Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 e non usare la mia EFI, avvia e posta il blocco, e la efi che stai usando 2500hd non e compatibile quindi metti i3 e 710 Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 ecco... qui ci sta buoni 5min...poi parte con la mela aggiornato smbios con la versione più appropriata con l'i5 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 posta la cartella clover Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 ti serve origin? Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 scusa ma i kext, quali stai usando? metti fakeSMC, lilu e Weg in Other no, fai tu, metti i kext che ho detto e togli gli altri Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 nella cartella 10.15 ho virtualsmc..ma l'ha messo clover...devo aggiungere anche fakesmc? Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 qui in clover/System Parameters cosi On 4/11/2020 at 7:40 PM, fabio8v said: nella cartella 10.15 ho virtualsmc..ma l'ha messo clover...devo aggiungere anche fakesmc? Expand toglilo e metti quello che ho detto in Other Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 ecco la efi...migliorato di molto il tempo di caricamento..procedo con l'installazione EFI.zipFetching info... siamo nell'ordine di 1 min Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 i kext li devi mettere in Other tutti se flagghi inject NVidia, non mettere nv_disable nelle flag del bootarg, la 710 è nativa Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 ok...nv_disable lo mettevo per sicurezza Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 ho tolto nv_disable e non va in grafica Link to comment Share on other sites More sharing options...
fabio8v Posted April 11, 2020 Author Share Posted April 11, 2020 in pratica la barra sotto la mela avanza finchè lo schermo diventa nero..e lì rimane Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted April 11, 2020 Moderators Share Posted April 11, 2020 togli la spunta su injectNvidia e riprova Link to comment Share on other sites More sharing options...
fabio8v Posted April 12, 2020 Author Share Posted April 12, 2020 Funziona!!!!! Bravissimo!!!! Grazie per l'aiuto Link to comment Share on other sites More sharing options...
