisamente kaput, con kext caricato non me la vede più in nessun modo, provato di tutto. Sicuramente è ancora in uno stadio beta e sono certo che avremo un kext perfettamente funzionante, certo però ieri funzionava (la connessione non perfettamente ma andava), oggi nulla boh. E' comunque un argomento da seguire. Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 25, 2020 Support Team Share Posted July 25, 2020 itlwm v1.0.0-alpha HeliPort v1.0.0-alpha itlwm An Intel Wi-Fi Adapter Kernel Extension for macOS, based on the OpenBSD Project. Documentation We highly recommended you to explore our documentation before using this Kernel Extension! Intro Compatibility FAQ Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted August 23, 2020 Support Team Share Posted August 23, 2020 v1.0.0_stable itlwm is for gen1 device, and itlwmx is for gen2 device. If you want to know how to use and how to know your device, please go to the DOC. Assets4 itlwmx_v1.0.0_stable.kext.zip3.21 MB itlwm_v1.0.0_stable.kext.zip6.47 MB v1.0.0 The latest five updates are: b5d926a GH Release 8adc862 fix ssid disappeared when doing disconnect 28ae7ec Update Spanish translation. (#177) 7433db5 Refactored WiFi configuration window (#156) fa800fe Add a service for toggling Wi-Fi HeliPort.dmg7.6 MB Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted August 23, 2020 Support Team Share Posted August 23, 2020 Compatibility https://openintelwireless.github.io/itlwm/Compat.html 1 Link to comment Share on other sites More sharing options...
T19 Posted September 12, 2020 Share Posted September 12, 2020 funziona!! intel wifi AC9462 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 17, 2020 Support Team Share Posted September 17, 2020 v1.1.0 stable itlwm Merged itlwmx to itlwm, itlwmx is now deprecated. Compressed firmware files, reduced itlwm size to 9.9 MB. Resolved an issue that causes the system to become unresponsive when uploading with P2P software. A single itlwm.kext supports all the previously supported devices. itlwm still needs to be used with Heliport and provides support for 10.12 and above systems. 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 17, 2020 Support Team Share Posted September 17, 2020 AirportItlwm Beta Supports all itlwm-supported devices. Supports native Wi-Fi selection and switching with WPA/WPA2/Unencrypted Wi-Fi Networks. Supports Location Services. Handoff and Universal Clipboard perfectly supported. (#292 (comment)) Known Issues and limitations Handoff and Universal Clipboard are the only supported Continuity features. Instant HotSpot from iPhone can be recognized but may likely fail to connect. Workaround: use itlwm.kext with HeliPort. Apple Bluetooth peripherals may fail to connect. Workaround: use itlwm.kext with HeliPort or disable iCloud. 1 Link to comment Share on other sites More sharing options...
iLoveOSX Posted September 19, 2020 Share Posted September 19, 2020 On 9/17/2020 at 11:44 AM, iCanaro said: v1.1.0 stable itlwm Merged itlwmx to itlwm, itlwmx is now deprecated. Compressed firmware files, reduced itlwm size to 9.9 MB. Resolved an issue that causes the system to become unresponsive when uploading with P2P software. A single itlwm.kext supports all the previously supported devices. itlwm still needs to be used with Heliport and provides support for 10.12 and above systems. testato proprio ieri sul mio elitebook. Per il momento sembra andare alla grande sia Wi-Fi che bt. 1 Link to comment Share on other sites More sharing options...
philarticolo31 Posted October 31, 2020 Share Posted October 31, 2020 Alla luce dell'ultimo aggiornamento di questi kext, quali è meglio usare? itlwm + Heliport o AirportItlwm beta bigsur? (sono su bigsur) grazie Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 31, 2020 Support Team Share Posted October 31, 2020 usa quello che ti funziona meglio o ti piace di più itlwm.kext + heliport.app sono in release stable airportitlwm è ancora in beta Link to comment Share on other sites More sharing options...
philarticolo31 Posted October 31, 2020 Share Posted October 31, 2020 ok, grazie.. una cosa però non ho capito: se uso itlwm + Heliport .. immagino che la gestione del wifi e bluetooth passerà tutta da Heliport bypassando l'app nativa con l'altro kext invece è più "vanilla" corretto? 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 31, 2020 Support Team Share Posted October 31, 2020 un caffè corretto per @philarticolo31 al tavolo 32 Link to comment Share on other sites More sharing options...
philarticolo31 Posted October 31, 2020 Share Posted October 31, 2020 Lo prendo come un si 😅 1 Link to comment Share on other sites More sharing options...
philarticolo31 Posted October 31, 2020 Share Posted October 31, 2020 qualquadra non mi cosa @iCanaro ho provato sia con itwlm che airportitwlm , ma non mi fa il boot... ho abilitato i kext nel config ... ma zero.. non bootta... te lo allego, mi sembrava di aver fatto tutto giusto e via bios wifi e bt sono abilitati 🤷🏻♂️ philart.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 31, 2020 Support Team Share Posted October 31, 2020 forse se scrivi giusto il nome nel config non ti ricordi? con OC basta sbagli una virgola e ti fa dito medio @philarticolo31 poi quel Brcmfirmwaredata abilitato per HS e mojave che ci fa li solo soletto? 😄 Link to comment Share on other sites More sharing options...
philarticolo31 Posted October 31, 2020 Share Posted October 31, 2020 che ciecato... ora funge. però e per airdrop? come faccio a farlo andare? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted November 1, 2020 Support Team Share Posted November 1, 2020 non saprei, disabilita questo e prova l'altro kext anche se in beta e vedi se poi ti funge https://github.com/OpenIntelWireless/itlwm/releases/tag/v1.2.0-alpha puoi anche leggere la loro documentazione https://openintelwireless.github.io/itlwm/ Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted November 1, 2020 Support Team Share Posted November 1, 2020 Does it support Apple's Continuity Framework (Airdrop, HandOff) Currently, only Handoff and Universal Clipboard works with AirportItlwm, other features are not supported. Link to comment Share on other sites More sharing options...
philarticolo31 Posted November 1, 2020 Share Posted November 1, 2020 ok adesso ho provato anche con airportitwlm e funziona anche lui direttamente dalle preferenze di sistema. c'è però una cosa che non mi torna: come mai nonostante abbia disabilitato i kext relativi a brcm (il dongle bluetooth che uso per mouse etc) lui continua a funzionare (e di conseguenza non va il bluetooth intel) ? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted November 1, 2020 Support Team Share Posted November 1, 2020 esegui riavvio e magari resetta la NVRAM Link to comment Share on other sites More sharing options...
philarticolo31 Posted November 1, 2020 Share Posted November 1, 2020 (edited) negativo.. anche dopo reset nvram e dongle scollegato. wifi funziona... bt zero se collego dongle funziona.. eppure da config è tutto disabilitato ciò che concerne brcm Edited November 1, 2020 by philarticolo31 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted November 18, 2020 Moderators Share Posted November 18, 2020 Allora io mi trovo in questa situaziuone la mia scheda intel wifi dual band AC 3165 funge benissimo, wifi e BT su Catalina Con un solo kext AirportItlwm.kext e senza istallare HeliPort ma questo tenendo sul config di OC Misc/Security/SecureBootModel su Default come vedete da foto mentre in BigSur le cose cambiano il kext Airportitlwm, non funziona più, e devo per forza cambiare il Secure citato sopra in Disable, altrimenti BigSur non si avvia proprio, allora ho ripiegato con itlwm.kext ed istallando HeliPort ma oltre ad avere due icone Wifi (una non funzionante) fa un pò ca.....re la connessione e rispetto a prima non mi sembra che con tutti questi raggiri sia vanilla come il precedente C'è modo di far funzionare il vecchio kext? Per il BT non ho problemi finge in entrambi i casi Link to comment Share on other sites More sharing options...
AlexAMD Posted November 19, 2020 Share Posted November 19, 2020 Anche io ho riscontrato i tuoi problemi, per la doppia icona puoi disabilitare quella del mac e lasciare quella di Heliport .... speriamo che con il kext Airportitlwm 1.2 si risolva anche su big sur .... inoltre con i kext itlwm non vede piu la wifi ma la vede come eternet ..... 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted November 19, 2020 Support Team Share Posted November 19, 2020 3 ore fa, AlexAMD ha scritto: inoltre con i kext itlwm non vede piu la wifi ma la vede come eternet ..... tutto normale, è spiegato nel loro wiki Spoiler Non lasciarti ingannare se Ethernetmostrato nelle Preferenze di Sistema. Il motivo è che non ho utilizzato il closed source di Apple IO80211Family, ma ho piuttosto falsificato l'hardware come un dispositivo Ethernet, proprio come le schede Wi-Fi USB. https://openintelwireless.github.io/itlwm/#compatibility Link to comment Share on other sites More sharing options...
